Honda VFR750 Clutch question
sgtcalle
PostPosted: 20:37 - 16 Sep 2014    Post subject: Honda VFR750 Clutch question Reply with quote
Hi all, I recently picked up a 97 Honda VFR750. When pulling away the clutch judders at the end of the lever travel when it engages, and slips slightly when powering on in higher gears. A handful of throttle stops the judder, and it gets worse as the bike warms up.
I am planning on replacing the clutch springs and plates, before I do so is there any other reason I may have these symptoms I should be aware of?
Also, the haynes manual states there is a special Honda tool involved, do i need this just to replace the plates and springs, or is this tool to remove the whole clutch basket.
Thanks.
CBR600F '02
Manchester
andym
PostPosted: 21:08 - 16 Sep 2014    Post subject: Reply with quote
Mine is an old 93 model and it doesn't judder at higher revs.... the only time I've found it sounds or feels different is if the oil is getting low then it feels rough pulling away between 2-4k rpm, but a litre of oil sorts that one out.... but then my biting point is around 1/3 - 1/2 lever travel
Richy CB1000
PostPosted: 07:55 - 17 Sep 2014    Post subject: Reply with quote
Check the oil level plus quality of first. As said plate thickness check, plus spring tension torque check.
What I've done in the past on an almost worn one is remove the fibrous plates rotate them round a notch or two so they're different orientation than before, re torque the springs.
Won't fix completely but will get you through a couple of pay days, don't rag it until it's really warmed up 15-20 mins plus will help.
CB1000 Big One, Triumph T3 Trophy 900
sgtcalle
PostPosted: 21:28 - 17 Sep 2014    Post subject: Reply with quote
Thanks all, I had heard the clutch basket wear could be a cause, but I'll drop the oil and see if that helps.
CBR600F '02
Manchester
Major Doss
PostPosted: 23:16 - 17 Sep 2014    Post subject: Reply with quote
Before you fill up with £20 of Motul, whip off the clutch cover. google something along the lines of 'worn motorbike clutch basket' and you'll see the the wear given by the plates. The sticky out bits called 'tangs' are what we're after. Examine where they work along the basket, dents or grooves is bad. Remember there are a matching set on the inner bit of the basket, but you will need to undo the 6 nuts, and withdraw your assembly, to get a peek at her inner workings, so to speak. But a quick butcher's at her outer appearance should give you a rough idea if she's a go'er or not. Thumbs Up
Someone will be along shortly to correct me as to the exact configuration of your machine, but generally this works for me.
PostPosted: 12:02 - 18 Sep 2014    Post subject: Reply with quote
But before you do ANY of that, clean and lube the clutch push rod.
The hydraulic slave cylinder is located on the left side of the engine.
You'll need to remove the left hand side panel to get at it. There are three bolts holding the slave cylinder in place. One of them is very long.
Undo them and remove the slave, you may find it has a paper gasket under it which serves no useful purpose I can see, replace it or not as you wish, I didn't.
From this point be very careful NOT to pull the clutch lever in
Pull out the clutch push rod which runs right the way through the engine. You'll find one end of it is all corroded and horrible. Clean it up with WD40 and wire wool, lightly grease it with either lithium or red rubber grease (the latter would be best) and put it back in the other way round.
Replace the slave cylinder.
This would also be a good time to bleed some fresh hydraulic fluid through from the master cylinder. It gets serially ignored and in all probability has the original fluid in, along with a deep layer of sludge.
If that doesn't fix it, look at the clutch itself next.
Changing clutch plates just needs an 8 and 10mm socket as I recall (8 to remove the cover, 10 to remove the pressure springs)
I managed to get my notched clutch basket off without special tools, just a strap wrench. You can lock up most of it by jamming a denim rag in the gears. It has a normal hex nut in the centre of the clutch basket, not a castle one. I just whizzed the notches off mine with a grinding stone and put it back on, depends how bad they are.
If you have access to an impact wrench, removing the basket is very simple, just burp it off.
You may even get a reasonable view of the "fingers" on the clutch basket by looking through the oil filler hole with a pen torch.
If you need to do a clutch rebuild, I found a genuine honda clutch service kit from david silvers was cheaper than an aftermarket set of plates and included new springs and the cover gasket.
sgtcalle
PostPosted: 10:29 - 21 Sep 2014    Post subject: Reply with quote
Thank you all, very informative replies. I'll let you know how I get on.
CBR600F '02
Manchester
There is a gap of 1 year, 26 days between these two posts...
thesambaman
PostPosted: 16:46 - 17 Oct 2015    Post subject: Reply with quote
Very helpful thread as I have just bought a '93 VFR750 with the same problem. Can you tell me how you got on with this problem pls?
Chris
The last post was made 10 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 66.12 Kb
