| 770 |
 770 Nova Slayer
 Posted: 23:30 - 07 Sep 2014 Post subject: clutch lever keeps popping out |
the clutch lever on the crankcase keeps popping out of position when i clutch in. the clutch lever is on the left side. this happened after installing the clutch, what have i done wrong?
https://www.youtube.com/watch?v=53qYoGTXuXY&feature=youtu.be |
| yen_powell |
 yen_powell World Chat Champion
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 06:30 - 08 Sep 2014 Post subject: |
Make, model and year would help!
The lifter pin is usually retained at the bottom end, by a hook on the return spring that engages with a hole or protrusion inside the housing. Check that the spring is on correctly, and that the hook hasn't broken off. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| P. |
 P. Red Rocket
| 770 |
 770 Nova Slayer
| 770 |
 770 Nova Slayer
| lihp |
 lihp World Chat Champion
| P. |
 P. Red Rocket
 Posted: 10:06 - 08 Sep 2014 Post subject: |
You see the bit that the cable "sits in" the kinda metal looking sleeve, not the nipple but the actual cable.
That part of the cable is threaded for a reason. You have one nut either side of that, you then adjust the clutch cable by unscrewing the nuts, adjusting it and tightening back up.
The bit coming out of the engine should have something like this on it...
https://s3.amazonaws.com/thmb.inkfrog.com/pix/independentcycle/CLUTCH_LEVER_(2)_026.JPG/450/1
You should have a clip inside holding that part in. Initially I was looking at the clutch cable itself...  |
The last post was made 11 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
