Central heating boiler: odd noise.
Ribenapigeon
PostPosted: 13:27 - 08 Aug 2014    Post subject: Central heating boiler: odd noise. Reply with quote
I have an odd noise from my CE boiler.its when the pump stops when it switches off and when it stops after it does what I think is a routine trun over of the system every now and then. Its like a pipe banging but with a bit of a juddering noise. Its a Viessmann Vitodense 200. Any ideas? It had the main pump changed about six months ago and its about five years old. Its always made this noise and no change after the pump was changed.
mudcow007
PostPosted: 13:54 - 08 Aug 2014    Post subject: Reply with quote
air lock maybe?
pipes loose anywhere so they clatter when pressure changes?
i know our cold water pipe is loose in the wall an makes all sorts or weird n funky noises
Rigga
PostPosted: 13:55 - 08 Aug 2014    Post subject: Reply with quote
Air locked maybe? Or not enough pressure?
Current bike: Honda CBR 1100xx
Ribenapigeon
PostPosted: 17:28 - 08 Aug 2014    Post subject: Reply with quote
Pressures fine and engineer bled and repressurised the expansion chamber when the new pump was put in. Its not a loose pipe either.
PostPosted: 18:00 - 08 Aug 2014    Post subject: Reply with quote
Run out of the house, dial 999.
PostPosted: 18:10 - 08 Aug 2014    Post subject: Reply with quote
There's loads of reasons why it could be making the backfiring noise. Unless you're knowledgeable about boilers and gas installations then it's not a DIY job.
robs321
PostPosted: 19:08 - 08 Aug 2014    Post subject: Reply with quote
Could be the heat exchangers scaling up!
Al
PostPosted: 19:51 - 08 Aug 2014    Post subject: Reply with quote
I think the 200 has an internal diverter valve that makes a bit of a strange kind of groaning noise when it resets.
Yamaha FZR400RR 3tj
My Instagram Thingy
hellkat
PostPosted: 20:09 - 08 Aug 2014    Post subject: Reply with quote
She cannae take any more, Captain ...
Carl_steveo
PostPosted: 02:11 - 09 Aug 2014    Post subject: Reply with quote
I've had no hot water for a week. Crying or Very sad
Fucking flame failure every fucking time.
Current: Honda Nsr 125
Live: Sunderland
bikertomm
PostPosted: 17:07 - 12 Aug 2014    Post subject: Reply with quote
Is a certain store manager stuck inside?
Itchy
PostPosted: 17:44 - 12 Aug 2014    Post subject: Reply with quote
Is the boiler pre-empting the intake of air sound a plumber makes when you ask for a quote to fix it? Razz
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 17:58 - 12 Aug 2014    Post subject: Reply with quote
You could park your bike outside a British Gas store and ask advice.
thepuma
PostPosted: 18:01 - 12 Aug 2014    Post subject: Reply with quote
Nah...he'd more likely park outside the shop over the road just to piss them off.
765 RS
Fowlersrs
PostPosted: 19:33 - 12 Aug 2014    Post subject: Reply with quote
Could be any number of things, how olds the rest of the heating system? Do u have thermostatic radiator valves fitted? Is there a bypass underneath the boiler on the heating circuit (appreciate you prob won't know this)
Worst case scenario is boiler heat exchanger is scaled /blocked... Struggling to move the heat from it results in the water boiling inside which can cause banging.. This is new boiler time tbh.
Best case, something simple like no bypass or non bi directional trvs so the valves are banging through reverse flow..
Fowlersrs
PostPosted: 19:34 - 12 Aug 2014    Post subject: Reply with quote
Don't keep resetting it, get someone to sort why it's failing.. HTH
Bunny Lingus
PostPosted: 22:21 - 12 Aug 2014    Post subject: Reply with quote
Turn on all taps & let 'em run for a minute. Try & staunch the delivery briefly with a wet tea towell so that water backs up in the pipes. Then turn 'em all off downstairs first. Bleed the rads when hot then bleed the boiler. Treat it as you would hydraulic brakes. Boiler = MC, pipes = lines, caliper nipple = taps.
Ed: Hold on before you do anything! You first need to know that I ain't Corgi registered & this... Shocked
Total posts: 666 (0.02% of total / 5.79 posts per day)
Find all posts by Bunny Lingus
https://www.youtube.com/watch?v=MCrEeqmjOBo
Bunny Lingus & The Flipside Faggots
The last post was made 12 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 95.23 Kb
