Author |
Fladdem |
 Fladdem World Chat Champion
 Posted: 20:13 - 14 Aug 2014 Post subject: Spare Wheels |
Anyone use a set of road wheels and a set of mud wheels?
Just wondering what gets done with running two sets? Do you have two sets of chain and sprockets? Just wondering because I'd imagine you'd run different gear ratios for each application? What about wheel spacers? Two sets of those too?
I'm just compiling a list of stuff to get for my other set of wheels and just wondering if there's anything that needs to be seriously considered. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Back to top |
waffles |
 waffles World Chat Champion
Back to top |
dangerousdave |
 dangerousdave Traffic Copper
Back to top |
Fladdem |
 Posted: 21:14 - 15 Aug 2014 Post subject: |
I've been doing some research and I can run a 14/48 on road and a 13/48 offroad using the same length chain but with the wheel shifted back an extra 5mm. DO you use a separate chain for each sprocket kit? Or would I use the same chain but with two separate sprockets?
Already got new discs on one set, I wasn't going to keep swapping them over as well.
Wasn't going to go oversized front disk route anyway, I don't really ever feel the need for stronger brakes anyway, it would be nice I suppose but not necessary. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
Back to top |
G |
 G The Voice of Reason
Back to top |
1cyl |
 1cyl World Chat Champion
 Posted: 20:26 - 16 Aug 2014 Post subject: |
Interesting topic.
I do have both 14"/12" Offroad, and 12"/12" SM Mags, for the road going pit bike. As well as all the extra discs, sprockets and spacers to facilitate a relatively swift change over.
However its a bit of a pig because I only have one set of axels and like to use SM sliders . I also have to loosen the front SM disc to get the caliper on/off it . And I've recently been running the following gearing: SM 18/31, Dirt 17/41, which means faffing with flywheel cover/sprocket bolts .
I do however use the same chain, whilst junking the near maxed out adjusters for dirt (as visible), as its tension is perfect theres no adjustment needed. But all in, its about a 1/2hr job.
I'd love to try some offroad wheels on the KTM690 SMC.
My master plan is to buy a newish KTM EXC300 for off-roading, and then see about switching the wheels for a bit *.
*Although, I fear due to the SMC's forks, this may prove difficult, if not impossible .
Have fun OP . Post a vid if you can get a swap done in under 5 minutes . ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Back to top |
Fladdem |
 Posted: 20:52 - 16 Aug 2014 Post subject: |
Standard sized wheels, not going to worry about SM'ing her, it's only a TTR. Just something to save the knobblies while commuting or travelling on her or road rides with mates.
My pit bike has two 12" motard wheels and a 14"/12" combo for mud with a different rear sprocket for each wheel. Same front sprocket for each application and I believe the PO used the same chain for each combo, with the adjusters maxed out on the road set-up. It has discs on each set, same size for each. Problem is the pitbike doesn't have an inner wheel bearing spacer for the rear dirt wheel. FOr conversion on that bike, I reckon about 40 minutes, because I would change to the off-road plastics as well and need to faff about with spacers and now I think about it the dirt sprocket isn't bolted to the dirt wheel so would need to pinch the bolts from road wheel as well.
For TTR, I have same sized discs front and rear for both wheels, just wondering if it's worth getting some spacers for the other set as well. Currently, I need to swap the rear sprocket over from each wheel as well. Again, why I was wondering about another chain and sprocket set. Only swapped over a couple of times once yesterday and again this morning and it's about 40 minutes again, including getting the spacers out of each wheel and swapping sprocket and finding something to hold the front end of the floor as well. Must invest in a stand.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
Back to top |
1cyl |
 Posted: 21:05 - 16 Aug 2014 Post subject: |
MX Jack is a win
Or paddock pair.
I guess its a bit of a ballache on any bike.
If it took less than 10 minutes I'd do it every weekend. So as to enjoy the 180cc on the green lanes (instead of a 110cc) whilst still using it to blitz "my" empty carpark on Wednesday evenings.  ____________________ Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable |
Back to top |
G |
Back to top |
1cyl |
 Posted: 07:13 - 17 Aug 2014 Post subject: |
Seems your absolutely right G, As just found this:https://www.advrider.com/forums/showthread.php?t=936479
Which is interesting, but confirms it to be a headache.
As OP used Exc300 forks, I suppose, if i could be arsed (unlikely) I could swap the entire front ends over maybe. But that still leaves the rear.
Seems spindle size is the same up front but forks need changing and clamps for stability. ____________________ Chase my Witch up, Catch my Snitch up.
Back to top |
The last post was made 11 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
