Oxford Lifetime Panniers - WTF?
Phil D
PostPosted: 19:30 - 22 Aug 2014    Post subject: Oxford Lifetime Panniers - WTF? Reply with quote
All packed up for my euro trip tomorrow with my new second hand oxford lifetime panniers. Just did a trial fit for the first time to my 2001 Hornet and these things are horrendous to fit! Theres absolutely no way i can do it alone (mind you they are fully loaded) but still really difficult.
They have 3 velcro straps, one which goes under the seat and 2 which go over. There are 2 sets of cut outs in the hornets rear cowl which look like they could maybe be there for some sort of strap but the seat definitely doesn't fit if i put the bottom strap any where near them. I managed to get the seat on after much faffing about with the bottom strap in this position:
https://s27.postimg.org/4vguzjlg3/photo_5.jpg
The seat had to be really rammed on with both panniers having the weight taken off them to allow the bottom strap to 'sag' enough i suppose.
Top straps done up:
https://s27.postimg.org/idnrbtxlf/photo_2.jpg
As the older hornets have high exhausts it means the right hand pannier literally sits on it with all its weight. its not even on the bottom pannier more of the inside panel:
https://s27.postimg.org/62ze5i0yb/photo_3.jpg
The exhaust has a heat shield an all but after an 8 hour+ ride is the pannier likely to be plastiwelded to my bike!?
https://s27.postimg.org/3x53azxhv/photo_1.jpg
Finally it comes with 2 little straps on each pannier that don't seem to be there to attach to anything specific, i guess they are just for added security.. the back ones can attach to the grab rail:
https://s27.postimg.org/u41ot7qdv/photo_4.jpg
But there doesn't seem to be anything for the fronts to go on to so I've just taken them off for now
PostPosted: 22:58 - 22 Aug 2014    Post subject: Reply with quote
You might be interested to hear they never used to come with that middle strap, just the top two. You needed either non-slip matting under them or to have a bag or pillion on top of them to stop them sliding backwards.
How hot does the exhaust heatshield get? Too hot to touch with your bare hand? If it does, I wouldn't be resting the panniers on it without additional protection like some silicone matting or foil-backed pipe insulation.
Also be aware that if they are pushing the exhaust slightly in to the centre of the bike, it can cause the can to foul the tyre slightly at extreme suspension compression. Took me AGES to work out what was causing the stripe round my tyre.
On the plus side, the lifetime warranty doesn't cover the zips so you only need to live with them for two or three years.
Top tip: Don't have them expanded before you leave. Pack less shit. They are as neatly packed as they will be when you leave. Your stuff is going to take up more space as your trip goes on and you will aquire more stuff along the way. Leave room for it.
Llama-Farmer
PostPosted: 00:17 - 23 Aug 2014    Post subject: Reply with quote
I considered getting some Oxford X50 panniers for my Hornet, so went down to the local bike shop and trial fitted some.
It took both me and one of the showroom guys about 30 minutes to fit empty panniers to the bike so that the seat would refit and lock in place.
Even then it meant the pannier was sat on the exhaust, but that would be ok in my case because the zaust is a Micron carbon one which doesn't even get as warm as your average greggs sausage roll when running. Infact on the day the exhaust was hot but only because of the direct sunlight.
In the end I decided not to buy them, but haven't completely written off the idea. Will be interested to hear what you say about them after the trip.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
CieL
PostPosted: 00:53 - 23 Aug 2014    Post subject: Re: Oxford Lifetime Panniers - WTF? Reply with quote
Phil D wrote:
Damn, that is so wide... Shocked Good luck with that on such a long trip, I just hope you won't forget you have them there from time to time like I used to...or this guy Rolling Eyes
https://25.media.tumblr.com/3f27f20e3b264cf454ea4dff8d32c8f9/tumblr_mo4xp43Jyp1s02vreo1_400.gif
Semper Paratus
CaNsA
PostPosted: 01:35 - 23 Aug 2014    Post subject: Reply with quote
You see all those plastic loops on the panniers?
Use a bungee to pull the panniers together.
chickenstrip
PostPosted: 07:23 - 23 Aug 2014    Post subject: Reply with quote
Er, since when? If a zip fails, take it back to the supplying dealer. They'll be able to get a credit from Oxford, and so should be happy to replace.
Got the same problem with the strap on my bike, although I'm using a different piece of luggage. Can't get the seat closed with the strap in place, no matter how I fiddle with it. So I just bungee everything on.
grr666
PostPosted: 09:36 - 23 Aug 2014    Post subject: Reply with quote
The hard luggage on my bike makes it quite wide as well.
I can really feel the extra drag at speed with them fitted.
Done plenty of filtering with them on though, they are just slightly further out than my mirrors
so assuming my mirrors fit through comfortably then the boxes should as well. Fingers crossed anyway. Laughing
https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/bikerear1noreg_zpsc8b2d6a9.jpg
arry
PostPosted: 10:08 - 23 Aug 2014    Post subject: Reply with quote
Yup ^ Having the panniers on makes such a difference to the ride
OP - a mate of mine made up custom heat shields for the sides of his R1, so that he could run those panniers. I have no doubts whatsoever the exhaust would have melted them
https://i283.photobucket.com/albums/kk301/arryR32/10525642_703641453062970_5016713752846869303_n_zps741e219f.jpg
Llama-Farmer
PostPosted: 10:28 - 23 Aug 2014    Post subject: Reply with quote
^^ Do they support the weight of the pannier as well?
arry
PostPosted: 12:15 - 23 Aug 2014    Post subject: Reply with quote
Not particularly no. They're quite sturdy as they're tied up to the passenger foot pegs but they were only designed to ensure the bags didn't touch the exhaust rather than hold them outwards on any particular angle
John933
PostPosted: 14:44 - 23 Aug 2014    Post subject: Reply with quote
Don't know if you can do this. But had the same problem with my exhausts. So just got a bracket made up and lowered them. Now bag fit with out touching. I have no idea if you can do the same.
John933
My trip
Clanger
Stirrer
PostPosted: 15:42 - 23 Aug 2014    Post subject: Reply with quote
One of the reason I bought a bike with low level exhaust is because I go camping and use my soft panniers regularly. The D rings on the luggage is helpful to attach to many areas of the bike, such as rear foot-peg hangers, grab-rail.
I cut off the middle strap and use both the 'top' straps under my Versys seat. You will soon get used to sorting them out on your bike, it just takes a little practice. I also fit the panniers on 'unloaded', then load when on the bike...less hassle.
I've had mine many, many, many, many years now, no issues. Thumbs Up
FrankGill
PostPosted: 11:38 - 25 Aug 2014    Post subject: Oxford Panniers Reply with quote
The Missus and I use Oxford panniers, never use the strap under the seat, as stated if you use some of the non slip mat and have other stuff strapped on top or pillion I never have a problem. The Wife also sewed on a cheap oven glove where the pannier might come into contact with the exhaust. I will admit you have to be inventive with all the bungees to secure them to the bike. we have done several long trip's and weekends using them over the last 4yrs and for the price cannot fault them.
PostPosted: 12:22 - 26 Aug 2014    Post subject: Reply with quote
Any of our luggage that carries the Lifetime logo is guaranteed against manufacturing faults or flaws for LIFE! This guarantee covers everything except ancillary parts such as zip tags (not the zips themselves), buckles and raincovers which all carry our standard 12-month warranty.
Tried doing up a zip without a tag on it? That's why my last lot went in the bin. First the tag itself came off and I put a cable tie through the loop, then the loop came off the slider and it was useless. Happened to all four zips. The tags have gone on Mrs stinkwheels ones now, just a matter of time...
https://www.oxprod.com/index.php?pg=67
chickenstrip
PostPosted: 18:43 - 26 Aug 2014    Post subject: Reply with quote
Honestly, the number of luggage items we bin or put to show stock cos a zip tag has come off! Get the dealer to speak to his rep - those guys'll take anything back! It may be their stated policy not to, but in reality they like to keep the dealers (who like to keep the customers) happy.
If you're (as a BCF member) having problems with this, PM me and I'll see what I can do. It's not usual for me to get involved in this side of things, but if I can help, I will.
PostPosted: 23:55 - 26 Aug 2014    Post subject: Reply with quote
In fairness, I didn't pay full price for them because the shop selling them was closing down. When they die, they are getting replaced by something that is both waterproof and zipless. Probably ortleib.
c_dug
PostPosted: 08:49 - 27 Aug 2014    Post subject: Reply with quote
You threw away bags because of a broken zip tag?!?
Never heard of keyring loops? Perfect replacement.
Op, if I had bags resting on the exhaust like that and needed a short notice fix, the oven gloves would soon need replacing.
PostPosted: 09:21 - 27 Aug 2014    Post subject: Reply with quote
As I said, I used a small cable tie until the loop came off too. Then they're bucket fodder because those are relatively stiff zips and I get fed up with having sharp pieces of metal shoved up under my fingernails trying to open and close them.
The last post was made 12 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 108.1 Kb
