help with wiring no spark, pulse adrenaline/gs125 copy
impulsive
PostPosted: 10:01 - 11 Sep 2014    Post subject: help with wiring no spark, pulse adrenaline/gs125 copy Reply with quote
can anyone help me with wiring don't know what im doing but got no spark Sad
lihp
PostPosted: 10:30 - 11 Sep 2014    Post subject: Reply with quote
Red to +
WD Forte
PostPosted: 11:04 - 11 Sep 2014    Post subject: Reply with quote
put more stickers on it
bikers smell of wee
impulsive
PostPosted: 11:19 - 11 Sep 2014    Post subject: Reply with quote
also should say, got new loom, new stator, new coil pack, new plug and cap and new battery, just not sure why I got no spark guessing faulty connector somewhere?
gavcarter
PostPosted: 11:21 - 11 Sep 2014    Post subject: Reply with quote
kill switch........
impulsive
PostPosted: 11:23 - 11 Sep 2014    Post subject: Reply with quote
taken kill switch off side stand and j#connected the wire together, kill switch in clutch lever. pulls in and solenoid just clicks, I have a kill switch in throttle assembly or front brake but that is a new unit
mudcow007
PostPosted: 11:31 - 11 Sep 2014    Post subject: Reply with quote
what voltage at your battery?
impulsive
PostPosted: 11:34 - 11 Sep 2014    Post subject: Reply with quote
12.51 on battery
bikenut
PostPosted: 15:56 - 11 Sep 2014    Post subject: Reply with quote
get a wiring diagram........suspect cdi unit kill circuit........any pics??
have you painted the frame ( and now insulated the earth?? )??
I presume you have no spark via the k/starter??
clickling solenoid, bad connection to starter etc etc etc .....mmmmmmm have you painted the frame
nuts about bikes
impulsive
PostPosted: 18:02 - 11 Sep 2014    Post subject: Reply with quote
i have painted the frame but earthing points sanded back to bare metal
impulsive
PostPosted: 15:16 - 12 Sep 2014    Post subject: Reply with quote
little update replaced solenoid recharge battery, engine is turning over but I still have not got spark, any help please guys?
mudcow007
PostPosted: 15:25 - 12 Sep 2014    Post subject: Reply with quote
ok
so what condition is plug?
coil?
ht lead?
impulsive
PostPosted: 15:41 - 12 Sep 2014    Post subject: Reply with quote
new plug, new coil new cap
gavcarter
PostPosted: 15:44 - 12 Sep 2014    Post subject: Reply with quote
Coil wires the right way round? If its two bullets swap them over.....
impulsive
PostPosted: 15:53 - 12 Sep 2014    Post subject: Reply with quote
yes only one way coil wires fit
no bullet connectors all in wiring loom
impulsive
PostPosted: 15:54 - 12 Sep 2014    Post subject: Reply with quote
suspecting dodgy connection in wiring, also have a new cdi here im going to chuck in as soon as I remember where I put it now Very Happy
impulsive
PostPosted: 16:06 - 12 Sep 2014    Post subject: Reply with quote
https://img.llexeter.co.uk/images/partimages/1521_XF125GY-2B_390.jpg
impulsive
PostPosted: 12:36 - 14 Sep 2014    Post subject: Reply with quote
bump, any help guys?
bikenut
PostPosted: 14:54 - 15 Sep 2014    Post subject: non starter Reply with quote
so still no spark?? pics please
nuts about bikes
impulsive
PostPosted: 22:16 - 15 Sep 2014    Post subject: Reply with quote
pictures of what bikenut?
PostPosted: 22:46 - 15 Sep 2014    Post subject: Reply with quote
Probably about time to put a location in your profile and offer tea or tits.
bikenut
PostPosted: 10:50 - 16 Sep 2014    Post subject: pics..... Reply with quote
pics of what?? your thumb perhaps??
jesting apart, pics of the bike, the cdi if fitted the genny the engine etc etc etc .....pics relevant to your problem ( bikes problem rather than acne ) :karma:
nuts about bikes
WD Forte
PostPosted: 13:44 - 16 Sep 2014    Post subject: Reply with quote
swap and hope is a poor way of fixing bikes
<rant>
"Test dont guess FFS"
</rant>
If that diagram is the correct one for your bike
its a very simple machine
I'd disconnect the wire from the CDi to the ignition switch first
If you're lucky its that.
On most CDI bikes that wire will be pulled low to stop the sparks
and will go high to allow sparks/engine run
A wrong or badly wired switch may be disabling the CDI
(get meter, test)
If that makes no difference
test the source coil and pulser coils resistances to earth
If any show a dead short they're probably burn out or shit wiring
High or off the scale reading could also be burn out, broken wires or open connectors.
With a meter you can also do contiinuity tests to see if the wires at the cdi are actually connected to the ign sw/ign coil/pulser./ source coil etc
test time 5 mins max
You do have a meter don't you?
bikers smell of wee
bikenut
PostPosted: 14:46 - 16 Sep 2014    Post subject: Reply with quote
wiring diagram wont open on my computer........
nuts about bikes
WD Forte
PostPosted: 15:21 - 16 Sep 2014    Post subject: Reply with quote
The one posted was for a Pulse Adrenaline found on google
and here
https://www.pulsemoto.co.uk/XF125GY-2B_parts_33012_1521_XF125GY-2B.php
whether it bears any resemblence to a gs125 ( Suzuki?)
is anybodys guess.
The OP isnt helping much
Dont know about anybody else but the old psychic powers
aint half playing up since the green kryptonite incident
( curse you Lex Luthor !!)
and some idea WTF he's doing/ trying to do would help.
he hasn't clue and we have to guess.
Just put more stickers on it and make it into a garden ornament
bikers smell of wee
The last post was made 12 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 118.62 Kb
