| TaeKwon125 |
 TaeKwon125 Borekit Bruiser
 Posted: 09:33 - 20 Aug 2014 Post subject: Coolant query for Hornet |
So I checked my 1998 Honda Hornet's coolant today and it looks a bit like vommit. Mmmmmm......
Safe to say it needs changing.
I have some of this stuff lying around at home, (VW Coolant G12 Plus Plus)
https://c1552172.r72.cf0.rackcdn.com/55650_x800.jpg
Question is, will it be suitable? The Haynes manual says it must be a "Coolant suitable for Aluminum Engines" and I've read something before about a certain type of additive screwing things up so I thought I'd check.
Cheers, O |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:40 - 20 Aug 2014 Post subject: |
Should be fine. What's the specs?
I can't find that exact coolant on google, just another G12 plus plus one, which is fine for non-ferrous metals. ____________________ My Flickr |
| Conzar |
 Conzar World Chat Champion
| TaeKwon125 |
| Wafer_Thin_Ham |
 Posted: 09:55 - 20 Aug 2014 Post subject: |
Should be fine. Aluminium is non-ferrous, and it's for non-ferrous metals. I also doubt it's pure aluminium, it's more likely to be an alloy, and your coolant is fine for that.
If you're worried just buy more. I'd probably just bung it in personally.
If it has to be done tonight and you're worried about it, just train out the vomit and fill with water until you can get some anti-freeze you're happy with. It's not cold enough to freeze pure water outside yet. ____________________ My Flickr |
| Aff |
 Aff World Chat Champion
 Posted: 09:57 - 20 Aug 2014 Post subject: |
IIRC G12 was made because Euro manufacturers (mainly VAG) wanted a coolant with corrosion inhibitors that didn't contain phosphate. Apparently water in Europe has a much higher mineral content than the rest of the world and if you mix them with phosphate they create deposits that will block the system up.
Problem is G12 doesn't mix well with coolant that contains phosphate, so if you want to use it make sure you very thoroughly flush out the old coolant. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| TaeKwon125 |
 Posted: 11:52 - 20 Aug 2014 Post subject: |
Ok cheers for the info, looks like I will be flushing the system through well, mixing it up tonight and giving it a go.  |
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
