engine options (chinky content.....sorry)
69chris
PostPosted: 17:54 - 16 Aug 2014    Post subject: engine options (chinky content.....sorry) Reply with quote
hey guys,
im sure iv seen the answer to this already somewhere but cant seem to find it Rolling Eyes
the mrs wanted a 125 to whip around town on, wanted a bantam or sim but couldnt get on with the r/h gearchange,
so i found a chinky 125 and chopped it about a bit to try and make it look old'ish,
however, once it was mot'd and she had used it for a while shes decided it isnt fast enough for those 'out of town' runs,
so, is the another engine that will fit into it ?? dont mind a bit of cutting/welding/wiring etc, but something bigger that would bolt in would be better,
btw, its a cg125 based engine
cheers all Smile
stevo as b4
PostPosted: 18:08 - 16 Aug 2014    Post subject: Reply with quote
I'm sure some of the 125cc Honda specialists on here might know more, but the CG and CB/XL/XLR engines are related and I believe they share mounting points.
I would say that there's a very good chance that a Honda XL200R or XL185 engine would fit without much work at all, if you could find one that is?
There are I believe various Chinese 150-160cc big bore top ends available for the OHV and OHC clone engines, but IMO they won't provide enough extra power to make it worthwhile stripping and re-building a motor with possible less than quality parts?
The XL200R lump is 18bhp. Probably of no use to you if your machine takes a Honda based clone engine, but there are 200cc versions of the Suzuki GS/DR125 engine and also the Yamaha SR/XT125 engine, that make similar power.
CHR15
Turbo nutter bastard
PostPosted: 18:17 - 16 Aug 2014    Post subject: Reply with quote
a dayang dy200 engine will drop in.
69chris
PostPosted: 19:11 - 16 Aug 2014    Post subject: Reply with quote
cheers guys, ill have an ebay search and see what comes up,
although it runs along ok with a farty old sounding exhaust note it just needs to run along a bit quicker Laughing
heres a couple of pics of it for anyone who might be interested, its rusting nicely now Smile
https://i157.photobucket.com/albums/t78/71bugslug/v_zpsb31643e8.jpg
https://i157.photobucket.com/albums/t78/71bugslug/bikes014_zps0986fc03.jpg
PostPosted: 19:23 - 16 Aug 2014    Post subject: Reply with quote
Not sure I'd want that to go much quicker, looks like you've messed up the already poor handling.
She has a good life insurance policy in your name, yes? Wink
69chris
PostPosted: 19:27 - 16 Aug 2014    Post subject: Reply with quote
hahaha its suprisingly ok on the road - dont knock it till ya tried it Wink
im not talking about 'fast' fast, just a bit happier at 55/60 so it doesnt sound quite so strained.....if you know what i mean Smile
PostPosted: 19:42 - 16 Aug 2014    Post subject: Reply with quote
You might want to keep an eye out for the 233cc parallel twin from a Jinlun "250" or similar, coded as a 253FMM. They're also found in some in ATVs, but with reverse gears (could be lulzy). I'm not guaranteeing that it'll fit, just that it's a contender.
Proper job on the bike, but what's holding the rear end up? Eh?
PostPosted: 19:52 - 16 Aug 2014    Post subject: Reply with quote
My (official) Honda CG always seemed fine at those speeds.
It generally maxed out around 65 and never bothered me holding it at that. Had 75 on the clocks with a gentle slope and probably a little tail wind.
So I'd consider a Honda engine, presuming that should slot straight in - but it will depend on what you mean by 'sound strained' - perhaps the issue is more deciding the sound isn't an issue? (Though appreciated the bike was obviously intended for form over function, so guessing that's going to include aural stimuli too.)
I've ridden bikes with overly stiff suspension and ridden hard tail push bikes and not too far off those speeds. I've also ridden bikes that handle well Smile.
69chris
PostPosted: 19:59 - 16 Aug 2014    Post subject: Reply with quote
ta guys Smile
i think its just all the lil chink engine has to give, she had a proper cg before she passed her test and iirc that was perfectly happy at 60 ish but this one sounds 'unhappy' beyond 50,
50 would be ok if it was a comfy cruising speed, its just a bit tiring when it sounds flat out Laughing
i appreciate my homemade exhaust prob isnt helping the situation but it was pretty crap before it was chopped up.............. usual gutless copy junk i guess
cheers again Smile
PostPosted: 20:30 - 16 Aug 2014    Post subject: Reply with quote
My CG-copy-engine saw a real (as in real) 60 without assploding. Buzzy, but it didn't banana the pushrods or shed a valve.
I do have to wonder if you've got the fuelling right. A cone filter and straight through exhaust - is the carb and jetting up to it?
If so, have you tried up-gearing? The copybikes do seem to be geared fairly low.
69chris
PostPosted: 20:43 - 16 Aug 2014    Post subject: Reply with quote
the old carb was buggered so instead of buying a std replacement i bought a slightly bigger carb (24mm ? cant remember) that was sposed to be for a 140 pit bike,
going on the thinking that pitbikes run crappy cone filters and noisy exhausts was my only reasoning Laughing
to be fair to my rash choice iv done a few plug chops and it does seem to be running right, maybe a tad rich at idle/very low revs but ok elsewhere
the gearing is now cg, mainly as the cg wheel came with a new sprocket already fitted so i just bought a matching front along with the new chain
Nobby the Bastard
Harley Gaydar
PostPosted: 21:13 - 16 Aug 2014    Post subject: Reply with quote
Be careful of rusting spokes. Potential MOT failure...
Triumph Sprint ST 1050
69chris
PostPosted: 13:04 - 21 Aug 2014    Post subject: Reply with quote
got ya Thumbs Up
i meant 'cosmetic' rust, the tank was left to fester a bit before it was lacquered and the frame and....well, almost everything else had varying coats of paint to encourage an 'aged' look to develop
i know its not everyones cuppa tea but it works for the mrs which means i have peace - happy days Laughing
Robby
Dirty Old Man
PostPosted: 13:12 - 21 Aug 2014    Post subject: Reply with quote
Your complaint is about poor performance.
You're running a cone air filter, a straight-through exhaust, and a random pitbike carb. This is not conducive to giving the engine exactly the right amount of fuel and air, all the time.
Plug chops won't tell you much. You can get an idea of whether the fuelling is generally rich or lean, but it could well be lean at a quarter throttle and rich at three quarters throttle.
I would start off by fitting the right carb, with the right settings and jet sizes.
69chris
PostPosted: 13:31 - 21 Aug 2014    Post subject: Reply with quote
noted and agree
but as mentioned up there ^^ somewhere it was pretty lacking in go before it was chopped up when it was running stock 'everything',
if anything its maybe a lil more peppy now - mind you that might be coz its weighs half as much now Laughing
wr6133
PostPosted: 13:43 - 21 Aug 2014    Post subject: Reply with quote
The 253FMM roger suggests would physically fit the space. You'd have to chop about and weld the mounts though (Its a copy of the Honda 233 twin, which has the same mounting points as the 125 twin). I had one in my Jinlun 250 and it pulled that bloated lump to a few Mph under 80, in that pushbike you've built I suspect it would be fairly fast.
The last post was made 11 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.91 - MySQL Queries: 13 - Page Size: 92.26 Kb
