Bandit carbs - coincidence or just plain wierd
mudcow007
PostPosted: 07:51 - 03 Sep 2014    Post subject: Bandit carbs - coincidence or just plain wierd Reply with quote
swapped my tank last night
clean carbs again as the tank sealent (petseal ultra) had started to dissolve an what ever it touched it left an 'orrible stacky tacky mess...
so set mixture screws to 1.5 times out refitted carbs
bike ran as good as a bandit can run, this morning started riding to work an it felt like it was running on 2 or 3, power was mega lumpy then i hit a pot hole an must have dislodged a throttle cable (push cable i think) as the throttle went slack but would still power the bike
this is the odd bit - the bike started running on 4 again?
coincidence or would a badly fitted cable cause poor running? or is witchcraft at play?
Bezzer
PostPosted: 08:03 - 03 Sep 2014    Post subject: Reply with quote
Could be anything like a bit of the petseal shit left in there and blocking the float needle or somewhere else that got knocked free when you hit the pothole. As you've just been messing with the carbs it's probably the push cable not locating properly.
Formerly known as
P.
PostPosted: 08:14 - 03 Sep 2014    Post subject: Reply with quote
Find a mint tank.
Fit mint tank.
Clean carbs.
New fuel lines.
The profit... oooh the sweet sweet profit. Laughing
mudcow007
PostPosted: 08:18 - 03 Sep 2014    Post subject: Reply with quote
oi paddy...tank is mint i will have you know.... well except for the outside that looks like its been to a party in fallujah
carbs were stripped - (i didnt split them though) an cleaned with acetone, as ive found that will dissolve basically anything
it got me to work with the slack cable so will refit the iffy cable an use thread lock this time
updates to follow
Formerly known as
P.
PostPosted: 08:29 - 03 Sep 2014    Post subject: Reply with quote
Why is petseal still present if tank is mint.
All that goes in my tank is petrol, when it gets rusty or leaks, I'll buy a new tank, purely as its hassle Laughing
mudcow007
PostPosted: 09:01 - 03 Sep 2014    Post subject: Reply with quote
the tank that was originally on the bike was holed, so was treated to a bit of electrolysis, welded an then given a slap of petseal
when the above failed, i just replaced the tank...which admitting i just should have at the beginning an saved my self a quid or three....
Formerly known as
P.
PostPosted: 09:41 - 03 Sep 2014    Post subject: Reply with quote
See, profit Laughing
Just replace the fuel lines if you haven't done so and grab a small in line filter.
mudcow007
PostPosted: 08:13 - 04 Sep 2014    Post subject: Reply with quote
update
after fiddling with the carbs again last night, all is well in the world of mudcow's Bandit Mr. Green
The last post was made 11 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.23 - MySQL Queries: 13 - Page Size: 54.84 Kb
