| FLV |
 FLV Trackday Trickster
| wots |
 wots World Chat Champion
 Posted: 08:36 - 27 Aug 2014 Post subject: |
Full loom's are cheap on ebay, I nearly replaced my RR-W loom when the wires into my starter relay fried. I was able to repair it. The repair cost me about 20 quid, looms started at that. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| Taught2BCauti... |
 Posted: 09:15 - 27 Aug 2014 Post subject: |
If everything is working and safe, you can use cable-ties to secure everything to the frame - but use 6mm or wider ties or they could cut through the harness under vibration.
If there is a potential for rubbing, you can use extra insulating tape on the harness, or self-adhesive foam strips on the frame.
I'm pretty sure the fuse box should be secured - either by screws or by snapping into a recess.
Move the handlebars from stop to stop to make sure nothing is getting stretched.
If you have some parts of the harness where water ingress might be a problem, use self-amalgamating tape or heat-shrink tubing.
Another tip for complex re-wiring jobs - get some of those plant marker strips from the garden centre, and use a Sharpie to label the sections that branch off, and cable-tie them in place. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Minty |
 Minty World Chat Champion
| FLV |
 Posted: 12:40 - 27 Aug 2014 Post subject: |
I think I'll invest in some crimping kit and have a go at tidying it up and securing it.
I'll pop the fairings off and have a half decent go at it.
It's oil change and rear brake pads time so plenty of facing to do.
Thanks all  ____________________ parp...brap....parp |
| stickybackbob |
 stickybackbob Trackday Trickster
| FLV |
| m3-paul |
 m3-paul Spanner Monkey
 Posted: 15:22 - 28 Aug 2014 Post subject: |
The last post was made 11 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
