suzuki gs 125cc starts then doesn't
cousolfc
PostPosted: 22:48 - 24 Aug 2014    Post subject: suzuki gs 125cc starts then doesn't Reply with quote
I have a 1998 or 99 suzuki gs125es its had a brand new batter, starter solanoid and spark plug, but if I go out for say an hour when I go back to go out it wont turn on all other electricals work (lights, horn indicators) does anybody kniw what the problem may be? Im thinking the wiring
Efes123
PostPosted: 08:49 - 25 Aug 2014    Post subject: Reply with quote
sounds like a good guess Thumbs Up Does it happen every time?
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
cousolfc
PostPosted: 09:47 - 25 Aug 2014    Post subject: Reply with quote
Yeah went for a long ride cut out 10 miles from home came back on after like an hour of pushing, day after started first time went to shop and I little ride round my area, wouldnt start again, went out yesterday for 30 mins since then its not been back on, haven't tried this morning
Efes123
PostPosted: 10:10 - 25 Aug 2014    Post subject: Reply with quote
If it happens every single time, then it's prolly not wiring. Something is expanding with the heat and causing a problem. Struggling to think of anything Crying or Very sad starter motor Question
Does it try to start?
cousolfc
PostPosted: 10:21 - 25 Aug 2014    Post subject: Reply with quote
If I go to bump it I get some noise otherwise no nothing
cousolfc
PostPosted: 10:22 - 25 Aug 2014    Post subject: Reply with quote
Gunna read starter motor section in manual now
cousolfc
PostPosted: 12:41 - 25 Aug 2014    Post subject: Reply with quote
now no electricals are working and the bike hasn't started today. indicators worker when I tried horn it all stopped
Efes123
PostPosted: 12:59 - 25 Aug 2014    Post subject: Reply with quote
A real strange one this Crying or Very sad
I know you said a new battery, but have you put a meter on it? It might be that your rec/reg is frying it, but then I wouldn't have expected it to start the next day.
I'd start from basics again. Get a meter on each point.
cousolfc
PostPosted: 13:16 - 25 Aug 2014    Post subject: Reply with quote
what do you mean by meter on each part
Efes123
PostPosted: 17:19 - 25 Aug 2014    Post subject: Reply with quote
A multimeter Smile Check the rate across the battery, solenoid, starter motor. Check you're getting a strong spark from your plug. Have you got a kill switch on that bike? I had one that was slightly corroded so it drained the charge on starting
cousolfc
PostPosted: 14:04 - 31 Aug 2014    Post subject: Reply with quote
it does have a kill switch yeah think that could be the problem tbh, wiring loom comes tomorrow going to change it all then ill have a look at the kill switch whilst doing it as I have a spare front brakr lecer which has the starter button and kill switch ill check that one and use thw best one thank you.
MattWadz
PostPosted: 14:43 - 31 Aug 2014    Post subject: Reply with quote
Could have a shitty earth somewhere, possibly losing an earth or something on the killswitch? happened to my friends bike his killswitch was playing up and it took him ages to work it out as when he held it in a certain position the bike would start, then on or off it would die Razz
Not sure how much use that is to you though Razz
Check your earths and a general visual/continuity check if youve got a multi meter? be really handy to get one if you havent got one, can get them dirt cheap too Smile
Karma Thumbs Up
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
nowhere.elysium
The Pork Lord
PostPosted: 14:58 - 31 Aug 2014    Post subject: Reply with quote
When you try and start it the second time, does the engine turn over, but not 'catch'? If so, then I'd be looking at coil breakdown - when a dying coil gets hot, it often won't generate a spark.
cousolfc
PostPosted: 18:10 - 31 Aug 2014    Post subject: Reply with quote
got 70 miles out of her today not had the usual problem. since I first postedd this thread today was the first time it worked seems to feel smoother. but its had no work done to it which I don't understand. gunna order the multi meter tomorrow or buy one from somewhere. when Ichange the wiring loom tomorrow ill check the earths, as a friend told me it could be a dodgy earth. don't get why somedays its perfect some days its not and some it won't start
Nick 50
PostPosted: 19:03 - 31 Aug 2014    Post subject: Reply with quote
This may sound incredibly stupid at first, but bear with.
I had a GZ, and the wrong bolt was in the clutch lever. When I pulled in the clutch lever, sometimes it wouldn't push the switch in fully and the bike wouldn't start for love nor money. It took a while to diagnose. Once the correct bolt was in never had the problem again.
So might be something to quickly check and check the clutch switch pin too.
cousolfc
PostPosted: 19:07 - 31 Aug 2014    Post subject: Reply with quote
wel tbh nick the bike has quite a few dodgy bolts so I will definitely be checking them.
Nick 50
PostPosted: 06:58 - 02 Sep 2014    Post subject: Reply with quote
Have you managed to get anywhere with the bike?
cousolfc
PostPosted: 13:54 - 02 Sep 2014    Post subject: Reply with quote
Iv manged 209 miles now not had the problem which I dont understand at all, still waiting for it to stop working.
_Chris_
PostPosted: 19:37 - 04 Sep 2014    Post subject: Reply with quote
Just in case it comes back... there are a few 'safety' features on this bike that could play-up - check the switches for:
1 - The clutch lever must be fully in to start the bike
2 - The kick-stand must be fully up if the bike is in gear (if you put the kickstand down before going into neutral while parking the engine cuts out)
3 - Kill switch
Just getting started
cousolfc
PostPosted: 22:37 - 04 Sep 2014    Post subject: Reply with quote
I think I sussed the problem, the bike has a switch to turn the fuel o, off or reserve im thinking I had that on off not sure but no problem has occured again still waiting to put the loom in but iv manged 300 miles now without a problem. Thanksfor all yyour help guys
Dan100tdi
PostPosted: 23:41 - 04 Sep 2014    Post subject: Reply with quote
Embarassed
The last post was made 11 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 110.06 Kb
