| marty tilley |
 marty tilley Derestricted Danger
| davebike |
 davebike World Chat Champion
 Posted: 08:54 - 16 Sep 2014 Post subject: |
OK why change the oil
Te oil in the tank (2 stroke oil) is total loss
The oil in the "engine" actually it is in the gear box is what I suspect you have changed should be 10/40 engine oil
The oil pump delivery can be checked by with the engine idling loosening one of the banjo bolts while holding the pump at full delivery (push the cable pulley towards the pump body )
oil should leak out
Cable should be adjusted but I can no longer remember the alinement's
Dave
Suzuki trained a very long time ago ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Taught2BCauti... |
I'm guessing that the bike has stood for a while and you wanted to make sure the CCI tank has fresh 2T oil?
I found This Article which might help.
I remember you need to check the alignment marks at full throttle, but not sure how you check the system is working, other than it uses oil and the level in the tank drops as you ride. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| _Iain_ |
 _Iain_ Banned
 Posted: 10:03 - 16 Sep 2014 Post subject: |
I'd fill tank with a litre or so of pre-mix then suck all the oil I could get out of the 2t tank with a syringe. I'd then disconnect the autolube pump and point output hose at bucket/drain tray...run bike up adding fresh 2t oil whilst holding pump flat out open.
When satisfied it's the fresh oil coming through, reconnect pump to carb/inlet and wait till no bubbles in lines. Would then drain pre-mix from tank, re-fill with petrol. Well, actually I'd just fill the thing back up to the top with straight petrol and giggle about the extra smoke for a while.
If we're talking gearbox oil, then undo sump plug, let it fall out, sump plug back in and re-fill with the amount stamped on the casing. ____________________ Please be aware that the above post may be full of complete nonsense.
| bikenut |
 bikenut World Chat Champion
| MCN. |
 MCN. Banned
| marty tilley |
| bikenut |
| Vincent |
 Vincent Banned
The last post was made 12 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
