Bike balance - no wheels
Commuter_Tim
PostPosted: 20:17 - 05 Aug 2014    Post subject: Bike balance - no wheels Reply with quote
Will a CG balance on the centrestand, sans wheelage?
I would assume if both wheels weigh roughly the same, it should be OK?
I need to get the wheels trued up, unfortunately there is only 1 little old man who seems to do spokes in the entirity of Tyne and Wear...
I would assume hes not gonna remove and de-tyre the wheels for me (also making the assumption the tyres need to be removed).
my bike will be stored out the back, ground anchored.
Suggestions?
TL:DR How balance CG no wheels?
I ride a Bandit 600... badly.
PostPosted: 20:19 - 05 Aug 2014    Post subject: Reply with quote
Axle stand + spindle.
It won't magically balance Thumbs Up
Itchy
PostPosted: 20:23 - 05 Aug 2014    Post subject: Reply with quote
Bricks under the fork legs, and swing arm.
There done.
Or hang the bike from beams of your garage roof. Or using a corner.
A LONG time ago a BCFer used two windows which were on a corner of his home, he put a plank of wood between the two windows and hung his bike from it.
PostPosted: 20:28 - 05 Aug 2014    Post subject: Re: Bike balance - no wheels Reply with quote
Shouldn't need to remove tyres, I'd have thought - unless you need new spokes anyway.
Possible it could even be done still on the bike, but expect they'd prefer to be given wheels.
Stuff under each end and you should be fine.
Don't let it rock too much on the centre stand without wheels as may fold up. Or just do that intentionally and place it on the ground Smile.
Commuter_Tim
PostPosted: 20:56 - 05 Aug 2014    Post subject: Re: Bike balance - no wheels Reply with quote
Interesting, will give the fella a ring tomorrow and see whats what.
I would happily pay him more if I didn't have the bother and could just ride there and have him sort it ...that will not be my opening line of course Smile
Raffles
PostPosted: 22:03 - 05 Aug 2014    Post subject: Reply with quote
I find that using a number of extra long 1/2'' extensions fitted with a suitably sized socket and inserted into the underside of the headstock to be the simplest and the safest way of supporting the front end. Using this method means that the bike can withstand being knocked and the front end turned from lock to lock without danger of it falling over.
Bunny Lingus
PostPosted: 01:34 - 06 Aug 2014    Post subject: Reply with quote
Lynch it with a friendly tree or stick a leash on that puppy & tie it to the garage roof. It'll dive forwards. I have a bare CG frame with just yokes on & that will balance on the kick part of the centre stand but I still tie it up in case it falls over on the cat...
Bunny Lingus & The Flipside Faggots
The last post was made 12 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 52.7 Kb
