FLIP UP PLATES
V4
PostPosted: 00:44 - 18 Jan 2005    Post subject: FLIP UP PLATES Reply with quote
These flip up number plate brackets, will it fit my VFR400? I'm going to the London show later this month and i'll pick one up there if i can, any body know how they work? How much they are? If they affect rear indicator mounting etc? cheers
LEON
Silver
PostPosted: 00:51 - 18 Jan 2005    Post subject: Reply with quote
I think they're illegal to sell now.
instigator
PostPosted: 00:56 - 18 Jan 2005    Post subject: Reply with quote
Wouldnt exaclty be hard to make yourself...although you may screw the back of your bike up if you make a mistake
PostPosted: 02:14 - 18 Jan 2005    Post subject: Reply with quote
I used to have plate spinner thing, it was an power valve motor with the plate on the end of it. It was mounted under the pillion seat in front of the rear light and had a switch on the end of a long wire to spin it.
Looked a lot more normal the plate flippers, unless you looked closely or under the pillion seat it looked pretty much normal.
Shaun
Likes 'em bent
PostPosted: 06:10 - 18 Jan 2005    Post subject: Reply with quote
I am now in posession of it, haven't actually got round to using it yet though tempted to put it on ebay and see what it goes for. High;y doubt you will find one at a bike show either.
Motkram
PostPosted: 07:00 - 18 Jan 2005    Post subject: Reply with quote
They will fit anything pal, take a while to do a nice job though. I expect the constabulary would hold a pretty dim view of it, and give you a ticket in lieu!
It's probably one of these things that is'nt illegal unless you are actually (seen) using it?
Part-time GSXR1000 pilot>Micron Serpert system+K&N, PC111, Sigma slipper clutch, Brembo m/c+Galfer discs, Gilles rearsets, Translogic Quickshifter.
GP125>GSF400>VFR400NC30>YZF600R>YZFR1(1998)+KLR250>YZFR1(2003)>CBR900RRY>YZFR1(2002)>GSXR1000K1+RGV250
kasandrich
PostPosted: 11:39 - 18 Jan 2005    Post subject: Reply with quote
I can't see that the device is illegal, just using it on the road, there are plenty of legitimate uses, such as, switching over to "show plates" at a show, or photo session, track use etc.
Richard
CBR1000FM
PostPosted: 23:50 - 18 Jan 2005    Post subject: Reply with quote
I don't think you'd be very likely to manage to get away with a plate flipper claiming it was for shows or track use. They could ask for proof of either of those and you'd most likely be quite fucked then, and they'd just notice your illegal exhaust, race can, the speed and everything else they can do you for.
The ones which mount under the seat are good as you can't see that it's there unless you remove the seat and it just looks normal until you spin it. Get caught with any of them especially if they've seen you use it and you've fucked.
tatters
Exxon Valdez
PostPosted: 00:02 - 19 Jan 2005    Post subject: Reply with quote
one of these are the most advanged method
https://www.users.freenetname.co.uk/~trap/fliptip.htm
PostPosted: 00:25 - 19 Jan 2005    Post subject: Reply with quote
They also have the advantage of being blindingly obvious. Confused
Dr Nick
PostPosted: 00:53 - 19 Jan 2005    Post subject: Reply with quote
If you cant find one to buy anywhere, make one yourself, mate of mine made one with a doorhinge and an old servo, hes using it on a marsbar sized numberplate though, not sure about how well it would work with standard size plates.
is that it
Ricey
PostPosted: 01:04 - 19 Jan 2005    Post subject: Reply with quote
My dad's mate used to have a ZXR400 with a plate that flipped up when he pulled it onto full throttle. Not 100% how it worked but I was younger and I was amazed.
Davo
Davo To The Rescue!
PostPosted: 01:21 - 19 Jan 2005    Post subject: Reply with quote
I would imagine they would charge you with attempting to pervert the course of justice, if they class it the same as those number plate white out devices.
Ricey
PostPosted: 01:38 - 19 Jan 2005    Post subject: Reply with quote
Suppose only thing would be good for is speed cameras??
PostPosted: 01:52 - 19 Jan 2005    Post subject: Reply with quote
I'd rather it was just a switch rather than connected to when you did something like full throttle.
If you wanted to be very cleaver, you'd hook one up to a GPS listing of all fixed spot gatsos in the country and to a radar & laser detector. When you're coming up to a gatso or it detects something spin your plate (if you have it switched on, also have an override switch). Smile
Ricey
PostPosted: 02:19 - 19 Jan 2005    Post subject: Reply with quote
I think you have yourself a good idea there Ste patient it and get someone to make it.
binge
Emo Kiddy
PostPosted: 03:05 - 19 Jan 2005    Post subject: Reply with quote
Hehe!
That picture up there ^^^^
Its well obvious Laughing
Easy to do...
Cut ur current number plate in half
Hing from BEHIND
Connect a high torque RC servo up to the back of it
Set it up so when the switch is pressed, the number plate is folded in half
and youre done
Or theres the other alternitive where you dont cut it, and you set the servo up so it lifts ur number plate up so its against the rear undertray facing down...
<|Binge|>
Shaun
Likes 'em bent
PostPosted: 06:49 - 19 Jan 2005    Post subject: Reply with quote
Or you can all wait a week until I get my numberplate spinner on ebay and bid like crazy for it! Mr. Green
innominate
PostPosted: 08:30 - 19 Jan 2005    Post subject: Reply with quote
Just had an idea.
Dunno how possible this would be...
If you can fit some kind of LCD film over the numberplate.
Then get it to blank out different parts of the numberplate at a time.
If you could get this going fast enough (25 frames per second), then it would look normal to anyone looking at the plate.
But if a camara snapped it, you would only get a partial image of the plate. Maybe like only one digit displayed at once.
Won't stop you getting nicked by the Police if they chase you down, but could work against the evil camara's..
But may just be too complicated to put into practice tbh :/
I, as a responsible adult human being, will never concede the power to anyone to regulate my choice of what I put into my body, or where I go with my mind. From the skin inwards is my jurisdiction, is it not? I choose what may or may not cross that border. Here I am the customs agent. I am the coast-guard. I am the sole legal and spiritual government of this territory, and only the laws I choose to enact within myself are applicable.
Ricey
PostPosted: 09:15 - 19 Jan 2005    Post subject: Reply with quote
My dad's mate had a small plate one and it just completely lifted up and was hidden away under the tray.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 09:16 - 19 Jan 2005    Post subject: Reply with quote
If you get caught with one for, lets say speeding, they will throw the book at you for that offence if they notice a plate flipper.
Anyone remember the guy that filmed himself doing 165mph in the Brecon Beacons, and the police pulled him and saw the flipper? The copper told the court he had a flipper and he got a 12 month sentence Neutral
Ricey
PostPosted: 09:48 - 19 Jan 2005    Post subject: Reply with quote
It is a serious offence the best thing like I said earlier is to use it in the case of speed camera's.
BlueNinja
PostPosted: 11:12 - 19 Jan 2005    Post subject: Reply with quote
Dont use them, not for cameras, not for speeding.. the penalty could be very serious indeed depending on situation.. keep your licenses people, and keep enjoying motorcycling Thumbs Up
instigator
PostPosted: 11:16 - 19 Jan 2005    Post subject: Reply with quote
^^Says a 16.8 year old lad who bought a No2 kit for his very much pristine condition ZXR400. Laughing Laughing
tatters
Exxon Valdez
PostPosted: 13:20 - 19 Jan 2005    Post subject: Reply with quote
they also reviewed a full LED number plate which was basicly a tft moniter whic would go blank at the press of the button, the only sure method of hiding the reg
The last post was made 21 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 124.37 Kb
