| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:58 - 16 Sep 2014 Post subject: Running a little hot - Oil Cooler replacement? |
My bike's running a little hotter than usual lately, I had thought it due to summer weather but now the weather has got cooler the bike's still throwing out more heat than I recall being normal earlier in the year.
Earlier this year I changed the oil cooler for one that didn't leak, it was a bit tatty and surface corrosion and now I'm wondering if I should be looking at replacing it.
Cornwall Kawasaki want £400 for the cooler on it's own, and it's probably a good idea to fit new hoses to it to do the job properly.
I've had a good look round the web and I've not been able to find anywhere making a pattern part for the ZZR600E (which surprises me) and all the ones on e-bay look just as bad as mine, if not worse.
I still have the old one I took off, anyone any ideas where to find a cooler / get one made around Manchester? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Itchy |
 Itchy Super Spammer
 Posted: 23:26 - 16 Sep 2014 Post subject: |
Have you checked your radiator fluid levels?
My CBR ran hot when it was only half filled.
Second an oil cooler isn't exactly a complex bit of kit, the only important bit is the collar which fits onto the engine and is plumbed in.
My old CBR had a 918 fireblade radiator on it. It worked fine. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Kickstart |
 Kickstart The Oracle
| orac |
 orac World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 05:52 - 17 Sep 2014 Post subject: |
Any possibility of air in the system? = Air is a insulator, so the fluid can't transfer enough heat.
OR, there is a pressure leak, and since you did not see anything wet, I'd say the filler cap might be leaking. The cooling system is pressurized = the water can get above 100°C with no problem yet not being boiling.
Extra cooling power is not the way to go. If you get too much cooling power the engine won't never work well, at its operating temperature, which will cause reduction of its life time.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Wonko The Sane |
 Posted: 08:56 - 17 Sep 2014 Post subject: |
I'm basing things on my feet getting a bit hotter than usual of late
The oil cooler that's on doesn't leak but doesn't look great so I'm assuming it's not doing its job quite as well as it should so aiming to fit a like for like replacement, not a larger cooler
The cooling system is topped up but I've not checked for air etc but I've not had any reason to worry about it ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| Vincent |
 Vincent Banned
| The Artist |
 The Artist Super Spammer
| _Iain_ |
 _Iain_ Banned
 Posted: 10:05 - 17 Sep 2014 Post subject: |
| Itchy |
 Itchy Super Spammer
 Posted: 10:25 - 17 Sep 2014 Post subject: |
Could it be that schools have started and the roads are more clogged up?
Around July August riding into Manchester city centre took 15 minutes.
Engine temp from this was around 78-92.
it now takes 20 minutes a barely recognisable amount of time but it involves a lot more high revs low gear filtering.
Engine temp now hovers around 95-103. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| chris-red |
| mentalboy |
 mentalboy World Chat Champion
| Casper |
 Casper World Chat Champion
The last post was made 12 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
