vacuum gauge
Meshuggah
PostPosted: 18:09 - 04 Sep 2014    Post subject: vacuum gauge Reply with quote
https://www.ebay.co.uk/itm/Carbtune-Pro-vacuum-gauge-2-column-/131179215528?pt=UK_Motorcycle_Parts&hash=item1e8ae3faa8
Hello everyone. Just a quick question. Is the Throttle body sync really needed (I've got an FZ6 2005 with 22000 miles on it) and is the one in the link a decent one?
Thanks.
Triumph Tiger 800 2012
orac
PostPosted: 18:51 - 04 Sep 2014    Post subject: Reply with quote
it good to keep them in sync, and should always be done after a clean, as for it being a good one - dunno but you can build them
https://www.google.co.uk/?gws_rd=ssl#q=how+to+make+a+carb+balancer
there are some in that search that are made from fish tank tubing and some water with food dye.
I have a cheap set of gauges in box under the bed, they have saved me a few quid over the years
mentalboy
PostPosted: 19:22 - 04 Sep 2014    Post subject: Reply with quote
I find it easier reading the 'column' style gauges (like the one you've shown) rather than the dial type, but if you are going to get one then it's probably better to make sure that it is the 4 column variety, which makes use easy on any 2/4 cylinder - that pic is very misleading because the ad is for a two column gauge but the pic shows four rubber hook up tubes as per the 4 column variety, must catch out a good few people!!!
The older mercury type are the best (IMHO) but getting harder to find nowadays
Make mine a Corona.
johnsmith222
PostPosted: 20:08 - 04 Sep 2014    Post subject: Reply with quote
definitely splash out and get the 4 column one. I'd order it from morgan themselves and go for the carry case too as it's pretty good quality and nice to have.
I know it's one of these tools that you can make yourself, but it's one of the things you only buy once and it's nice to have the proper tool.
Meshuggah
PostPosted: 20:35 - 04 Sep 2014    Post subject: Reply with quote
What about this one? https://www.ebay.co.uk/itm/131214129801?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I've never done to be honest. I'm not even sure if it's needed cause the bike goes, but it could be an invenstment for the furture.
mudcow007
PostPosted: 07:49 - 05 Sep 2014    Post subject: Reply with quote
i made my own
https://i25.photobucket.com/albums/c81/mudcow007/20140417_075029_zpse4f2aaf9.jpg
made from fishtank pipes a couple of t junction thingies an some atf
took all of 20mins including finding a bit of kitchen worktop to attach it all too
mentalboy
PostPosted: 16:32 - 05 Sep 2014    Post subject: Reply with quote
I have one of those and one of the four column protune versions, as said before, both work ok but personally I prefer reading the column type - it's fairly obvious looking at the 4 columns to gauge when something's off, the dial type above have several different measurements around them, which tends to give a cluttered look and makes reading the exact measurement that you're after trickier (but not much) than just looking at 4 columns next to each other.
Edit: bottom of page one on the link reminded me of another reason why I like the carbtune, see for yourself... https://www.bikechatforums.com/viewtopic.php?t=263096
Make mine a Corona.
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 53.77 Kb
