| Rncv |
 Rncv Nitrous Nuisance
 Posted: 20:43 - 24 Aug 2014 Post subject: NSR 125 Piston sizes |
Hi,
Currently rebuilding a Honda NSR 125 for my cousin. I've got the engine apart here and I'm looking to order a new piston.
I've read different stories in different places about what size piston ect ect.
There are 5 different pistons to choose from, A B C D & E.
This corresponds to a letter stamped on the barrel. I guess that the barrel I have is a D type by what is stamped below the exhaust port?
https://i61.tinypic.com/10xr1o1.jpg
If this is the case, when ordering pistons through wemoto they only offer a 54mm and oversized ones which doesn't correspond with the 53.961mm for a D type
Any help would be much appreciated!  ____________________ Current: 01' Bandit 600, 92' Goose 350
Previous: Lots! |
| Kickstart |
 Kickstart The Oracle
 Posted: 20:59 - 24 Aug 2014 Post subject: |
The piston sizes Honda list are for accurate clearance. Wemoto are listing over size pistons (which is a bit strange as the NSR has a plated bore so cannot be rebored, unless modified with a steel liner fitted). All the sizes Honda list are equivalent to the standard piston size (ie, aftermarket they are not caring about the exact clearance).
| Rncv |
| Kickstart |
| alains |
 alains World Chat Champion
 Posted: 10:01 - 26 Aug 2014 Post subject: |
go to https://www.davidsilverspares.co.uk
they have all you need to rebuild your top-end
piston D ref : 13104 KY4 901 (~£40)
i've got all spares refs , if you need it send me a pm
with it you need : rings,piston pin,clips,small end bearing,oil seal(valves shaft),base cylinder seal,head gasket ____________________ the worst day fishing is better than the best day working |
The last post was made 11 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
