| Varadero mikki |
 Varadero mikki L Plate Warrior
| davebike |
 davebike World Chat Champion
 Posted: 15:18 - 25 Aug 2014 Post subject: |
To do it properly you either need a Wide Band fuel air meter weld a fitting for the lamda senser into each down pipe and adjust each by guesswork / trial and error with lots of test rides with the test set up fitted
The WBFA meter is about £150 and a jet kit £100
Or take the bike to a Dyno centre and pay them to do it on the rolling road
about £250 possibly more ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Varadero mikki |
| davebike |
 Posted: 15:36 - 25 Aug 2014 Post subject: |
No read what I wrote the lamda senser comes with the WBFAM kit
so you can tell how far out you cheap crap has put the fuelling
) ____________________ Dave
[email protected] |
| Taught2BCauti... |
 Posted: 16:13 - 25 Aug 2014 Post subject: |
Stick to the original jets - 82 front and 88 rear. Many people have tried to re-jet the Vara 125 carbs, but the original spec works best.
You also need to make sure the needle valves are the right way around too - front is marked "C12A", rear is marked "C12B" (if you don't stick to the original jet sizes, you will also need new needle valves to suit).
When setting up the carbs with a vacuum gauge, the rear cylinder needs to be setup 30mmHg (1.18"Hg) lower than the front at 1500 rpm. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| smegballs |
 smegballs World Chat Champion
| iooi |
 iooi Super Spammer
| motad_uk |
 motad_uk Nitrous Nuisance
 Posted: 10:42 - 04 Sep 2014 Post subject: |
you have bought sensibly and bought from the uk- contact us and we will help!
01922 714700
with db eaters fitted the system is designed to run with standard jets
anyone trying to sell you a system that needs jetting or dyno work before using it is not selling you a road legal system or indeed a system that has been designed properly or at all
am always wary of "performance" air filters- if its one that takes off the original air box- my immediate recommendation is to refit the air box ____________________ [email protected] www.motad.co.uk
see us on Facebook at Motad Ltd |
| bladerunner |
| wr6133 |
 wr6133 World Chat Champion
| motad_uk |
 Posted: 15:16 - 11 Sep 2014 Post subject: |
you do not need to rejet when fitting a Motad (or Venom ) system
my suggestion to refit the standard air box and filter and all will be well
there are several exhaust suppliers suggesting that dyno work, re-tuning etc is required after fitting- in my experience that is purely because of poor (or no) design and development on the bike! ____________________ [email protected] www.motad.co.uk
| iooi |
 iooi Super Spammer
 Posted: 18:56 - 12 Sep 2014 Post subject: |
Sad, but par for the course that the OP has not come back with a update....
Guess advice was not what was wanted. As we all know non std airbox is about the same as a skybluepink powerband  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| motad_uk |
 Posted: 15:02 - 15 Sep 2014 Post subject: |
at least a skybluepink powerband looks colourfull!
taking off the standard airbox without loads of knowledge and testing is just bad ____________________ [email protected] www.motad.co.uk
| stevo as b4 |
| Scootaloo |
 Scootaloo Could Be A Chat Bot
| qarka |
 qarka Spanner Monkey
 Posted: 09:02 - 05 Nov 2014 Post subject: |
They usually connect on the inlet ports of the engine head itself. Below the carbs and on the actual engine. Depending on the bike you will have 4 blanking bolts/ 4 nipples or a mixture. The carb tune might come with nipples you can use.
https://www.thestraycat.net/images/Farkles/3&4_ports.jpg ____________________ Previous - Sinnis Apache - Honda Bros 400 - Yamaha SR500 - Honda Transalp - Kawasaki ZX-7R - Honda CB-1 - Honda 929 Fireblade - Honda NTV650 [b]Current[\b] Honda CB500 |
The last post was made 11 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
