| Phil D |
 Phil D Two Stroke Sniffer
 Posted: 19:30 - 22 Aug 2014 Post subject: Oxford Lifetime Panniers - WTF? |
All packed up for my euro trip tomorrow with my new second hand oxford lifetime panniers. Just did a trial fit for the first time to my 2001 Hornet and these things are horrendous to fit! Theres absolutely no way i can do it alone (mind you they are fully loaded) but still really difficult.
They have 3 velcro straps, one which goes under the seat and 2 which go over. There are 2 sets of cut outs in the hornets rear cowl which look like they could maybe be there for some sort of strap but the seat definitely doesn't fit if i put the bottom strap any where near them. I managed to get the seat on after much faffing about with the bottom strap in this position:
https://s27.postimg.org/4vguzjlg3/photo_5.jpg
The seat had to be really rammed on with both panniers having the weight taken off them to allow the bottom strap to 'sag' enough i suppose.
Top straps done up:
https://s27.postimg.org/idnrbtxlf/photo_2.jpg
As the older hornets have high exhausts it means the right hand pannier literally sits on it with all its weight. its not even on the bottom pannier more of the inside panel:
https://s27.postimg.org/62ze5i0yb/photo_3.jpg
The exhaust has a heat shield an all but after an 8 hour+ ride is the pannier likely to be plastiwelded to my bike!?
https://s27.postimg.org/3x53azxhv/photo_1.jpg
Finally it comes with 2 little straps on each pannier that don't seem to be there to attach to anything specific, i guess they are just for added security.. the back ones can attach to the grab rail:
https://s27.postimg.org/u41ot7qdv/photo_4.jpg
But there doesn't seem to be anything for the fronts to go on to so I've just taken them off for now |
 Posted: 22:58 - 22 Aug 2014 Post subject: |
You might be interested to hear they never used to come with that middle strap, just the top two. You needed either non-slip matting under them or to have a bag or pillion on top of them to stop them sliding backwards.
How hot does the exhaust heatshield get? Too hot to touch with your bare hand? If it does, I wouldn't be resting the panniers on it without additional protection like some silicone matting or foil-backed pipe insulation.
Also be aware that if they are pushing the exhaust slightly in to the centre of the bike, it can cause the can to foul the tyre slightly at extreme suspension compression. Took me AGES to work out what was causing the stripe round my tyre.
On the plus side, the lifetime warranty doesn't cover the zips so you only need to live with them for two or three years.
Top tip: Don't have them expanded before you leave. Pack less shit. They are as neatly packed as they will be when you leave. Your stuff is going to take up more space as your trip goes on and you will aquire more stuff along the way. Leave room for it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| CieL |
 CieL Brolly Dolly
| CaNsA |
 CaNsA Super Spammer
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 07:23 - 23 Aug 2014 Post subject: |
| stinkwheel wrote: |
Er, since when? If a zip fails, take it back to the supplying dealer. They'll be able to get a credit from Oxford, and so should be happy to replace.
Got the same problem with the strap on my bike, although I'm using a different piece of luggage. Can't get the seat closed with the strap in place, no matter how I fiddle with it. So I just bungee everything on. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| grr666 |
 grr666 Super Spammer
 Posted: 09:36 - 23 Aug 2014 Post subject: |
The hard luggage on my bike makes it quite wide as well.
I can really feel the extra drag at speed with them fitted.
Done plenty of filtering with them on though, they are just slightly further out than my mirrors
so assuming my mirrors fit through comfortably then the boxes should as well. Fingers crossed anyway.
https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/bikerear1noreg_zpsc8b2d6a9.jpg ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.
| arry |
 arry Super Spammer
| Llama-Farmer |
| arry |
 arry Super Spammer
| John933 |
 John933 Crazy Courier
 Posted: 14:44 - 23 Aug 2014 Post subject: |
Don't know if you can do this. But had the same problem with my exhausts. So just got a bracket made up and lowered them. Now bag fit with out touching. I have no idea if you can do the same.
John933 ____________________ My trip |
| Clanger |
 Clanger Stirrer
 Posted: 15:42 - 23 Aug 2014 Post subject: |
One of the reason I bought a bike with low level exhaust is because I go camping and use my soft panniers regularly. The D rings on the luggage is helpful to attach to many areas of the bike, such as rear foot-peg hangers, grab-rail.
I cut off the middle strap and use both the 'top' straps under my Versys seat. You will soon get used to sorting them out on your bike, it just takes a little practice. I also fit the panniers on 'unloaded', then load when on the bike...less hassle.
I've had mine many, many, many, many years now, no issues.  ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
| FrankGill |
 FrankGill Renault 5 Driver
| chickenstrip |
 Posted: 18:43 - 26 Aug 2014 Post subject: |
Honestly, the number of luggage items we bin or put to show stock cos a zip tag has come off! Get the dealer to speak to his rep - those guys'll take anything back! It may be their stated policy not to, but in reality they like to keep the dealers (who like to keep the customers) happy.
If you're (as a BCF member) having problems with this, PM me and I'll see what I can do. It's not usual for me to get involved in this side of things, but if I can help, I will. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
 Posted: 23:55 - 26 Aug 2014 Post subject: |
| chickenstrip wrote: | Honestly, the number of luggage items we bin or put to show stock cos a zip tag has come off! Get the dealer to speak to his rep - those guys'll take anything back! It may be their stated policy not to, but in reality they like to keep the dealers (who like to keep the customers) happy.
If you're (as a BCF member) having problems with this, PM me and I'll see what I can do. It's not usual for me to get involved in this side of things, but if I can help, I will. |
In fairness, I didn't pay full price for them because the shop selling them was closing down. When they die, they are getting replaced by something that is both waterproof and zipless. Probably ortleib. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c_dug |
 c_dug Super Spammer
The last post was made 12 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
