06 r6 brake fade
biggeeman
PostPosted: 11:14 - 07 Aug 2014    Post subject: 06 r6 brake fade Reply with quote
Hi 2006 r6 having brake fade probs wen hot
I have galfer steel lines new crush washers etc
Rbf 600 fluid
Sbs race pads
Vacuum bled twice now
Real pazzo levers
But still getting brake wen at track or even street could I still have
Air in the system?
Any help would be great.
lol your funny
PostPosted: 11:24 - 07 Aug 2014    Post subject: Reply with quote
Replace the fluid.
biggeeman
PostPosted: 11:35 - 07 Aug 2014    Post subject: Reply with quote
MarJay wrote:
Replace the fluid.
Was new bottle you thinks its fookd?
lol your funny
PostPosted: 12:16 - 07 Aug 2014    Post subject: Reply with quote
biggeeman wrote:
MarJay wrote:
Replace the fluid.
There are three reasons for brake fade:
1.) Water contamination in the fluid
2.) Old fluid
3.) Huge amounts of air in the system.
If it was 3 then you'd find that the brakes wouldnt' work at all, or at the very least be spongy. What kind of fluid did you put in? Did you use DOT 5.1?
biggeeman
PostPosted: 13:23 - 07 Aug 2014    Post subject: Reply with quote
Hi,
No sure mate if its 5.1 its motul rbf 600 supposedly the bees knees stuff.
lol your funny
Aff
PostPosted: 13:26 - 07 Aug 2014    Post subject: Reply with quote
Under what conditions you getting the fade?
How much do your weigh?
Electric Bike Project
biggeeman
PostPosted: 13:32 - 07 Aug 2014    Post subject: Reply with quote
Generally hard on the brakes wether it be street or track.
I weigh about 13.5 stone poor brakes lol
The fluid is dot4
lol your funny
Aff
PostPosted: 13:38 - 07 Aug 2014    Post subject: Reply with quote
How do the discs look? Show any bluing? Glazing?
Still definitely worth putting new fluid in the and bleeding properly.
Copycat73
PostPosted: 14:21 - 07 Aug 2014    Post subject: Reply with quote
"Racing Brake Fluid 600
Avoid mixing with polyglycols based brake fluid with lower performances.
Do not mix with silicone (DOT 5 silicone base) or mineral base fluids (LHM)."
Thinking
caveat emptor
biggeeman
PostPosted: 14:52 - 07 Aug 2014    Post subject: Reply with quote
No glazing scotch Brite/ light sanded the disc but they were fine anyway I did rule that out. Discs are light blue and back of old pads are very blue. New pads do bite better but still lever fading.
lol your funny
Robby
Dirty Old Man
PostPosted: 18:06 - 07 Aug 2014    Post subject: Reply with quote
If the fluid isn't the problem, then my next thought is heat. You're getting too much of it into the system, and not enough out.
Are the pads that you're using meant to go with a different sort of brake disc? Did you omit any springs or shims when fitting them? Race pads are designed to avoid brake fade at high temp, with the downside of reduced performance at low temp. The issue could be that the brakes want to be at a higher temperature than the fluid is happy with, or the disk isn't dispersing the heat.
The alternative is a sticky piston in a caliper making a pad drag on a disc. This makes heat at all times, including when you're off the brakes and they should be cooling down.
My final thought would have been dodgy fake pazzo levers holding the brakes a little bit on all the time, but you ruled that out in the original post.
biggeeman
PostPosted: 20:36 - 07 Aug 2014    Post subject: Reply with quote
No nothing has been left out pins plates etc
The pads do work with the discs my mate has r1 on same setup he doesn't get fade.
I put the bike on a paddock and span the wheel 1 to 2 turns which I believe is correct plus I let a little fluid out the reservoir to ease the pressure as such.
I've had that dodgy lever issue before with a clutch my fz1 had Chinese levers after a track session, I couldn't move the clutch stripped the thing to bits new cable new clutch plates and engine oil turned out to be the lever so always buy the real McCoy now lol.
lol your funny
Rockhopper
PostPosted: 21:44 - 07 Aug 2014    Post subject: Reply with quote
Explain exactly what your symptoms are. A spongy lever is not brake fade for example.
PostPosted: 21:59 - 07 Aug 2014    Post subject: Reply with quote
OE disks on the R6 are fine for Superstock/Supersport Racing, so unlikely to be an issue on the road/trackdays.
I've been on track with SBS Dual Carbon pads, and OE discs with no issues at all. All day. Granted I am a little lighter, but only a couple of stone.
My money's on a fluid or caliper issue.
I suggest you strip and clean your calipers to, and change your fluid. I think I used Motul or castrol in my old one. Thinking
biggeeman
PostPosted: 22:23 - 07 Aug 2014    Post subject: Reply with quote
spongy lever for sure thankfully I have good pads so i can still stop, but I cant exert more force cause my lever is at my fingers/bar when hot.
folk on the r6 forum telling me I need the brembo rc master cylinder granted it will be better but my wallet will be way lighter. my 03 zx636 track bike had stock system with ss lines and they brakes were stonking. so im not convinced I need to spend lots of cash on a m/c unless mines is fookt of course, but if my brakes are cool my lever is mint so that kind of rules the m/c is functioning well.
lol your funny
PostPosted: 10:59 - 08 Aug 2014    Post subject: Reply with quote
Sounds like water contamination.
biggeeman
PostPosted: 15:10 - 08 Aug 2014    Post subject: Reply with quote
I've put new fluid in today putoline race dot 4. lever feels no different cold but it wouldn't.. will try to get a blast around over the weekend as it's pissing the now.
Spoke to a bike mechanic today whilst getting fluid he reckons brake discs are fookt lol I get a good 2/3 spins on the paddock as it should with no evidence of a warp disc, brakes are a nightmare. I'll report back once I get a chance to nip out.
lol your funny
iooi
PostPosted: 18:44 - 08 Aug 2014    Post subject: Reply with quote
Seal on the piston in master cylinder could be worn. Or there is some crap in the bottom.
I would taken the brake lines off and let all the fluid drain out and start from scratch again.
biggeeman
PostPosted: 23:58 - 08 Aug 2014    Post subject: Reply with quote
Fluid in from an empty system, as empty as I could get it
See what happens when I get a chance to go out.
If this doesn't work may replace all the seals calliper and m/c. Bikes just turned 20k probably likely seal are fookt now.
lol your funny
orac
PostPosted: 11:12 - 09 Aug 2014    Post subject: Reply with quote
er, didnt r6 from 2004 on wards a get recall due to front master cylinder issues causing something along thses lines.
I would be tempted to swap out the master cylinder and see if the that helps
Edit:
https://www.motohouston.com/forums/showthread.php?t=269853
it seems so, i can only find us refrence to it. maybe worth a visit to your dealer and ask them to check things over and make sure yout didnt miss the recall if there was one in the uk
MCN covered it:-
https://www.motorcyclenews.com/mcn/news/newsresults/general-news/2013/october/oct1813-massive-suzuki-gsx-r-recall/
PostPosted: 17:47 - 09 Aug 2014    Post subject: Reply with quote
orac wrote:
OP has an R6, not a GSXR.
IIRC the 06 onwards R6 got a brembo M/C.
biggeeman
PostPosted: 18:01 - 09 Aug 2014    Post subject: Reply with quote
Yeah it's not a gsxr, tbh i think It is the m/c I nearly get it to touch the bars even when cold, after a good bleed. I thinks there's play in the m/c can anyone else get there's to the bar cold and survive a track day?
With little fade?
lol your funny
The last post was made 12 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.34 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 138.32 Kb
