Cutting out at lights....
Tamsin
PostPosted: 11:09 - 15 Sep 2014    Post subject: Cutting out at lights.... Reply with quote
In the last few days the CG (2001, electric start, bog standard) has started to cut out every now and then at traffic lights.
Always when in first gear, engine at tickover, clutch full in, rear brake on. The engine just cuts, no jerk etc as if it was stalling on the clutch.
Its a bit of a sod having to then flick to neutral, restart and get moving again.
Any ideas folks? Very Happy
James83
PostPosted: 11:36 - 15 Sep 2014    Post subject: Reply with quote
Faulty kickstand cutout?
Jonathan A wrote: tart.
Tamsin
PostPosted: 11:38 - 15 Sep 2014    Post subject: Reply with quote
Given that it didn't come with side stand from the factory, I doubt there is a cut out....
James83
PostPosted: 11:49 - 15 Sep 2014    Post subject: Reply with quote
Next guess would be loose connection in the kill switch, assuming it came with one of those?
orac
PostPosted: 11:50 - 15 Sep 2014    Post subject: Reply with quote
dodgy clutch switch?
weasley
PostPosted: 12:03 - 15 Sep 2014    Post subject: Re: Cutting out at lights.... Reply with quote
Do you do this because it is the only way it will restart, or is it habit? If it cuts out, you should be able to stay in gear, keep the clutch in and simply thumb the starter button.
Tamsin
PostPosted: 12:31 - 15 Sep 2014    Post subject: Reply with quote
Theres no kill switch
and it will only start in neutral after said stall. In normal situations it will start in gear.
mudcow007
PostPosted: 12:32 - 15 Sep 2014    Post subject: Reply with quote
does it happen when the bike is hot or cool etc?
Tamsin
PostPosted: 13:15 - 15 Sep 2014    Post subject: Reply with quote
Well, this morning it did it within minutes of starting out, yesterday it did it after about 10 minutes of riding (after about 3 hours stood)
So I guess cold/cool-ish. But i've not been on a long ride on it in a while
PostPosted: 13:29 - 15 Sep 2014    Post subject: Reply with quote
Colour and condition of your spark plug? Have you adjusted the idle mixture, and idle speed?
Amount of free play at the clutch lever?
Tamsin
PostPosted: 13:35 - 15 Sep 2014    Post subject: Reply with quote
I have to confess that I've not done anything to the mixture since I bought the bike, nor have I pulled the plug to have a look.
I did wonder whether it may be an issue with fuelling but that doesn't explain why I need to get it into neutral before I can restart...
When you say free play, I assume you mean easy movement before it "takes up the slack" and starts to pull the clutch? Very little indeed, I'll go give it a poke on my lunch break and report back though
PostPosted: 13:51 - 15 Sep 2014    Post subject: Reply with quote
It does sound on the face of it like electrical, but a fouled plug, slow idle or well off mixture is easy to diagnose and something you should be checking for anyway since it's so easy on that bike.
DrSnoosnoo
PostPosted: 13:54 - 15 Sep 2014    Post subject: Reply with quote
On my super old CG ('81 vintage) it will cut out when it's cold out when stopped. I just increase my idle speed a touch or just keep a small amount of revs on while stopped.
map
Mr Calendar
PostPosted: 13:58 - 15 Sep 2014    Post subject: Reply with quote
Have just thought if fuelling issue, choke isn't kept on is it?
I mention as had this once on lad's 125. Just cut out at roundabout after been riding for a little while. Found out choke was pulled out (on). May be of some use or unrelated, but at least then another possible eliminated.
Tamsin
PostPosted: 14:30 - 15 Sep 2014    Post subject: Reply with quote
Nope, choke is only ever on for a short while while warming up and I get my lid & gloves on
ETA: free play in clutch lever about 15mm at lever end
Tamsin
PostPosted: 18:41 - 15 Sep 2014    Post subject: Reply with quote
I dont think I made it clear on reading back, its an intermittent thing
Tamsin
PostPosted: 19:43 - 15 Sep 2014    Post subject: Reply with quote
I'd liken it more to the ignition being turned off than a stall.
No idea about how long the plug has been on there, I've had the bike since March and not changed it.
Carvel
PostPosted: 19:49 - 15 Sep 2014    Post subject: Reply with quote
scrap it
Flatbadger
PostPosted: 19:57 - 15 Sep 2014    Post subject: Reply with quote
I had the same, my battery needed replacing. Try a good charge up first.
You're in ISIS
Tamsin
PostPosted: 21:08 - 15 Sep 2014    Post subject: Reply with quote
Right, I have some ammo for things to look at/do so fingers crossed.
Tamsin
PostPosted: 18:55 - 22 Sep 2014    Post subject: Reply with quote
Well, I gave it a damned good going over at the weekend and dealt with a number of other issues...
Found loose battery connection, did it up again good and proper and pulled the plug for a look - judging by the plug colour shes a little bit rich but not excessively so. I used a standard socket to get the plug in and out, as none of my plug sockets would fit, so I've ordered the correct one and will have a play with the mixture when I get it.
Did a decent length ride afterwards and got her nice and hot, no problems at all until I was nearly home and she did the same thing again, cut out in at the lights - also the clutch started squealing like a pig and cutting in hard, rather than progressively (I think I've sorted that issue with clutch adjustment at the lever end though)
The last post was made 12 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 113.92 Kb
