Varadero 125 rejetting
Varadero mikki
PostPosted: 13:32 - 25 Aug 2014    Post subject: Varadero 125 rejetting Reply with quote
hi
i have a honda varadero 125 v1, My exhaust rotted out, and my air filter had a hole init, so in my haste. I went out and got a venom full exhaust and a performance air filter. i have tried for weeks to get the carb set right but its having non of it. i can get it close but its still not how it was, i have been told it needs bigger main jets, so i have striped the carbs down and took out the main jets for the sizes. Mine has *82* in the front and *88* in the rear carb.
i have found new jets but i dont have a clue what sizes to replace the original ones as there are 25 different sizes. here's a link to show you guys
Honda XL 125 V1 Varadero 01 Carburettor - Main Jet Parts at Wemoto - The UK's No.1 On-Line Motorcycle Parts Retailer
if some one could help that would be great thanks
davebike
PostPosted: 15:18 - 25 Aug 2014    Post subject: Reply with quote
To do it properly you either need a Wide Band fuel air meter weld a fitting for the lamda senser into each down pipe and adjust each by guesswork / trial and error with lots of test rides with the test set up fitted
The WBFA meter is about £150 and a jet kit £100
Or take the bike to a Dyno centre and pay them to do it on the rolling road
about £250 possibly more
Dave
NC750Xdct + others at work !
[email protected]
Varadero mikki
PostPosted: 15:28 - 25 Aug 2014    Post subject: Reply with quote
There's no lamda sensor's on this model. And every kit requires drilling the carbs, which I am not a fan of doing, I have an air flow meter and know how to set the carbs up I just don't know what size of jet to replace the original ones.
davebike
PostPosted: 15:36 - 25 Aug 2014    Post subject: Reply with quote
No read what I wrote the lamda senser comes with the WBFAM kit
so you can tell how far out you cheap crap has put the fuelling
Smile)
Dave
[email protected]
Taught2BCauti...
PostPosted: 16:13 - 25 Aug 2014    Post subject: Reply with quote
Stick to the original jets - 82 front and 88 rear. Many people have tried to re-jet the Vara 125 carbs, but the original spec works best.
You also need to make sure the needle valves are the right way around too - front is marked "C12A", rear is marked "C12B" (if you don't stick to the original jet sizes, you will also need new needle valves to suit).
When setting up the carbs with a vacuum gauge, the rear cylinder needs to be setup 30mmHg (1.18"Hg) lower than the front at 1500 rpm.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
smegballs
PostPosted: 16:26 - 25 Aug 2014    Post subject: Reply with quote
Just do some plug chops OP and try to dial it in that way.
I tried to improve jetting on various bikes in the past, but always made it worse that stock, and never had the patience for a billion plug chops and incremental dialling in.
As such I'm now a firm believer in keeping shit to stock specs and trusting in the nice folks in the R&D department who doubtless invested far more time and effort into said engines fuelling than I ever would.
iooi
PostPosted: 17:15 - 25 Aug 2014    Post subject: Re: Varadero 125 rejetting Reply with quote
Who by?
I would contact Motad and see what they recommend.
motad_uk
PostPosted: 10:42 - 04 Sep 2014    Post subject: Reply with quote
you have bought sensibly and bought from the uk- contact us and we will help!
01922 714700
with db eaters fitted the system is designed to run with standard jets
anyone trying to sell you a system that needs jetting or dyno work before using it is not selling you a road legal system or indeed a system that has been designed properly or at all
am always wary of "performance" air filters- if its one that takes off the original air box- my immediate recommendation is to refit the air box
[email protected] www.motad.co.uk
see us on Facebook at Motad Ltd
bladerunner
PostPosted: 02:44 - 06 Sep 2014    Post subject: Reply with quote
Old rule of thumb was if removing the airbox a 10% bigger main jet was a good starting point. With your setup I'd suggest just trying a single size bigger on each carb and see how you get on.the most important thing before you start rejetting /changing needle clip position and or air screw settings....is do one thing at a time and test it.
wr6133
PostPosted: 09:38 - 06 Sep 2014    Post subject: Reply with quote
The filter will have added more air to the mix making you run lean. To fix that you add more fuel by upjetting.
It's a fiddly boring process so if you can put the airbox back on.
If not then buy the size up, the 2 sizes up and three sizes up. Start with the size up and plug chop. If that's still lean then next one..... repeat until the mix is right
Are you honestly suggesting anyone rejetting a 125 needs to buy all that crap or spend that much?
Do you sell these things or offer those services or something?
motad_uk
PostPosted: 15:16 - 11 Sep 2014    Post subject: Reply with quote
you do not need to rejet when fitting a Motad (or Venom ) system
my suggestion to refit the standard air box and filter and all will be well
there are several exhaust suppliers suggesting that dyno work, re-tuning etc is required after fitting- in my experience that is purely because of poor (or no) design and development on the bike!
iooi
PostPosted: 18:56 - 12 Sep 2014    Post subject: Reply with quote
Sad, but par for the course that the OP has not come back with a update....
Guess advice was not what was wanted. As we all know non std airbox is about the same as a skybluepink powerband Laughing
motad_uk
PostPosted: 15:02 - 15 Sep 2014    Post subject: Reply with quote
at least a skybluepink powerband looks colourfull!
taking off the standard airbox without loads of knowledge and testing is just bad
stevo as b4
PostPosted: 19:28 - 15 Sep 2014    Post subject: Reply with quote
I don't think a lack of a std airbox is the evil work of satan that some people make it out to be. Yes carburation on many modern bikes will be totally screwed up, but that's what jet kits, and dyno time with a skilled operator/engine tuner are for.
As long as your not using very small and crap pod filters or squashed up against the frame rails foam filters, then sorting out a filterless bike can be done with enough work and hassle.
Big Ol air cooled naked four's look pretty good sometimes with huge open polished bell mouths. I know that people have tuned such bikes to carburate well by spending a lot of time on set up and use of a dyno.
BSD for example has set up many such bikes to run really well, but you have to expect some fairly major carburation changes and parts swapping to get a near ideal set up with an open intake.
Scootaloo
PostPosted: 03:11 - 05 Nov 2014    Post subject: Reply with quote
Most helpful, all the info needed here! Got a carb tune arriving tomorrow in the post so this will be helpful.
Where do the hoses connect on the carb though?
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
qarka
PostPosted: 09:02 - 05 Nov 2014    Post subject: Reply with quote
They usually connect on the inlet ports of the engine head itself. Below the carbs and on the actual engine. Depending on the bike you will have 4 blanking bolts/ 4 nipples or a mixture. The carb tune might come with nipples you can use.
https://www.thestraycat.net/images/Farkles/3&4_ports.jpg
The last post was made 11 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 90.48 Kb
