Speedometer not working.
Hefty
PostPosted: 07:31 - 13 Aug 2014    Post subject: Speedometer not working. Reply with quote
Hoping someone can help me with this.
Noticed on my commute to work today my speedo isnt working, not registering speed or clocking miles. Cant tell if the bulbs gone too as its daylight & not had time to check it over properly.
Am I correct in assuming its the cable that runs from behind the speedo down to the bottom of the forks? Gave that a bit of a shove each end to make sure neither end had come away etc.
It was working fine last night, wasn't this morning. Any suggestions?
2011 Honda CBF125.
'13 Honda CBF125 // '99 Suzuki SV650s // '98 Honda CB600F Hornet
neil.
PostPosted: 07:45 - 13 Aug 2014    Post subject: Reply with quote
The cable inner has most likely snapped - very common and you need to replace the entire cable, which is usually around £10 or so.
Hefty
PostPosted: 07:55 - 13 Aug 2014    Post subject: Reply with quote
Cheers for the quick response. How much you reckon it'll cost to have a new one fitted?
Is there any way I can check thats actually whats happened?
neil.
PostPosted: 07:59 - 13 Aug 2014    Post subject: Reply with quote
It's easy enough to do yourself. If you disconnect the cable at both ends and remove it, twist the inner at one end and if it doesn't turn at the other end it's snapped inside.
Hefty
PostPosted: 08:13 - 13 Aug 2014    Post subject: Reply with quote
Okay ill have a go on my lunchbreak. Im guessing its as simple as ordering a new cable and replacing the old one via the same method?
Hefty
PostPosted: 12:35 - 13 Aug 2014    Post subject: Reply with quote
Cheers Iain Thumbs Up
Before I proceed & cock it up.. Is this the correct cable?
https://i.imgur.com/stPNR0m.jpg
Also it looks like im gonna have to remove the half-fairing to get behind the speedo? Unless theres an easier way? Sorry for being a mongoloid but this is very much terra incognito for me, in case you couldnt tell.
totalllama82
PostPosted: 21:33 - 13 Aug 2014    Post subject: Reply with quote
That'll likely be it yes.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
The last post was made 11 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 63.9 Kb
