Sealent around metal
lee8040
PostPosted: 21:53 - 12 Sep 2014    Post subject: Sealent around metal Reply with quote
Whats a good sealant that I can put around metal? Any silicone ones stick?
It's to go on the engine casing where the oil is stored. I have a gs500 that leaks oil from the cSing where the filter sits. It's not the o ring it's a notch of metal removed from the casing and a old repair hasn't worked. Basically want to put a sealant around the bottom to stop oil dripping out. To repair along with the other things is way more than the bike is worth
mentalboy
PostPosted: 22:12 - 12 Sep 2014    Post subject: Reply with quote
If you mean there's a chunk missing from your engine casing then you are best to look for a secondhand part and expect a stripdown, or get a professional to charge lots and lots for TIG welding and dressing a repair.
You could use any number of sealants but, as those on here who've tried before will tell you, they will fail sooner rather than later. Sorry, probably not what you wanted to hear.
Make mine a Corona.
PostPosted: 22:20 - 12 Sep 2014    Post subject: Reply with quote
Probably that.
As an owner of a Royal Oilfield, I can confirm that no amount of rubber or silicone gloop can compensate for two pieces of metal not meeting up quite as nature intended. A few pennies of oil and a wipe down with a rag is a lot cheaper and more time efficient than trying to bridge that gap.
stirlinggaz
PostPosted: 23:13 - 12 Sep 2014    Post subject: Reply with quote
hi,
might have misunderstood issue, but wouldnt a a little blob of jb weld do?
cheers,
GAZ
WD Forte
PostPosted: 00:20 - 13 Sep 2014    Post subject: Reply with quote
yep, Jb weld.
A wee drop of that and a careful dressing with small file
can fill scratches, digs and such.
Degrease and prep the surface first for best effect or you may just
waste your time.
bikers smell of wee
temeluchus
PostPosted: 00:44 - 13 Sep 2014    Post subject: Reply with quote
A picture of the damage would help.
Depending on where and how bad, JB weld might make a decent long term repair.
The last post was made 12 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 47.76 Kb
