Fuel Additives
tootall
PostPosted: 16:26 - 17 Jan 2005    Post subject: Fuel Additives Reply with quote
Hi, now the colder weather looks set to return I've been thinking about adding a cold weather fuel additive to my tank after someone told me it can greatly reduce engine wear when starting on cold mornings.
Any of you guys do this already/reccommend it?
And more to the point where the hell do you buy it from...can't seem to find it anywhere.
Cheers.
Razz
Rory
PostPosted: 17:03 - 17 Jan 2005    Post subject: Reply with quote
It may not be necessary. The petrol you get from the pump is changed during the year, so that it copes better with the weather conditions. If you want to reduce wear, you could consider using an oil that is thinner at low temperatures.
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
PostPosted: 17:07 - 17 Jan 2005    Post subject: Reply with quote
Not heard of any fuel additives doing that. There are plenty around intended to help prevent carb icing.
What is probably best to do if you are worried about it is to change the oil for the thinner spec stuff that is mentioned in your owners handbook for cold weather.
Robby
Dirty Old Man
PostPosted: 22:34 - 17 Jan 2005    Post subject: Reply with quote
I'd just ride it.
Are you planning on keeping this bike for over 100,000 miles?
If not, the marginal wear difference is best ignored. Metal is tough stuff.
Just warm it up properly and ride it.
PostPosted: 23:47 - 17 Jan 2005    Post subject: Reply with quote
Main purpose of the fuel stabilisors is to stop the petrol going off when stored over the winter.
tootall
PostPosted: 08:31 - 18 Jan 2005    Post subject: Reply with quote
Thanks for this guys.
All useful info.
Thumbs Up Thumbs Up Thumbs Up
map
Mr Calendar
PostPosted: 09:47 - 18 Jan 2005    Post subject: Re: Fuel Additives Reply with quote
tootall wrote:
..thinking about adding a cold weather fuel additive to my tank after someone told me it can greatly reduce engine wear when starting on cold mornings. Razz
From my earlier post on fuel stabilisers Silkolene FST may held reduce engine wear...
MAP wrote:
I 've been told about Silkolene FST but is this just for carb icing or is it a stabiliser as well (stops petrol left in carbs from turning to gunk). The Silkolene site doesn't say it's a stabiliser as such...
Pro FST - Fuel System Treatment for all scooter and motorcycle engines
A fully effective carburettor de-icer which also guards against cold start engine wear and fuel system corrosion. Combats carburettor sticking and jet blocking. Effective in all unleaded and leaded fuels. Suitable for 2 and 4-stroke engines. Also combats minor pre-ignition effects.
HTH Thumbs Up
The last post was made 21 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 55.07 Kb
