What type of Coolant?
atters247
PostPosted: 20:16 - 05 Aug 2014    Post subject: What type of Coolant? Reply with quote
Hi Folks - just got an ER5 as first "biggie" and need some advice. It's been stood for months with previous owner so needed some work doing - new filters and rear tyre initially.
It tends to run hot after a while, was wondering if this is normal? I've checked coolant levels and this is around the lower mark and need some advice on which coolant to get to top it up or flush it out with new as I don't know how long the current stuff has been in.
PostPosted: 20:16 - 05 Aug 2014    Post subject: Reply with quote
How hot exactly?
atters247
PostPosted: 20:20 - 05 Aug 2014    Post subject: Reply with quote
I can feel the heat through my boot - that hot.
PostPosted: 20:24 - 05 Aug 2014    Post subject: Reply with quote
Well... that isn't a great gauge of heat Laughing
Coolant bubbling out of overflow?
Changed oil and coolant recently? Just standard antifreeze/water mix is what goes in my bikes. Anything from Tesco.
el_oso
PostPosted: 20:25 - 05 Aug 2014    Post subject: Reply with quote
probably normal. Does it have a temperature gauge?
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 20:28 - 05 Aug 2014    Post subject: Reply with quote
ER5s dont, they have basic as hell clocks. Mine was ridden in winter and was warm regardless. Laughing
atters247
PostPosted: 20:43 - 05 Aug 2014    Post subject: Reply with quote
Nope, no temp gauge, just a red light indicator. No coolant bubbling up. It's the first one I've had that needed coolant so figured to ask for advice. Had the oil changed with new filter, also had new air filter fitted.
andys675
PostPosted: 21:11 - 05 Aug 2014    Post subject: Reply with quote
coolant is a change every three years on my service schedule
if it is on the bottom it may be for a reason, like so it doesn't overflow when its running, lots of triumphs suffer from this, leave it on the minimum to stop coolant leak during heat expansion
silkolene pro cool or castrol motorcycle coolant will be fine, just use straight from the bottle
bodger
PostPosted: 21:23 - 05 Aug 2014    Post subject: Reply with quote
Main thing is don't mix old style blue/green antifreeze with OAT pink/red/orange antifreeze.
Best to drain,flush and fill up with 50/50 mix
The last post was made 12 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 56.36 Kb
