Fuel mixture help needed please
mellorbo
PostPosted: 16:04 - 29 Aug 2014    Post subject: Fuel mixture help needed please Reply with quote
Hi all,
Firstly let me bring you all up to speed on my situation.
i have a 2011 sinnis apache 125cc ( yes i know its Chinese so please don't tell me to get a real bike that is not the issue at hand )
i believe its based on a suzuki gn or gz engine.
I have replaced the muffler/backbox for an aftermarket one but i have left the down pipe as stock. i have swapped out the stock air filter for a free flow foam one and put on a crank case oil breather filter and removed the egr system with a blanking plate.
I have been told to re-jet my carb to a bigger one if i have issues.
now the bike seems to be running fine with no dead spots or splutters on the acceleration but it does "burble" on deceleration (it did this as completely stock)
BUT i have a feeling that the bike is running lean as the engine gets too hot to touch after a short journey (approx 2 miles) which if i remember correctly it never got that hot before.
it has a mikuni carb (slider type) with the throttle cable coming out of the top of the cylinder which unscrews to show a spring and needle e.t.c
now i was wondering if i could just move the washer down a notch on the needle towards the point if that would make it run richer until i can get a bigger jet in a few week.
im just worried that if it is running too lean then i will cause damage to my engine, any help with this matter would be greatly appreciated and if you have any further questions i will be happy to answer if i can.
thankyou in advance
james
Commuter_Tim
PostPosted: 18:54 - 29 Aug 2014    Post subject: Reply with quote
In b4 "put it all back to stock" "they know better than you" etc. (you all know it was coming anyway) Laughing
I ride a Bandit 600... badly.
mellorbo
PostPosted: 19:06 - 29 Aug 2014    Post subject: Reply with quote
Commuter_Tim wrote:
In b4 "put it all back to stock" "they know better than you" etc. Laughing
lol. i knew that was coming
i have gained power from the upgrades and a friend of mine has the same bike and he has done the same upgrades (not same products) and whereas when we first got them we was equal in power he did his upgrades and leaves me for dust and has a higher top end. i know it will never be anything special as its a 125cc but more power makes it safer to ride.
i have adjusted the needle into the bottom position and i have more power in gears 1,2,3 but 4 starts to hesitate and 5 just splutters. its getting dark now so i will have to have another look tomorrow.
i may end up having to take it to the dyno tuning shop near me and pay the £30 and get them to do it properly
PostPosted: 21:08 - 29 Aug 2014    Post subject: Reply with quote
Every little helps.
The colour of your spark plug tells you about the fuelling. Run it at a given throttle opening for as long as you can (if it explodes, you ran it too long) then hit the killswitch while holding the throttle steady until it's stopped. Plug out, check the colour.
https://img31.imageshack.us/img31/5442/sparkplugt.jpg
With that carb, you can do:
#1 3/4 to Full throttle (change main jet).
#2 Idle to 1/4 (adjust mixture screw).
#3 1/4 to 3/4 (needle height).
Idle mixture can be done by just tweaking until the revs increase at idle. Above that, you will want to look at the plug colour.
mellorbo
PostPosted: 21:14 - 29 Aug 2014    Post subject: Reply with quote
thankyou for that i shall give it a go tomorrow.
when i pull the plug out do i take it out as soon as i pull over or wait for it to cool down first?
PostPosted: 21:43 - 29 Aug 2014    Post subject: Reply with quote
Straight away, using only your lips.
It won't change colour while it's cooling.
stirlinggaz
PostPosted: 22:23 - 29 Aug 2014    Post subject: Reply with quote
hi,
aye, definately a plug chop is in order & re-jetting of the carb will improve performance & make it less likely to go BANG!!!
you say you have replaced the "muffler/backbox", what with?
does it have a cat? (another restriction imo)
pretty much garauntee you will be running lean, but how much? luckily these bikes are set up rich from new.
what carb do you have? if its one of those mikuni rip offs from china, i'd be looking at replacing it, though how successful you will be with jetting is a bit of a lottery.
its a chinese 4 stroke, probably putting out around 9 or 10 bhp from new (to get it through the emissions test), but with a few mods, you might get close to 13 or 14bhp....revving the tits off it.
doesnt sound worth it does it.......but that would mean around 30/40% improvement.(max)
how well the bike will take this extra powahh....who knows but i'd give it a go.(but am a bit daft)
as an example i owned some chinese cbr125 replica, fitted with a weird all up or all down gearbox. engine was 80% cg rip off.(156FMI)
with a bigger main jet. a gutted exhaust, a cone filter & sprocket change i was getting around 65mph at wot (real speed, indicated speed was just shy of 80mph), but it rattled like f*ck, (no balancer shaft) & sounded.....a bit different & all plastics fittings were replaced with decent s/s stuff with fibre washers & any others replaced with s/s or threadlok. : this makes riding the bike a helluva lot more pleasurable.
far better than the original 55mph max, at the red-line.
the change of sprockets made it a bit more suitable for NSL roads,
cheers,
GAZ
ps : didnt there used to be a dedicated chinese bike owners forum....? im fairly sure there was.........................anyway the sinnis bikes seem to be one of the better chinese bikes we are getting.
pps : & more importantly, you do realise moving the clip on the needle only really affects the middle throttle openings?
whereas the main jet is for WOT (puting it simply).
you have to address the FULL throttle range.
WOT 1st, plug chop takes care of main jet,
idle-1/4 throttle is the pilot jet & the rest is the clip on the needle. (WAAAAAY over simplified)
mellorbo
PostPosted: 22:42 - 29 Aug 2014    Post subject: Reply with quote
the engine in the sinnis is sound its built in a suzuki factory its the pulse adrenalin and superbyke rmr which are the knock offs. its not got a cat its a straight through down pipe to a performance can with a k&n filters.
the spark plug was changed last month to an irridium one. i had it spare at the time and its the correct plug for the bike so i put it in. it has been gapped correctly too and i did the valve clearances 2 weeks ago too
i believe its a genuine mikuni carb as all part numbers and markings match up to other mikuni carbs i have had so im 99% sure
this is the exhaust i got https://www.chinesemotorcyclepartsonline.co.uk/partno_EXHKIT001.php
EDIT:
yes i understand that the needle clip was not the be all end all i just thought id give it a try as set in the middle it seemed to be ok ish. thankyou all for the help so far im going to go get a jet tomorrow but im going to pay the £30 and get it dyno tuned to find the current air fuel mix its on and get it re jetted properly. i shall let you all know how i get on.
p.s i have come into some money today not a great deal but enough to do what i need. i started this thread with the thought that it was going to be a while when i could afford it. but as i use the bike daily i diddnt want to blow it up
mellorbo
PostPosted: 16:40 - 30 Aug 2014    Post subject: Reply with quote
hey guys i couldn't get in to the dyno shop today so i went to my local back street garage and got a jet. i went bigger from a 97.5 to a 112.5
as expected the bike pulls harder now quite noticeably throughout the rev range.
i have noticed however sometimes when i let off of full throttle the bike lunges forward in a split second power burst. is that anything to be concerned about?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:04 - 30 Aug 2014    Post subject: Reply with quote
The bike accelerates when you shut off the throttle and you ask whether or not it's an issue?
You do know what the throttle does, don't you?
I suspect that you have now put in too large a jet.
Triumph Sprint ST 1050
mellorbo
PostPosted: 18:07 - 30 Aug 2014    Post subject: Reply with quote
lol yes i do know what a throttle does but since it only lunges for a second it doesn't catch me off guard.
i also bought a 105 jet too but diddnt know if that would be going too far down back towards lean.
talkToTheHat
PostPosted: 00:07 - 01 Sep 2014    Post subject: Reply with quote
The lunging on throttle off is dangerous and will catch you out on a slippery roundabout or similar.
The GN/GZ/GS125 engine design is pretty tough, I don't have personal experience of clones. Both the two I had would burble a little on a closed throttle and were fine temperature wise.
Hot's relative, but mine would both be too hot to touch after a spirited ride and when I stopped would make the plink plink plink sound of cooling metal for a few minutes. Plugs were fine, the K2 drank oil, the K6 didnt. Too hot smells different.
Bandit. does. everything.
spriddler
PostPosted: 08:57 - 01 Sep 2014    Post subject: Re: Fuel mixture help needed please Reply with quote
You must inform your insurer of ANY changes from stock or in the event of a third party claim your insurer can rescind cover.
A third party personal injury claim could bankrupt you.
(Don't give me all that "Why?" or "How will they know?" guff. My son's in insurance and they'll take any opportunity to wriggle out. They're not in business for your benefit.
PostPosted: 09:21 - 01 Sep 2014    Post subject: Re: Fuel mixture help needed please Reply with quote
They'll still have to pay out to the 3rd party. Ask your son why.
Being sued by your insurer to recover their payout could bankrupt you.
How would they go about showing that the modification contributed significantly to the crash?
mellorbo
PostPosted: 17:46 - 01 Sep 2014    Post subject: Re: Fuel mixture help needed please Reply with quote
i like how you automatically assume that i haven't notified my insurer.
and im sure if you ask your son you will find all insurance company's try to "wriggle" out of legit claims. they will go digging into every tiny thing to avoid paying. i know from personal experience.
but since we are on assumptions.
i assume you are one of the by the book. pay your parking tickets people e.t.c did you know that they are actually illegal? they unlawfully give them to you and make you pay in fear.
you do know they cant bankrupt me personally dont you? just my "strawman" or piece of paper with a name on it that if you go to court they can only deal with it if YOU take responsibility for it by claiming to be that person. its all hearsay
do you know tv licence is illegal?
your son may work in insurance but he only knows what he has been taught by his employer, on a need to know basis. im pretty sure he will not know what goes on behind closed doors. (im not saying what your son does is a bad job. its just a statement)
if you want to learn more on what im saying go to
www.getoutofdebtfree.org
this site is full of useful information. not just getting out of debt and covers legal issues as above.
it will also teach you a thing or two Smile
ps. i came on this forum for help. you automatically assume that im braking the law and have not notified my insurance on my modifications. and in quite an arrogant way imo (which i have told them and made no change in price).
also i have my own public liability insurance policy which covers any 3rd party for a maximum of £15 million, i need this policy for work but its valid 24/7 in or out of work so even if my insurance diddnt pay out my cover would.
see how wrong you was on your assumptions? that could lead you in trouble at some point in your life.
but thankyou for your concern and have a nice day Smile
mellorbo
PostPosted: 17:56 - 01 Sep 2014    Post subject: Reply with quote
hi, thankyou for your reply. the temperature has got a lot more stable and does not seem to be an issue now.
as for the lunge, it only happens if i have full throttle on at about 7k revs then shut off throttle fully it lunges slightly. the exhaust also smells a little rich but not much. but the guy in shop said to try lower the needle down and it should balance it out. im going to give it a try if not ill have to find a smaller jet. stock was 97.5 i bought a 105 but that runs it too lean and i have a 112.5 in currently so im thinking maybe around 110 size?
spriddler
PostPosted: 07:49 - 02 Sep 2014    Post subject: Re: Fuel mixture help needed please Reply with quote
".......and...................... R E L A X"
Sheeesh! Rolling Eyes
PostPosted: 09:37 - 02 Sep 2014    Post subject: Reply with quote
ADMIRALTY LAW, I AM A FREEMAN ON THE LAND, NOT A SHIP!
Robby
Dirty Old Man
PostPosted: 10:31 - 02 Sep 2014    Post subject: Reply with quote
Having skimmed down the thread, let me see if I have this correct:
1. You did some mods. The bike was running fine, but you thought it was too hot.
2. You moved the needle down. Moving the needle down means the engine will run lean on 1/4 to 3/4 throttle. You need to be more accurate in your explanation here. Did you move the needle to a lower position (move the clip up the needle) or vice-versa?
3. You fitted a bigger main jet. This makes the mixture richer at full throttle, but has little effect at other times.
4. It's running poorly.
You have an air-cooled engine. They get hot. The only good indication you have of the heat in the engine is the spark plug. You don't need to go a plug chop - a chop is a technique for assessing fuelling under one particular set of conditions. You are looking to assess how the engine is working during normal riding.
Put the carb back to stock. Fit a new plug. Go for a 20 minute ride. Let the engine cool down. Remove the plug and look at it. If it's tan brown, your engine is fine.
Carb tuning is not that simple. You have four main things to adjust - idle, mixture, needle, main jet. An adjustment to one of them will have some effect on the others, varying from negligible to significant. To make adjustments accurately, you need to have the engine under load and be able to measure the air/fuel mix from the exhaust.
Luckily, you have a ace up your sleeve. The mixture doesn't need to be perfect, in fact it can be pretty awful. To foul a plug, it needs to be very rich. To melt something, it needs to be very lean. The stock settings allow for a fair bit of leeway, so you don't need to mess about with it after doing some minor mods.
mellorbo
PostPosted: 12:08 - 02 Sep 2014    Post subject: Reply with quote
i shall try to answer your questions as much as i can
1: i did the mods (exhaust, air filter/breather filter, egr blanking) i thought the bike was running ok as it was running the same as when i bought it second hand. but i noticed it getting hot and i mean really hot enough to the point it used to hesitate and lack power once hot.
2: i have 3 notches on my needle top - middle - bottom it sits on middle as stock. in order to make the mixture leaner i moved the needle up so i put it on the bottom notch. that had worse effects than desired so i put it back to the middle (stock)
3: yes i fitted a bigger main jet. it was 97.5 stock so i put in a 112.5
4: to be honest i would say it was running poorly before i did the mods it used to splutter and jerk under heavy throttle as fully stock.
now it has consistent power through the rev range and no splutters on acceleration just that little lunge if i shut the throttle off from fully open but not if i just let off as normal and close the throttle gently instead of like a on off switch
mellorbo
PostPosted: 14:51 - 02 Sep 2014    Post subject: Reply with quote
hey guys i went out for a ride today for approx an hour. some slow parts cruising in 5th 4k revs 40mph.
some just before redlining it in 5th gear on dual carriage ways 8500rpm 70-75mph
i would say 70% of the ride was full throttle changing gear from 8k revs (limiter 9k)
i got home waited half hour took plug out and took pics, will post link below.
this is the same plug i was running lean on too.
plug number (NGK)
https://imgur.com/m4a1izs,TpQMgh8#0
plug tip
https://imgur.com/m4a1izs,TpQMgh8#1
the ground electrode looks like a tan brown but the rim around the electrode looks black. it is an iridium plug if that makes a difference.
Robby
Dirty Old Man
PostPosted: 16:50 - 02 Sep 2014    Post subject: Reply with quote
The colour looks right. 70% throttle means the fuelling is being controlled by the main jet and the needle.
Surging when you snap the throttle shut is a concern. My best guess is it's running too rich on wide open throttle. Throttle snaps shut, a bit of fuel is still floating around, surge.
The main jet you have fitted is 17% bigger. I don't feel like doing maths, but as a ballpark that means it's flowing about 20% more fuel. The modifications you have made are unlikely to mean that you are flowing 20% more air. I would try an intermediate size of main jet.
mellorbo
PostPosted: 19:25 - 02 Sep 2014    Post subject: Reply with quote
hi, thankyou for that.
i have another main jet size 105 so i might try that one tomorrow thats in between the 112.5 thats in and the 97.5 that was stock. im useless at maths so im not good at working out what % difference that is but ill try it anyway and report back with the results
wr6133
PostPosted: 20:04 - 02 Sep 2014    Post subject: Reply with quote
When I did free flowing pipes and cone filters on a Chinese bike it needed a 10% upjet. So if you started on a 97 I'd be trying with 106, 107,108... plug chops on each of those I'd bet one is right.
PostPosted: 20:33 - 02 Sep 2014    Post subject: Reply with quote
By my reckoning the 105 is 16% more fuel and the 112 is a whopping 33% more.
The last post was made 11 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.31 - MySQL Queries: 15 - Page Size: 148.01 Kb
