| mellorbo |
 mellorbo Derestricted Danger
| Commuter_Tim |
 Posted: 18:54 - 29 Aug 2014 Post subject: |
In b4 "put it all back to stock" "they know better than you" etc. (you all know it was coming anyway)  ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| mellorbo |
| Rogerborg |
 Rogerborg nimbA
 Posted: 21:08 - 29 Aug 2014 Post subject: |
Every little helps.
The colour of your spark plug tells you about the fuelling. Run it at a given throttle opening for as long as you can (if it explodes, you ran it too long) then hit the killswitch while holding the throttle steady until it's stopped. Plug out, check the colour.
https://img31.imageshack.us/img31/5442/sparkplugt.jpg
With that carb, you can do:
#1 3/4 to Full throttle (change main jet).
#2 Idle to 1/4 (adjust mixture screw).
#3 1/4 to 3/4 (needle height).
Idle mixture can be done by just tweaking until the revs increase at idle. Above that, you will want to look at the plug colour. ____________________ Biking is 1/20th as dangerous as horse riding.
| mellorbo |
| Rogerborg |
 Rogerborg nimbA
| stirlinggaz |
 Posted: 22:23 - 29 Aug 2014 Post subject: |
hi,
aye, definately a plug chop is in order & re-jetting of the carb will improve performance & make it less likely to go BANG!!!
you say you have replaced the "muffler/backbox", what with?
does it have a cat? (another restriction imo)
pretty much garauntee you will be running lean, but how much? luckily these bikes are set up rich from new.
what carb do you have? if its one of those mikuni rip offs from china, i'd be looking at replacing it, though how successful you will be with jetting is a bit of a lottery.
its a chinese 4 stroke, probably putting out around 9 or 10 bhp from new (to get it through the emissions test), but with a few mods, you might get close to 13 or 14bhp....revving the tits off it.
doesnt sound worth it does it.......but that would mean around 30/40% improvement.(max)
how well the bike will take this extra powahh....who knows but i'd give it a go.(but am a bit daft)
as an example i owned some chinese cbr125 replica, fitted with a weird all up or all down gearbox. engine was 80% cg rip off.(156FMI)
with a bigger main jet. a gutted exhaust, a cone filter & sprocket change i was getting around 65mph at wot (real speed, indicated speed was just shy of 80mph), but it rattled like f*ck, (no balancer shaft) & sounded.....a bit different & all plastics fittings were replaced with decent s/s stuff with fibre washers & any others replaced with s/s or threadlok. : this makes riding the bike a helluva lot more pleasurable.
far better than the original 55mph max, at the red-line.
the change of sprockets made it a bit more suitable for NSL roads,
cheers,
GAZ
ps : didnt there used to be a dedicated chinese bike owners forum....? im fairly sure there was.........................anyway the sinnis bikes seem to be one of the better chinese bikes we are getting.
pps : & more importantly, you do realise moving the clip on the needle only really affects the middle throttle openings?
whereas the main jet is for WOT (puting it simply).
you have to address the FULL throttle range.
WOT 1st, plug chop takes care of main jet,
idle-1/4 throttle is the pilot jet & the rest is the clip on the needle. (WAAAAAY over simplified) |
| mellorbo |
 Posted: 22:42 - 29 Aug 2014 Post subject: |
the engine in the sinnis is sound its built in a suzuki factory its the pulse adrenalin and superbyke rmr which are the knock offs. its not got a cat its a straight through down pipe to a performance can with a k&n filters.
the spark plug was changed last month to an irridium one. i had it spare at the time and its the correct plug for the bike so i put it in. it has been gapped correctly too and i did the valve clearances 2 weeks ago too
i believe its a genuine mikuni carb as all part numbers and markings match up to other mikuni carbs i have had so im 99% sure
this is the exhaust i got https://www.chinesemotorcyclepartsonline.co.uk/partno_EXHKIT001.php
EDIT:
yes i understand that the needle clip was not the be all end all i just thought id give it a try as set in the middle it seemed to be ok ish. thankyou all for the help so far im going to go get a jet tomorrow but im going to pay the £30 and get it dyno tuned to find the current air fuel mix its on and get it re jetted properly. i shall let you all know how i get on.
p.s i have come into some money today not a great deal but enough to do what i need. i started this thread with the thought that it was going to be a while when i could afford it. but as i use the bike daily i diddnt want to blow it up |
| mellorbo |
| Nobby the Bastard |
| mellorbo |
| talkToTheHat |
| spriddler |
 spriddler Two Stroke Sniffer
| Rogerborg |
 Rogerborg nimbA
| mellorbo |
| mellorbo |
| spriddler |
 Posted: 07:49 - 02 Sep 2014 Post subject: Re: Fuel mixture help needed please |
| mellorbo wrote: |
i like how you automatically assume that i haven't notified my insurer.
and im sure if you ask your son you will find all insurance company's try to "wriggle" out of legit claims. they will go digging into every tiny thing to avoid paying. i know from personal experience.
but since we are on assumptions.
i assume you are one of the by the book. pay your parking tickets people e.t.c did you know that they are actually illegal? they unlawfully give them to you and make you pay in fear.
you do know they cant bankrupt me personally dont you? just my "strawman" or piece of paper with a name on it that if you go to court they can only deal with it if YOU take responsibility for it by claiming to be that person. its all hearsay
do you know tv licence is illegal?
your son may work in insurance but he only knows what he has been taught by his employer, on a need to know basis. im pretty sure he will not know what goes on behind closed doors. (im not saying what your son does is a bad job. its just a statement)
if you want to learn more on what im saying go to
www.getoutofdebtfree.org
this site is full of useful information. not just getting out of debt and covers legal issues as above.
it will also teach you a thing or two
ps. i came on this forum for help. you automatically assume that im braking the law and have not notified my insurance on my modifications. and in quite an arrogant way imo (which i have told them and made no change in price).
also i have my own public liability insurance policy which covers any 3rd party for a maximum of £15 million, i need this policy for work but its valid 24/7 in or out of work so even if my insurance diddnt pay out my cover would.
see how wrong you was on your assumptions? that could lead you in trouble at some point in your life.
but thankyou for your concern and have a nice day  |
".......and...................... R E L A X"
Sheeesh!  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:37 - 02 Sep 2014 Post subject: |
ADMIRALTY LAW, I AM A FREEMAN ON THE LAND, NOT A SHIP! ____________________ Biking is 1/20th as dangerous as horse riding.
| Robby |
 Robby Dirty Old Man
 Posted: 10:31 - 02 Sep 2014 Post subject: |
Having skimmed down the thread, let me see if I have this correct:
1. You did some mods. The bike was running fine, but you thought it was too hot.
2. You moved the needle down. Moving the needle down means the engine will run lean on 1/4 to 3/4 throttle. You need to be more accurate in your explanation here. Did you move the needle to a lower position (move the clip up the needle) or vice-versa?
3. You fitted a bigger main jet. This makes the mixture richer at full throttle, but has little effect at other times.
4. It's running poorly.
You have an air-cooled engine. They get hot. The only good indication you have of the heat in the engine is the spark plug. You don't need to go a plug chop - a chop is a technique for assessing fuelling under one particular set of conditions. You are looking to assess how the engine is working during normal riding.
Put the carb back to stock. Fit a new plug. Go for a 20 minute ride. Let the engine cool down. Remove the plug and look at it. If it's tan brown, your engine is fine.
Carb tuning is not that simple. You have four main things to adjust - idle, mixture, needle, main jet. An adjustment to one of them will have some effect on the others, varying from negligible to significant. To make adjustments accurately, you need to have the engine under load and be able to measure the air/fuel mix from the exhaust.
Luckily, you have a ace up your sleeve. The mixture doesn't need to be perfect, in fact it can be pretty awful. To foul a plug, it needs to be very rich. To melt something, it needs to be very lean. The stock settings allow for a fair bit of leeway, so you don't need to mess about with it after doing some minor mods. |
| mellorbo |
 Posted: 12:08 - 02 Sep 2014 Post subject: |
| Robby wrote: | Having skimmed down the thread, let me see if I have this correct:
i shall try to answer your questions as much as i can
1: i did the mods (exhaust, air filter/breather filter, egr blanking) i thought the bike was running ok as it was running the same as when i bought it second hand. but i noticed it getting hot and i mean really hot enough to the point it used to hesitate and lack power once hot.
2: i have 3 notches on my needle top - middle - bottom it sits on middle as stock. in order to make the mixture leaner i moved the needle up so i put it on the bottom notch. that had worse effects than desired so i put it back to the middle (stock)
3: yes i fitted a bigger main jet. it was 97.5 stock so i put in a 112.5
4: to be honest i would say it was running poorly before i did the mods it used to splutter and jerk under heavy throttle as fully stock.
now it has consistent power through the rev range and no splutters on acceleration just that little lunge if i shut the throttle off from fully open but not if i just let off as normal and close the throttle gently instead of like a on off switch |
| mellorbo |
 Posted: 14:51 - 02 Sep 2014 Post subject: |
hey guys i went out for a ride today for approx an hour. some slow parts cruising in 5th 4k revs 40mph.
some just before redlining it in 5th gear on dual carriage ways 8500rpm 70-75mph
i would say 70% of the ride was full throttle changing gear from 8k revs (limiter 9k)
i got home waited half hour took plug out and took pics, will post link below.
this is the same plug i was running lean on too.
plug number (NGK)
https://imgur.com/m4a1izs,TpQMgh8#0
plug tip
https://imgur.com/m4a1izs,TpQMgh8#1
the ground electrode looks like a tan brown but the rim around the electrode looks black. it is an iridium plug if that makes a difference. |
| Robby |
 Robby Dirty Old Man
| mellorbo |
| wr6133 |
 wr6133 World Chat Champion
The last post was made 11 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
