brake pad springs
stranger12
PostPosted: 08:19 - 26 Aug 2014    Post subject: brake pad springs Reply with quote
Hi All,
I have changed my brake pads and confused which way should the spring be placed on the back of the pds.
it has an arrow pointing up on the spring or metal peice as per the picture but no arrows or anything on the calipers.
so I checked it and it seems to fit both way .
I went with the arrow pointing up toward the top of the caliper.
can someone please advice what is the job of the metal peice and which way it should be fit in ?
if done wrong , can it have a fatal result ?
https://i57.tinypic.com/10rvevc.jpg
https://i59.tinypic.com/10nxs8o.jpg
many thanks
SV650 Red
R6 Red
Aff
PostPosted: 09:04 - 26 Aug 2014    Post subject: Reply with quote
The arrow points the direction of wheel rotation.
Electric Bike Project
Taught2BCauti...
The pads shouldn't be a tight fit in the caliper and the pin(s) will hold them securely. The spring is there to stop them rattling and chattering when braking.
If it physically fits either way, then it probably doesn't matter - but arrows usually point upwards, forwards, or in the direction of rotation.
Hope this helps, but see if there's a YouTube vid for someone doing the job on your model of bike, or get it checked with a dealer.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
stranger12
PostPosted: 19:07 - 26 Aug 2014    Post subject: Reply with quote
many thanks , that makes sense.
I think I have been a bit paranoid about this, when I roll the bike I can hear a rubbing sound which is not a stock caliper or anything but always there as if the pads are stuck to the disc .
the disc doesn't get hot and the sound doesn't slow the bike down but there.
it is sort of like when you leave the bike for few weeks and when you get on it again and move it, it makes the rubbing sound or whatever it is called.
how can I eliminate it all together.
I have taken the caliper out, pushed the pistons in and then put back on.
as soon as I brake 1nce or twice with bike standing the rubbing sound comes back in
SV650 Red
R6 Red
Aff
PostPosted: 19:32 - 26 Aug 2014    Post subject: Reply with quote
A certain amount of rub is normal.
Lift the bike up and give the wheel a spin. If it does 1 full rotation or more before stopping then it's nothing to worry about.
stranger12
PostPosted: 19:58 - 26 Aug 2014    Post subject: Reply with quote
it does about two rotations
SV650 Red
R6 Red
Aff
PostPosted: 20:04 - 26 Aug 2014    Post subject: Reply with quote
Don't worry about it then.
Taught2BCauti...
PostPosted: 20:07 - 26 Aug 2014    Post subject: Reply with quote
You could try a slight chamfer on the edges of each pad, but you probably won't ever get it noise-free for any length of time as the disc will amplify the smallest sound.
The last post was made 11 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 57.39 Kb
