| spikenipple |
 spikenipple Crazy Courier
 Posted: 15:50 - 02 Aug 2014 Post subject: Can you identify this subframe? |
I picked up an NC21 track bike yesterday which has had this subframe modified (read: bodged) to fit. It clearly isn't an NC21 subframe and I was told it's from an RS250 but it's not that either.
What's interesting is that the lower mounts are forward-facing rather than the original subframe that's bolted on parallel to the frame. The frame doesn't appear to have the original subframe lower mounts on it.
Any ideas?
https://i49.photobucket.com/albums/f277/Spikenipple/IMG_2052_zpsdcfc9348.jpg
https://i49.photobucket.com/albums/f277/Spikenipple/IMG_2053_zps04704971.jpg
Any help would be greatly appreciated!
Cheers ____________________ C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike |
| Bunny Lingus |
 Bunny Lingus Traffic Copper
| recman |
 recman World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 08:59 - 03 Aug 2014 Post subject: |
2 questions.
Does it work?
What's the problem?
Should see the subframe on my SV track bike...  |
| spikenipple |
 Posted: 14:19 - 03 Aug 2014 Post subject: |
It's steel. I'm not sure if it's homebrew as most of the welding is up to a professional standard but some of it is really crap, for example where two nuts have been welded on to fit the (homebrew) seat unit.
It looks like this when fitted.
https://i49.photobucket.com/albums/f277/Spikenipple/IMG_2047_zpsb2520b4d.jpg
Paddy, it works....sort of. The seat unit sits on top of the battery cage and there are two M6 nuts welded to the subframe to hold it on, so it flaps about a bit. There are two holes drilled through the subframe to fit the seat bolts, which has no place to hook at the front, and there's no rear tank mount so that moves about too. It's all a bit dodge!
I think I'll just have to cut and weld bits to get it all to fit.
The reason I'm trying to identify it is to see if there's a half decent race seat unit I can buy! ____________________ C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike |
| P.addy |
 P.addy Red Rocket
| kramdra |
 kramdra World Chat Champion
| spikenipple |
 Posted: 07:10 - 04 Aug 2014 Post subject: |
Ok cheers kramdra
It's not nearly as tasty as it looks....the wiring is an absolute mess. It has switchgear from a different bike, the l/h switchgear is missing altogether and plenty of electrical components are missing plugs where they've been butchered to fit the loom it came with....which is from a different Honda! The clocks are missing too.
I've trial-fitted an NC21 loom and it all seems to be correct, I'm just waiting for a fuse box to try and get it going.
If anyone has any of the following, please drop me a PM!
Clocks
Switchgear (both sides)
Upper swingarm chain guide (the rubber/plastic thing that the chain runs over)
Reg/rec
Spare 4/6 pin Honda connectors (including mini pin type) ____________________ C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike |
| Bunny Lingus |
| spikenipple |
 Posted: 08:15 - 06 Aug 2014 Post subject: |
Uhmmmm...thanks?  ____________________ C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike |
The last post was made 12 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
