I'm an idiot, what might I have damaged?
Wonko The Sane
PostPosted: 13:54 - 22 Aug 2014    Post subject: I'm an idiot, what might I have damaged? Reply with quote
It was going to happen sooner or later, set off with the stand down,
Turned right out of where I'd parked and as I rode over a sunken drainage channel (with metal grid over it) hear a clunking noise which I presume to be the stand coming back up.
anything I should be checking for damage wise?
Stand seems solid, can be pressed down towards the bike when it's down as though there is play in the bolt but I think it's always done this
bike is the ZZR
wots
PostPosted: 13:57 - 22 Aug 2014    Post subject: Reply with quote
Fix the cut-out switch, it's clearly not working.
DrSnoosnoo
PostPosted: 13:58 - 22 Aug 2014    Post subject: Reply with quote
Doesn't the ZZR have the side stand switch to prevent this or have you disabled it?
Make sure the stand hasn't got any cracks in it? If it looks alright it probably is. Make sure the bolt is tight still and ride many miles.
wots
PostPosted: 13:59 - 22 Aug 2014    Post subject: Reply with quote
Buy this, fix two problems
https://www.ebay.co.uk/itm/131271328796
You're lucky. I was expecting to say you crashed...
I doubt there has been any damage, and you've got away with it... Jammy.
PostPosted: 14:04 - 22 Aug 2014    Post subject: Reply with quote
You might have left a nasty mark on the drainage channel. Wink
Maybe worth a quick pitch-inspection of your underpants.
Wonko The Sane
PostPosted: 14:10 - 22 Aug 2014    Post subject: Reply with quote
When the dealer fitted alarm died and was removed the indicator and horn stopped working.
Replacing fuses didn't work as the circuit is built into the fuse box, fixing the indicators and horn has caused the sensor to stop working along with the neutral light.
To fix it would require replacing the fuse box.
blueglue
PostPosted: 14:13 - 22 Aug 2014    Post subject: Reply with quote
Sounds like your dealer needs choking out
Wonko The Sane
PostPosted: 14:33 - 22 Aug 2014    Post subject: Reply with quote
it was the late 90's most bikes were being fitted with alarms at the dealers. No idea which dealer as the bike has had a few owners over the years, Was a laserline system and worked ok until it started to die earlier this year so had it removed.
wots
PostPosted: 14:50 - 22 Aug 2014    Post subject: Reply with quote
Not just then. My ER-6 had an annoying problem when I bought it, clocks would reset after ignition on/off. Tried everything, even new clocks, then went to were I should've gone in the first place. Datatool alarm had clearly been installed by a tool, they had immobilised the power to the ECU (which is fair), but it's the same line to the clocks. It was one of two circuits immobilised, so I just re-connected this one.
baldy
PostPosted: 23:11 - 22 Aug 2014    Post subject: Reply with quote
I left the stand down on my xr400 once and it broke the frame.
One day i will rule the world, just not today.
PostPosted: 23:33 - 22 Aug 2014    Post subject: Reply with quote
Done it quite a few times. Possible it could damage the frame, but pretty unlikely
trevor saxe-coburg-gotha
PostPosted: 04:33 - 23 Aug 2014    Post subject: Reply with quote
Did it on my mod 2 - getting out of the test office car park. Whistle
Not sure why the CBF600 didn't stall when I tried to set off. Although having said that it was a bit of a shitter.
Of course, I thought I'd kicked it up - but it had not gone all the way. A fatal combination of rider error, lack of lubricant where stand meets frame, and tired spring made for insta-fail.
kris84
PostPosted: 13:40 - 24 Aug 2014    Post subject: Reply with quote
Check that you haven't bent the sub-frame. Laughing
CBT April 14, Theory passed May 15, MOD1 passed May 16, MOD2 passed June 16
Custom GS550 chop - Ducati Hyperstrada
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 84.62 Kb
