Ns125
dec3326
PostPosted: 13:00 - 20 Sep 2014    Post subject: Ns125 Reply with quote
Hi all just after a few suggestions please iv got a honda ns125 which was not running quite right and would cut out when it got warm ... The engine stated to get a bit noisy so iv rebuilt all top end and now it fires first kick and will sit there ticking over like a dream will rev up and ride fine soon as it starts to get warm tho it starts to pop and fart even had a few back fires out of it then won't run agin until it's cooled down abit has anyone got any ideas what could be causing this so far iv changed piston kit little end bearing ... New carb ... New Coil ht lead and cap and new plug also new rectifier ..... Only other thing I can think of is ignition pick up or cdi unit but iv
Carried out wiring checks to these as per manual and they all check out fine unless there's abit of resistance when things are getting warmer ???
PostPosted: 13:04 - 20 Sep 2014    Post subject: Reply with quote
The only time I have had similar issues on a bike it has been ignition related.
As such I would suggest sticking a strobe light on it and checking if the ignition timing does anything strange as it gets warm.
dec3326
PostPosted: 13:11 - 20 Sep 2014    Post subject: Reply with quote
Thanks will try that .... Is there any way you can ajust the timing tho if it's playing up when getting hot .... It's not going to be like a old
Car where ya can just move dizzy round abit to sort it all out is it or is it some thing simple like that .... Never really messed with timing on these just lined marks back up on flywheel when rebuilding that's about it lol ..... Thanks dec
PostPosted: 13:15 - 20 Sep 2014    Post subject: Reply with quote
While you can probably do bodges (say, using an offset woodruff key) to change the timing I would say that if the timing is going out when hot then the cdi is faulty and any timing changes could be quite random.
Not saying this is the problem, but something to check first and (assuming you have a timing light) should be easy to check.
dec3326
PostPosted: 13:21 - 20 Sep 2014    Post subject: Reply with quote
Nice one thanks will get a light and and cdi and have another play thanks again dec
The last post was made 12 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 44.78 Kb
