clutch lever keeps popping out
Bike Chat Forums Index -> The Workshop via View Category
PostPosted: 23:30 - 07 Sep 2014    Post subject: clutch lever keeps popping out Reply with quote
the clutch lever on the crankcase keeps popping out of position when i clutch in. the clutch lever is on the left side. this happened after installing the clutch, what have i done wrong?
https://www.youtube.com/watch?v=53qYoGTXuXY&feature=youtu.be
yen_powell
PostPosted: 04:28 - 08 Sep 2014    Post subject: Reply with quote
Shouldn't there be a nut on the cable on either side of the engine bracket?
XT1200Z and a DR350 in bits
Taught2BCauti...
PostPosted: 06:30 - 08 Sep 2014    Post subject: Reply with quote
Make, model and year would help!
The lifter pin is usually retained at the bottom end, by a hook on the return spring that engages with a hole or protrusion inside the housing. Check that the spring is on correctly, and that the hook hasn't broken off.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
P.
PostPosted: 08:00 - 08 Sep 2014    Post subject: Reply with quote
Yes, there should.
You are missing 2 nuts.
770
PostPosted: 09:27 - 08 Sep 2014    Post subject: Reply with quote
husqvarna sm 125 2002
770
Paddy. wrote:
Yes, there should.
where and what? can u pinpoint where it is missing??
lihp
PostPosted: 09:33 - 08 Sep 2014    Post subject: Reply with quote
I'm sure your mrs can tell you where you're missing your 2 nuts from Thumbs Up
P.
PostPosted: 10:06 - 08 Sep 2014    Post subject: Reply with quote
You see the bit that the cable "sits in" the kinda metal looking sleeve, not the nipple but the actual cable.
That part of the cable is threaded for a reason. You have one nut either side of that, you then adjust the clutch cable by unscrewing the nuts, adjusting it and tightening back up.
The bit coming out of the engine should have something like this on it...
https://s3.amazonaws.com/thmb.inkfrog.com/pix/independentcycle/CLUTCH_LEVER_(2)_026.JPG/450/1
You should have a clip inside holding that part in. Initially I was looking at the clutch cable itself... Laughing
The last post was made 11 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Workshop via View Category All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 56.82 Kb
