New Tyres
Mirey
PostPosted: 14:55 - 13 Sep 2014    Post subject: New Tyres Reply with quote
I just bought a second hand YBR125 and it's front tyre needs replacing.
I figured I'll just get both done. I'm thinking of getting Metzeler ME22s - I can get them on ebay for £65/pair.
https://www.ebay.co.uk/itm/Motorbike-tyres-Metzeler-ME22-90-90-18-57P-RF-/121430360694?pt=LH_DefaultDomain_3&hash=item1c45d04276
https://www.ebay.co.uk/itm/Motorbike-tyres-Metzeler-ME22-2-75-18-48P-RF-/151404825771?pt=LH_DefaultDomain_3&hash=item23406e4cab
However, I've never fitted bike tyres before.
What I can't seem to find out online is that if I take it to a mechanics to get them to fit them is if I have to take the wheels off the bike myself? Would they normally charge a lot more to do the lot (e.g. I take my bike in and they do everything)
I'm not adverse to learning to do stuff like fitting a wheel, it's just that I'm a little scared if I do it myself the wheel will come off as I'm driving along (or things to that effect).
Speaking of mechanics, does anyone know of any decent ones near lewisham/greenwhich?
Cheers!
Itchy
PostPosted: 15:03 - 13 Sep 2014    Post subject: Reply with quote
You can get a ride in ride outservice.
But it will cost more £25-30 just to change the tyres.
Or you can take the wheels off 'loose wheel' service which will cost less.
Myself the last time I changed tyres I removed the brake discs and took them to a car place, they charged me £5.
Teflon-Mike
tl;dr
PostPosted: 16:57 - 13 Sep 2014    Post subject: Reply with quote
YBR I believe has tubed tyres.
Ever fixed a puncture n a push-bike?
It exaclty the same as that, just a bit bigger.
Get a couple of GOOD tyre levers off e-bay.
I reccomend this sort:-
https://i.ebayimg.com/00/s/ODAwWDgwMA==/$(KGrHqVHJBkE63VtkUY-BO0TfPqW3g~~60_57.JPG
They are long for plenty of leverage, curved so they can be hooked over the rim nicely and locked under sprocket or brake disc, and sharp eough to get uder the bead easily.
That set of three is £27, which is probaby cheaper than a ride-in-ride out service, at a fitters, IF they are prepared to fit tyres they haven't supplied. (Some wont.) Though you can buy them individually for about a tenner, and if you only really need one good one, like that for the 'wiggling' bit, a couple of plain ones that are cheaper are all you need to hold the tyre while you pry. And of course, you have them handy next time you need to change a tyre or fix a puncture.
While you you have the wheels off, though, I would be iclined to spend a little time and have a look at the front brake, and at least clean the front caliper pistons, & grease the float pins, if not replace the brake pads.
At the back, you have a drum brake; that will apreciate you knocking the brake dust out of the drum, checking or replacing the shoes, and greasing the pivots. While on the other side you have a cush-drive, with the sprocket on.
Check the sprocket & chain, if tyres be dead good chance bikes done enough miles that the chain & Sprockets are due replacement.
BUT get a set of these:-
https://i.ebayimg.com/00/s/NDEyWDM4OQ==/z/LgsAAOSwQItT8cvX/$_35.JPG
As matter of course. £9 off Wemoto e-bay, they are the rubber blocks that go in the cush-drive. Its a five minute job to swap them, no special tools necessary, and they make a WORLD of difference to the bike. They are almost always hammered to death putting slop in the drive line, which is over-looked, neglected or not kown about. BUT, new ones an transform the way the bike rides, make gear changes a heck of a lot easier & smoother, while givig your drive chain a much easier time, so it doesn't wear out as quick.
Add a Haynes manual to the list for guidance, and you are STILL probably not a lot more out of pocket than taking tyres & like to a garage, AND you'll be getting a lot more value from it, as well as learning how to look after your bike.
There is nothing there, that is particularly hard or difficult or needs much more than factory tool-kit, bar the tyre levers.
Go for it... get greasy! Its a whole added pleasure to your biking looking after your own bike, with bonus you have nicer bike to ride for the effort.
c_dug
PostPosted: 17:08 - 13 Sep 2014    Post subject: Reply with quote
The chances of getting it so wrong that the wheel falls out are next to nothing.
You might need to pick yourself up a socket set and levers as above, but DIY is almost certainly easier than you imagine. It's just lots of little jobs lined up. If I asked you to undo one bolt I doubt you'd fret over it. It is essentially just minor jobs like that all lined up.
A manual will help, if you don't have one then most halfords have an alright selection, or your local bike shop. Or if you're really strapped for cash download a copy.
Not sure where you are based but a friendly local BCFist might be willing to help you out for a cuppa tea or two. Maybe post your location.
Also, removing both wheels at the same time to bring to a tyre place will require some genius bodgineering, it can be done with bricks, wood, rope, old tyres or random junk you find in the garden, or a combination of items on that list. Or ~£50 worth of stands if you want to do it properly.
c_dug
PostPosted: 17:10 - 13 Sep 2014    Post subject: Reply with quote
Duh! You said Lewisham.
Mirey
PostPosted: 18:18 - 13 Sep 2014    Post subject: Reply with quote
Teflon-Mike wrote:
things
Thanks. Sounds like it'll be worth the effort. I did wonder how to check the brakes - I know there are indicator levels, but I can't seem to see the pads themselves.
Supposedly the chain was replaced back in February or so. It seems to be okay. I did clean/lube it today. It kept coming out dirty. I took off the cover next to the sprocket attached to the engine, and there was a ton of crap there. I cleaned it out. I think it's all in my head, but it seems to be running nice now. Though it's probably because I stuck more air in the tyres - they were are 13/25 when they should've been 25/41 Neutral
Thanks for the help guys Smile
Mirey
PostPosted: 20:46 - 15 Sep 2014    Post subject: Reply with quote
So I've got a Haynes manual, but I can't see anything in here about the cush drive or rubber blocks.
I haven't read it cover to cover but just checked through what seemed like obvious places - drive train, wheels etc.
Where do they actually live on the bike? I've tried looking around on the internet but I'm mainly finding discussions on what a cush drive is...
Mirey
PostPosted: 20:48 - 15 Sep 2014    Post subject: Reply with quote
Scrap that. It refers to them as rubber dampers on page 6-27.
This book seems pretty awesome. I never knew these things existed.
Pigeon
PostPosted: 23:32 - 15 Sep 2014    Post subject: Reply with quote
I've done the same tyres on basically the same rims / bike as the YBR twice, the first time I spent 10 hours on it. I shit you not.
Lube is your friend. Eventually I used some Couzens washing up liquid, made the job very simple.
Tyre leavers + a couple of rim protectors, 3 is a luxury, 2 is fine.
The ME22's are fantastically grippy. They don't last too well, 4k miles, but they offer so much grip in the wet and dry. Brilliant for that bike.
I did 2 winters and summers on them, still haven't had the balls to go faster than 70mph down Devils Dyke than I did on the 125 on ME22's, although perhaps that's more a reflection on me than the tyres Smile
-Matt-
PostPosted: 23:55 - 15 Sep 2014    Post subject: Re: New Tyres Reply with quote
One of those 'how long is a piece of string' questions I guess. Probably depends where you go and 'who ya know'. In Bristol where I was living last year the usual rate for ride-in/ride-out fitting was about 25-30 quid a wheel it seemed. Would be knocked down to about 15 quid a wheel if you took the removed wheels in.
That being said a non-garage 'back-garden' mechanic [previously worked for a dealership] I went to for the last year I was living there charged 10 quid a wheel ride in/ride out - and did it and other stuff a lot quicker along with a lot better service than most of the local 'garages' and 'dealerships' did.
Sure plenty of other people may of had the total opposite experience though Laughing just depends who and where you goto really. I would like to learn to do it myself, but as with a lot of workshop stuff I tend to shy away from risking messing it up most of the time Embarassed
busbar
PostPosted: 13:42 - 16 Sep 2014    Post subject: Reply with quote
I too need a tyre change on my YBR as the back tyre is looking a bit bare in the middle tread-wise.
Having struggled to find anyone local to me to supply and/or fit I have toyed with the idea of changing the tyre myself but does the wheel not need balancing afterwards?
Andy_Pagin
PostPosted: 15:05 - 16 Sep 2014    Post subject: Reply with quote
It's not a bad idea to add your location to your profile.
c_dug
PostPosted: 15:30 - 16 Sep 2014    Post subject: Reply with quote
Balancing is unlikely to make much difference on your YBR.
DrSnoosnoo
PostPosted: 16:06 - 16 Sep 2014    Post subject: Reply with quote
My concern too. I need new tyres on the CG. The rear is square ... and the front, just looks bad.
Northern Monkey
PostPosted: 16:20 - 16 Sep 2014    Post subject: Reply with quote
I didnt balance the tyres on my Yam XT125, or my Royal Enfield, and Im not dead yet
I'd probably want them balanced on the NC750x, but on something that isnt going to go much past 60mph, you'll not notice.
ferrisio
PostPosted: 00:22 - 17 Sep 2014    Post subject: Re: New Tyres Reply with quote
Did you find one btw? I'm in Forest Hill and looking too. Can do most simple jobs myself but it's nice to know who's go-to locally for something I can't sort.
BMW R1100R
Diggs
PostPosted: 07:53 - 17 Sep 2014    Post subject: Reply with quote
If you are going to take the wheels off yourself take careful note of the order of spacers/washers/chain adjusters etc. Best thing to do is place them back on the spindle as you go along so you know they will be in the right place when you put it all back together again....
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
Wonko The Sane
PostPosted: 12:43 - 18 Sep 2014    Post subject: Reply with quote
Just had the tyres swapped on the ZZR, was told there's no point in ballancing the rear as with everything going on there you'll not notice.
Front was ballanced tho, took 50g of weight!
Mirey
PostPosted: 22:35 - 18 Sep 2014    Post subject: Reply with quote
Payday on Monday. I'll post my results and potentially pictures of how the change goes sometime next week.
Mirey
PostPosted: 20:20 - 05 Oct 2014    Post subject: Reply with quote
It's definitely more involved than changing the tyres on a push bike...
zark
PostPosted: 15:16 - 06 Oct 2014    Post subject: Reply with quote
i just got a pair of those tyres on my YBR...
Roughly the same price delivered - took it to a garage to get them fitted.
They charged £70 for both fitted - standard 1 hour labour rate - and i'm pretty sure it would have taken me longer than an hour. (they didn't charge for disposal etc of the old ones, that i've been stung for on car tyres)
I didn't realise how bad the old ones were until i had these fitted - really makes a difference to the handling. Just hope they last...
Mirey
PostPosted: 09:03 - 07 Oct 2014    Post subject: Reply with quote
Yep, starting to wish I had done that, or at least got them to just change the tyres.
My front wheel is currently like this and I have no idea how to fix it:
https://www.dropbox.com/s/qo5s42z5gg1i2ee/2014-10-07%2008.54.04.jpg?dl=0
https://www.dropbox.com/s/3wxxwctpzldbn0s/2014-10-07%2008.48.27.jpg?dl=0
iooi
PostPosted: 09:35 - 07 Oct 2014    Post subject: Reply with quote
2 options.
You need to get some air in the tyre. Might need to get high PSI to seat the bead. So a trip to a garage to blow it up will help.
OR
Simply take it to a local tyre fitter and get them to finish it off for you. Thumbs Up
Dave70
PostPosted: 10:39 - 07 Oct 2014    Post subject: Reply with quote
They charged you £70 just for fitting two tyres? Shocked
wr6133
PostPosted: 10:52 - 07 Oct 2014    Post subject: Reply with quote
That's probably roll in roll out service. Loose wheels should be a hell of a lot less (my local place charges £5 per wheel).
The last post was made 11 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 134.76 Kb
