| Mirey |
 Mirey Two Stroke Sniffer
| Itchy |
 Itchy Super Spammer
 Posted: 15:03 - 13 Sep 2014 Post subject: |
You can get a ride in ride outservice.
But it will cost more £25-30 just to change the tyres.
Or you can take the wheels off 'loose wheel' service which will cost less.
Myself the last time I changed tyres I removed the brake discs and took them to a car place, they charged me £5. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:57 - 13 Sep 2014 Post subject: |
YBR I believe has tubed tyres.
Ever fixed a puncture n a push-bike?
It exaclty the same as that, just a bit bigger.
Get a couple of GOOD tyre levers off e-bay.
I reccomend this sort:-
https://i.ebayimg.com/00/s/ODAwWDgwMA==/$(KGrHqVHJBkE63VtkUY-BO0TfPqW3g~~60_57.JPG
They are long for plenty of leverage, curved so they can be hooked over the rim nicely and locked under sprocket or brake disc, and sharp eough to get uder the bead easily.
That set of three is £27, which is probaby cheaper than a ride-in-ride out service, at a fitters, IF they are prepared to fit tyres they haven't supplied. (Some wont.) Though you can buy them individually for about a tenner, and if you only really need one good one, like that for the 'wiggling' bit, a couple of plain ones that are cheaper are all you need to hold the tyre while you pry. And of course, you have them handy next time you need to change a tyre or fix a puncture.
While you you have the wheels off, though, I would be iclined to spend a little time and have a look at the front brake, and at least clean the front caliper pistons, & grease the float pins, if not replace the brake pads.
At the back, you have a drum brake; that will apreciate you knocking the brake dust out of the drum, checking or replacing the shoes, and greasing the pivots. While on the other side you have a cush-drive, with the sprocket on.
Check the sprocket & chain, if tyres be dead good chance bikes done enough miles that the chain & Sprockets are due replacement.
BUT get a set of these:-
https://i.ebayimg.com/00/s/NDEyWDM4OQ==/z/LgsAAOSwQItT8cvX/$_35.JPG
As matter of course. £9 off Wemoto e-bay, they are the rubber blocks that go in the cush-drive. Its a five minute job to swap them, no special tools necessary, and they make a WORLD of difference to the bike. They are almost always hammered to death putting slop in the drive line, which is over-looked, neglected or not kown about. BUT, new ones an transform the way the bike rides, make gear changes a heck of a lot easier & smoother, while givig your drive chain a much easier time, so it doesn't wear out as quick.
Add a Haynes manual to the list for guidance, and you are STILL probably not a lot more out of pocket than taking tyres & like to a garage, AND you'll be getting a lot more value from it, as well as learning how to look after your bike.
There is nothing there, that is particularly hard or difficult or needs much more than factory tool-kit, bar the tyre levers.
Go for it... get greasy! Its a whole added pleasure to your biking looking after your own bike, with bonus you have nicer bike to ride for the effort. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| c_dug |
 c_dug Super Spammer
 Posted: 17:08 - 13 Sep 2014 Post subject: |
The chances of getting it so wrong that the wheel falls out are next to nothing.
You might need to pick yourself up a socket set and levers as above, but DIY is almost certainly easier than you imagine. It's just lots of little jobs lined up. If I asked you to undo one bolt I doubt you'd fret over it. It is essentially just minor jobs like that all lined up.
A manual will help, if you don't have one then most halfords have an alright selection, or your local bike shop. Or if you're really strapped for cash download a copy.
Not sure where you are based but a friendly local BCFist might be willing to help you out for a cuppa tea or two. Maybe post your location.
Also, removing both wheels at the same time to bring to a tyre place will require some genius bodgineering, it can be done with bricks, wood, rope, old tyres or random junk you find in the garden, or a combination of items on that list. Or ~£50 worth of stands if you want to do it properly. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
| Mirey |
| Mirey |
| Mirey |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:32 - 15 Sep 2014 Post subject: |
I've done the same tyres on basically the same rims / bike as the YBR twice, the first time I spent 10 hours on it. I shit you not.
Lube is your friend. Eventually I used some Couzens washing up liquid, made the job very simple.
Tyre leavers + a couple of rim protectors, 3 is a luxury, 2 is fine.
The ME22's are fantastically grippy. They don't last too well, 4k miles, but they offer so much grip in the wet and dry. Brilliant for that bike.
I did 2 winters and summers on them, still haven't had the balls to go faster than 70mph down Devils Dyke than I did on the 125 on ME22's, although perhaps that's more a reflection on me than the tyres  |
| -Matt- |
 -Matt- World Chat Champion
| busbar |
 busbar Two Stroke Sniffer
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| c_dug |
 c_dug Super Spammer
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| ferrisio |
 ferrisio Scooby Slapper
| Diggs |
 Diggs World Chat Champion
 Posted: 07:53 - 17 Sep 2014 Post subject: |
If you are going to take the wheels off yourself take careful note of the order of spacers/washers/chain adjusters etc. Best thing to do is place them back on the spindle as you go along so you know they will be in the right place when you put it all back together again.... ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Mirey |
| Mirey |
| zark |
 zark Trackday Trickster
| Mirey |
| iooi |
 iooi Super Spammer
| Dave70 |
 Dave70 World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
The last post was made 11 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
