New build won't boot, pulling my fucking hair out UPDATE PG3
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2, 3, 4, 5  Next
sabian92
PostPosted: 11:48 - 15 Aug 2014    Post subject: New build won't boot, pulling my fucking hair out UPDATE PG3 Reply with quote
Hi all,
Recently put this together as I was getting bored with console gaming.
I replaced the motherboard I had originally (MSI Z97 GD65) with the gigabyte one because I wanted to hackintosh but the MSI board isn't compatible. But that being said, I know everything works. The only thing that's changed is the motherboard.
I got the first one, got my CPU, CPU cooler, RAM and a SSD plugged in with an HDMI lead to my monitor and it booted but displayed nothing on the monitor. No BIOS, nada. Kept saying "Checking Signal" or some shit. Eventually the monitor goes into standby because there's no signal to it, and I've tried several HDMI cables so I know it isn't that.
Thought the board was shagged so returned it, got another one that's just arrived. Same issue. Surely I can't be that daft that can I? Mad
Cheers. Thumbs Up
Build:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor (£155.94 @ Scan.co.uk)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler (£48.79 @ CCL Computers)
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard (£128.96 @ PC World Business)
Memory: Kingston Fury Red Series 8GB (1 x 8GB) DDR3-1866 Memory (£60.11 @ Amazon UK)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive (£83.23 @ Amazon UK)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive (£55.60 @ Aria PC)
Video Card: Gigabyte GeForce GTX 770 2GB WINDFORCE Video Card (£229.87 @ Scan.co.uk)
Case: NZXT Switch 810 (White) ATX Full Tower Case (£109.32 @ Scan.co.uk)
Power Supply: SeaSonic 660W 80+ Platinum Certified Fully-Modular ATX Power Supply (£114.19 @ Scan.co.uk)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£11.21 @ Aria PC)
Monitor: LG 27MP65HQ 60Hz 27.0" Monitor (£202.13 @ Amazon UK)
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140mm Fan (£17.80 @ Ebuyer)
Other: Logitech M510 Wireless Mouse (£20.00)
Other: Logitech K270 Wireless Keyboard (£20.00)
Other: AKG K451 (£50.00)
Other: Logitech G27 (£187.50)
Total: £1631.28
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2014-08-15 11:48 BST+0100
MarkJ
PostPosted: 11:57 - 15 Aug 2014    Post subject: Reply with quote
Does your monitor have an input selection button? The ones at work we have to manually cycle between DVI or VGA depending on what cable the PC uses, the monitor won't automatically choose what input to use. Have a look in the monitor menu and see if you can force it to use the HDMI input.
PostPosted: 11:58 - 15 Aug 2014    Post subject: Reply with quote
I know you WANT HDMI but have you tried DVI/VGA at all...?
PostPosted: 12:13 - 15 Aug 2014    Post subject: Reply with quote
Do you hear the post beep?
Try the select input thing as above.
Failing that remove the SSD all all but 1 stick of RAM, if still no joy switch the sticks.
You have got the ram in the Correct clots haven't you? Mine has 6 slots and you must put the sticks in specific slots depending on how many you have.
Failing that try pluging in your GFX card too.
wytco0
PostPosted: 12:14 - 15 Aug 2014    Post subject: Reply with quote
Process of elimination, its a fairly complex build, pull everything you can down to minimum needed to boot. If the mobo has bulit in VGA try and use that and disconnect the graphics card as well. Use the minimum memory the mobo will handle (some insist on matched pairs etc)
Try and use a wired keyboard and mouse if you can.
When you can get it to boot reconnect bits one by one.
Good luck its probably something trivial.
current bike: 2014 Kawasaki ER-6f
sabian92
PostPosted: 12:18 - 15 Aug 2014    Post subject: Reply with quote
It doesn't, but I've had my laptop plugged into it to make sure it wasn't the monitor and it displayed straight away. Laptop has a VGA port as well, so it's essentially the same as the PC output-wise.
Aye, tried it with the previous board and this one. No dice.
Failing that try plugging in your GFX card too.
No, but for some really irritating reason it doesn't have a speaker. the MSI one didn't either. They've got these LED readouts for error codes instead but it's not even spitting out an error code. I tried booting it without the SSD, RAM in each slot (I've only got 1 stick at the moment) and it didn't work. I also read that you needed to dick with the BIOS to get it to accept 1866 RAM but I tried a 4GB 1366 stick from my HTPC (Same brand/type of RAM, just different MHz) and it didn't work either.
I can't see 2 motherboards (supposedly high quality ones at that) being DOA. Rolling Eyes Seems it may be the case though.
t121anf
PostPosted: 12:21 - 15 Aug 2014    Post subject: Reply with quote
Related?
https://forums.geforce.com/default/topic/719280/monitor-losing-signal-before-welcome-screen/
t121anf
PostPosted: 12:22 - 15 Aug 2014    Post subject: Reply with quote
Oh hang on, i missed you have a Graphics Card installed to.
the bios is set by default to the onboard only, have you change it yet?
PostPosted: 12:29 - 15 Aug 2014    Post subject: Reply with quote
Mobo's don't come with speakers it should have came with your case. Plug it in and listen for a beep code.
That RAM isn't on the Approved Vendor List, so that could be the issue. Before returning it use some RAM they actually say will work in the paperwork. This is stuff you should have checked before ordering.
I'd also suggest starting again from scratch take everything out and refit.
sabian92
PostPosted: 12:59 - 15 Aug 2014    Post subject: Reply with quote
I have a GPU but it isn't installed. This is all from the onboard ports. I haven't even managed to see anything yet, much less arse about with the BIOS!
I really don't recall getting one but I can go and scrounge one from somewhere. Looking online NZXT don't ship speakers with their cases any more, which is odd and a bit tight as they're not exactly expensive either. Considering the case alone was 100 quid plus, it wouldn't have gone amiss.
I did check it when I ordered the original motherboard, I didn't think it was an issue when I ordered the other board - considering it's a decent brand and well known I thought it would be okay with another major brand mobo.
I'll go and find some RAM that's apparently compatible then, and try that.
PostPosted: 13:26 - 15 Aug 2014    Post subject: Reply with quote
I wonder when that changed I ordered a NZXT case 20 months ago, it came with one. You should be able to pull one from any PC of the last 20 years. If not one would be a couple of quid from Maplin/PC repair shop.
sabian92
PostPosted: 13:41 - 15 Aug 2014    Post subject: Reply with quote
*shrug* No idea. I didn't get one though.
I'll nip to the local PC shop and get one anyway.
If I need to replace the RAM, is this going to be okay? I checked it against the compatibility list but a second opinion is always good.
PostPosted: 13:50 - 15 Aug 2014    Post subject: Reply with quote
It's not on the list as far as I can see.
PostPosted: 13:55 - 15 Aug 2014    Post subject: Reply with quote
I'd get the speaker to check for a beep code and try a different PSU before changing memory, the memory might not the issue, the Vendor list isn't definitive.
sabian92
PostPosted: 18:02 - 15 Aug 2014    Post subject: Reply with quote
I can't really understand the list much, I'm trying to find a single 8GB stick that matches but all that come up are 8GBx4 kits which are both expensive and unwanted.
Any recommendations? 1600Mhz preferably.
I know for a fact that the PSU works. I used it right up until the new mobo got here and then it wouldn't display anything. It's brand new as well.
Jayy
Mr. Ponzi
PostPosted: 18:24 - 15 Aug 2014    Post subject: Reply with quote
Pretty bizzare that two boards are doing the same thing. I would say you can safely eliminate the board, unless you've been extremely unlucky to get two fucked boards.
Next step I would be looking at the RAM / PSU. I've had faulty sticks cause a total non boot on the PC and also had faulty PSUs that have caused non boots.
If you've eliminated the monitor by checking it on a laptop and it came on straight away, it could be that fact you're using HDMI and not DVI?
You can't even see the BIOS though to check, can you?
Seb
PostPosted: 18:50 - 15 Aug 2014    Post subject: Reply with quote
Quick and simple test to get you pointed in the right direction.
Turn it on, give it 10 seconds, tap the power button again.
Does it switch off?
If it stays on then it's not posting, start looking at ram/expansion cards, can also simply be a duff motherboard.
If it switches off on the button, it's posting but you've got a video issue.
2010 Triumph 1050 Sprint ST
sabian92 wrote:
It doesn't
The manual says it does. Wink
Make sure that's set to HDMI. If the onboard video still doesn't work then try fitting the graphics card and then try the HDMI on that and then the VGA on that.
Can you try using a different monitor?
The CPU is seated correctly and you've not managed to bend any of the pins?
Try plugging a keyboard, once the pc is switched on the keyboard should light up and look 'normal', what happens if after you've switched the PC on if you press crt-alt-del?
Copycat73
PostPosted: 19:14 - 15 Aug 2014    Post subject: Reply with quote
have you took the insulation sticky off the bios battery ?
caveat emptor
sabian92
PostPosted: 20:14 - 15 Aug 2014    Post subject: Reply with quote
Yeah, I thought as much. 2 duffers is rare as rocking horse shit. I know for a fact the PSU works as it powered the build previous to returning the MSI mobo and I didn't have any problems. It's a decent PSU (gold rated I think?) so it's not likely to have fried anything nor have shat itself. I've tried HDMI and VGA and neither worked on the new motherboard although they worked on the old one and on the laptop.
I can't see the BIOS at all.
It's definitely set to HDMI as it's worked with other HDMI outputs. I've tried the GTX770 and it didn't work either.
I've tried a different monitor (An old as fuck VGA monitor Laughing) and it didn't work either. CPU is seated correctly and no pins are bent.
Does it switch off?
It doesn't go off so it's not POSTing in that case. I have to flick the PSU power switch to get it to go off.
I'm going to take a stab at the RAM being the wrong type. It's not on the recognised list so it would be the obvious thing.
I've had the battery out and there's none on it, and I've cleared the CMOS as well.
el_oso
PostPosted: 06:49 - 16 Aug 2014    Post subject: Reply with quote
It would be quite rare/unusual for RAM to not be compatible, unless it is some super duper high speed overclocked RAM. Just because it's not on the approved list doesn't mean it's not going to work, just means they haven't tested it.
If you haven't already I would be taking everything apart and starting again. Have you actually checked what configuration the RAM needs to go in. Some motherboards will only work with a pair of RAM sticks in channel 1 or whatever.
Ditch the HDMI for now, use VGA, it's a much safer option and go grab a speaker.
Duke 390
Car: Jeep Wrangler 4.0L
Seb
PostPosted: 09:13 - 16 Aug 2014    Post subject: Reply with quote
It's possibly worth getting down Maplin first and getting a PC speaker. You 'should' get a different beep code between no ram and incompatible ram. So pulling all the ram out and trying to boot should hopefully give you a little confirmation that it is indeed that.
bugeye_bob
PostPosted: 09:29 - 16 Aug 2014    Post subject: Reply with quote
new PC speakers look like this
https://i.ebayimg.com/00/s/NzcyWDg3Mg==/z/dmsAAOxyn~pR2EoL/$(KGrHqZ,!qwFG7I4FHeHBR2EoLpvYQ~~60_35.JPG
CaNsA
PostPosted: 13:29 - 16 Aug 2014    Post subject: Reply with quote
Do you get anything displaying on the LED code panel thing on the motherboard next to the ram slots?
The last post was made 12 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 146.03 Kb
