| sgtcalle |
 sgtcalle Spanner Monkey
| andym |
 andym World Chat Champion
| Vincent |
 Vincent Banned
| Richy CB1000 |
 Richy CB1000 Trackday Trickster
| sgtcalle |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 23:16 - 17 Sep 2014 Post subject: |
Before you fill up with £20 of Motul, whip off the clutch cover. google something along the lines of 'worn motorbike clutch basket' and you'll see the the wear given by the plates. The sticky out bits called 'tangs' are what we're after. Examine where they work along the basket, dents or grooves is bad. Remember there are a matching set on the inner bit of the basket, but you will need to undo the 6 nuts, and withdraw your assembly, to get a peek at her inner workings, so to speak. But a quick butcher's at her outer appearance should give you a rough idea if she's a go'er or not.
Someone will be along shortly to correct me as to the exact configuration of your machine, but generally this works for me. |
| Vincent |
 Vincent Banned
 Posted: 12:02 - 18 Sep 2014 Post subject: |
But before you do ANY of that, clean and lube the clutch push rod.
The hydraulic slave cylinder is located on the left side of the engine.
You'll need to remove the left hand side panel to get at it. There are three bolts holding the slave cylinder in place. One of them is very long.
Undo them and remove the slave, you may find it has a paper gasket under it which serves no useful purpose I can see, replace it or not as you wish, I didn't.
From this point be very careful NOT to pull the clutch lever in
Pull out the clutch push rod which runs right the way through the engine. You'll find one end of it is all corroded and horrible. Clean it up with WD40 and wire wool, lightly grease it with either lithium or red rubber grease (the latter would be best) and put it back in the other way round.
Replace the slave cylinder.
This would also be a good time to bleed some fresh hydraulic fluid through from the master cylinder. It gets serially ignored and in all probability has the original fluid in, along with a deep layer of sludge.
If that doesn't fix it, look at the clutch itself next.
Changing clutch plates just needs an 8 and 10mm socket as I recall (8 to remove the cover, 10 to remove the pressure springs)
I managed to get my notched clutch basket off without special tools, just a strap wrench. You can lock up most of it by jamming a denim rag in the gears. It has a normal hex nut in the centre of the clutch basket, not a castle one. I just whizzed the notches off mine with a grinding stone and put it back on, depends how bad they are.
If you have access to an impact wrench, removing the basket is very simple, just burp it off.
You may even get a reasonable view of the "fingers" on the clutch basket by looking through the oil filler hole with a pen torch.
If you need to do a clutch rebuild, I found a genuine honda clutch service kit from david silvers was cheaper than an aftermarket set of plates and included new springs and the cover gasket. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sgtcalle |
There is a gap of 1 year, 26 days between these two posts... |
| thesambaman |
 thesambaman L Plate Warrior
The last post was made 10 years, 345 days ago. Instead of replying here, would creating a new thread be more useful? |
