| dydey90 |
 dydey90 World Chat Champion
| Hetzer |
 Hetzer Super Spammer
| Northern Monkey |
 Northern Monkey World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 10:18 - 17 Aug 2014 Post subject: |
Is the Skyrim original copy or cracked version?
If the R9 has got it's OEM cooler, it should work no matter what. The same applies to the CPU. The only thing, that can go wrong is the PSU not giving it enough power under load.
EDIT: Are you sure you plugged all the power wires into the graphics card?  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| dydey90 |
| RhynoCZ |
| dydey90 |
 Posted: 12:08 - 17 Aug 2014 Post subject: |
I'm using an 850W PSU
Either this one or one that looks a lot like it:
https://www.cclonline.com/product/78083/PSU-711/Power-Supplies/Artic-Blue-850W-Power-Supply-Unit/PSU0326/
Oh, Skyrim is legit actually money paid for version. Got the Elder Scrolls Anthology box set, even though the first two games are so old they're available on freeware and require DOSbox to run. ____________________ This post is probably not serious and shouldn't be taken literally.
| CaNsA |
 CaNsA Super Spammer
| lihp |
 lihp World Chat Champion
| Hetzer |
 Posted: 12:11 - 17 Aug 2014 Post subject: |
Three hours later and have you tested the CPU temp with Prime95 and RealTemp yet? Not much point people trying to help you if you don't eliminate the obvious potential solutions. I mean, how the fuck do voltages come higher on your list of things to check than temps? Especially as you've revealed you're using a crap stock cooler. ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| dydey90 |
| lihp |
| Hetzer |
 Posted: 12:18 - 17 Aug 2014 Post subject: |
And have you drilled enough holes in that case? Because cases are the most critical component in a PC regarding it running correctly.
That and the voltage on a rail in an 850w PSU.
| CaNsA |
 CaNsA Super Spammer
| dydey90 |
| dydey90 |
| lihp |
| Ste |
 Ste Not Work Safe
| CaNsA |
 CaNsA Super Spammer
| dydey90 |
| lihp |
| CaNsA |
 CaNsA Super Spammer
 Posted: 12:35 - 17 Aug 2014 Post subject: |
| RhynoCZ |
 Posted: 12:38 - 17 Aug 2014 Post subject: |
Modern case: Anything that can be fitted with 120x120mm and bigger, fans in the front and back panel, with the PSU mounted on the bottom of the case.
I use Thermaltake M9 VI1000BNS (ancient old and was very cheap) I can fit 3x120x120mm fans in the front panel, 1x120x120 back. If I wanted a new case, I'd get the same but with the PSU mounted on the bottom of the case. I use 2 low speed fans front and 1 low speed fan back, everything runs cool and silent, 8 years now.
EDIT: I'd never get a case with the top mounted fans (holes for them), the PC gets full of dust as it is. Also taking off the side panel won't help the cooling, since you disrupt the airflow in the case. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| lihp |
| CaNsA |
 CaNsA Super Spammer
The last post was made 12 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
