| Meshuggah |
 Meshuggah Scooby Slapper
 Posted: 09:42 - 14 Sep 2014 Post subject: Throttle body position |
Hello everyone,
so I bought this vaccum gauge to check my tbp. when I plug it in this is what happens and I can take any reading.
https://www.youtube.com/watch?v=IjgiZCrnHiY
as usual any help would be much appriociated.
thanks. ____________________ Triumph Tiger 800 2012 |
| Pete. |
 Pete. Super Spammer
 Posted: 09:46 - 14 Sep 2014 Post subject: |
You gotta tweak the dampers to stop the needles flapping about. They'll snap off like that. Apart from that the balance actually looks pretty good. ____________________ a.k.a 'Geri'
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 09:49 - 14 Sep 2014 Post subject: |
I think you are trying to do it with the revs too low - hence the fluctuations.
Assuming you have connected the tubes to the inlet stubs correctly, try it again between 1500 and 2000 rpm.
Like this. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Meshuggah |
 Posted: 19:56 - 14 Sep 2014 Post subject: |
ok this is what happened so far:
I've read in the manual that at idle the hg should be 280.
That's not the case. at idle (1320 1380) the gauge shows points into the red zone. Only if I accelerate they go up.
The manual says to not touch the screw number 1 but regulate 2 3 and 4 according to it. that;s what I tried to do at first. Then I thought that n1 may need to be turned to reach 280 at idle. I did it and nothing happened. just a slight change but it still sits in the red zone. Now I have all the 4 screw almost completely turned in. this is what happens
https://www.youtube.com/watch?v=KbtURzOVEn4
It seems they all move at the same time and with the same amount but I have no idea if it's correct . the red area states : late valve intake, mainfold leak or heat riser.
Any suggestions? Thanks. ____________________ Triumph Tiger 800 2012 |
| orac |
 orac World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 21:06 - 14 Sep 2014 Post subject: |
What's "tbp"  ____________________ Space Is Deep |
| Pete. |
 Pete. Super Spammer
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 21:24 - 14 Sep 2014 Post subject: |
Ah....didn't notice the second vid where the needles aren't flying about  ____________________ Space Is Deep |
| Meshuggah |
| Meshuggah |
| Pete. |
 Pete. Super Spammer
 Posted: 06:43 - 15 Sep 2014 Post subject: |
The lower the revs when you do the throttle balancing, the closer you'll get them - so long as the throttles aren't worn to the point that the readings shift about a lot when you flcick the throttle.
The numbers are pretty-much meaningless because they are affected by several factors, useful only as a comparative scale so you can get them all the same. That's all you're aiming for really. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| Meshuggah |
| Vincent |
 Vincent Banned
| Meshuggah |
| Pete. |
 Pete. Super Spammer
 Posted: 19:57 - 15 Sep 2014 Post subject: |
All you're trying to achieve is that they all draw the same air in when the throttle is closed against the idle stop. What position the screws are actually in doesn't matter a damn EXCEPT that if you have one screwed against the stop you could well run out of adjustment on one of the others. ____________________ a.k.a 'Geri'
| Vincent |
 Vincent Banned
| Meshuggah |
| Pete. |
 Pete. Super Spammer
| Meshuggah |
| Pete. |
 Pete. Super Spammer
 Posted: 21:25 - 17 Sep 2014 Post subject: |
TBP is the wrong terminology. I never heard it called that and it will confuse people into thinking you are on about TPS (throttle position sensor).
Throttle balancing is what you're doing. If you had carbs instead of FI it would be carb balancing.
The purpose of throttle balancing is not to make them all open at the same time - they will do that no matter what - but to adjust them to all be open the same AMOUNT and therefore produce a similar sized explosion in each cylinder which in turn will provide a smooth idle. This only really affects idle and off-idle, for wider throttle openings balancing has very little effect. ____________________ a.k.a 'Geri'
The last post was made 12 years, 32 days ago. Instead of replying here, would creating a new thread be more useful? |
