Standing on pegs engine cuts out
Beardy
PostPosted: 09:01 - 12 Sep 2014    Post subject: Standing on pegs engine cuts out Reply with quote
So my xr125 (with its many quirks) cuts out when I stand on the pegs whilst green laning. I think its the sidestand switch because if I kick the sidestand with my heel it starts up again with the starter.
My question is can I simply disconnect it or can that cause other problems? I don't really need one as I've managed on other bikes for years before Very Happy
davebike
PostPosted: 09:08 - 12 Sep 2014    Post subject: Reply with quote
Yes it can be disconnected but I think you need to connect two f the three wires in the connector together
Sorry cannot remember the colour codes to connect
Dave
NC750Xdct + others at work !
[email protected]
orac
PostPosted: 09:12 - 12 Sep 2014    Post subject: Reply with quote
can you post a wiring diagram, been a fair while since playing with Honda wiring. is definitely a 3 wire setup?
c_dug
PostPosted: 09:34 - 12 Sep 2014    Post subject: Reply with quote
I bridged mine out on one of my bikes, it was just a case of connecting the two wires.
Try doing it at the connector block somehow rather than cutting the wires themselves, that way if it turns out not to be the issue you haven't ruined a good component.
Minty
PostPosted: 11:14 - 12 Sep 2014    Post subject: Reply with quote
Stop standing up. Thumbs Up
My fingers smell of your mum.
Beardy
PostPosted: 11:18 - 12 Sep 2014    Post subject: Reply with quote
This is the one I believe:
https://minus.com/i/bx1EMj3g7ucW7
Irn-Bru
PostPosted: 11:47 - 12 Sep 2014    Post subject: Reply with quote
When the side stand spring wears over time the stand bounces around while you're off roading, that means it'll cut out due to the safety switch. All I did on my bike was unplug the switch, then cut off the plug on the wiring loom and solder the wires together. Job jobbed. Also removed my clutch switch as well (very easy on a drz, no soldering required), have had one of those go bad once and left me stranded. Safety switches my arse, cause more harm than good.
Beardy
PostPosted: 16:12 - 14 Sep 2014    Post subject: Reply with quote
Switch removed so one less thing to worry about Very Happy
virus
PostPosted: 16:30 - 14 Sep 2014    Post subject: Reply with quote
first thing I do when I get a bike is to disable the 'safety' switches, they almost always fail leaving you stranded somewhere you'd rather not be, and to be honest, if im retarded enough to pull off with the sidestand down, or try and start it up in gear without the clutch in then maybe dropping the bike on myself will teach me not to do it again. Laughing
own: 81 xs1100g...
The last post was made 12 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 59.5 Kb
