Hello & Van Van issue
Remoulay
PostPosted: 14:56 - 21 Sep 2014    Post subject: Hello & Van Van issue Reply with quote
Hi! New to the forum...
I've had my 2003 Van Van for about a month now and this problem has only just started happening. (Cold?...)
It will start fine with choke on, I'll leave it for a minute, turn the handlebars to start riding and it will cut!
So I start it again and turn the handlebars hard left & right to see if that would affect it at all? Didn't seem to but it would still cut out. The only other time it has cut out was when I was slowing down to take a turn, when beforehand I had been riding without stop for about 15 mins straight.
My boyfriend recommended I get a new spark plug (7.80 Shocked). I'll change that next weekend and see how I go.
Any help/insight greatly appreciated.
Thanks Thumbs Up
deadwolf
PostPosted: 15:25 - 21 Sep 2014    Post subject: Reply with quote
Have you tried checking the clutch freeplay and cable? Might need some adjustment.
Motorsapien Art
CaNsA
PostPosted: 15:31 - 21 Sep 2014    Post subject: Reply with quote
Do you turn the choke off?
Remoulay
PostPosted: 15:32 - 21 Sep 2014    Post subject: Reply with quote
Yep. But that was because it was being fairly stiff. I sprayed some GT85 down the cable but it tightens up again within a few days.
Remoulay
PostPosted: 15:33 - 21 Sep 2014    Post subject: Reply with quote
Yes Smile
PostPosted: 19:30 - 21 Sep 2014    Post subject: Reply with quote
If you ask this again in the Workshop section then you'll get more helpful responses, and also a reply from Teflon Mike.
nowhere.elysium
The Pork Lord
PostPosted: 19:42 - 21 Sep 2014    Post subject: Reply with quote
What sort of speed is it idling at before it dies?
Remoulay
PostPosted: 09:21 - 22 Sep 2014    Post subject: Reply with quote
Ok, will do thanks Smile
It idled slowly at first, so I turned the idle speed up. It sits at 1600 rpm now. But when it cuts out, it does cut out at idle speed. Confused
PostPosted: 13:25 - 23 Sep 2014    Post subject: Reply with quote
https://www.ebay.co.uk/itm/NGK-Replacement-Spark-Plug-SUZUKI-125cc-RV125-Van-Van-K4-K5-03-No-1275-/360471674874?pt=UK_Motorcycle_Parts&hash=item53edc93ffa
Cheaper here for a plug, however I doubt thats your issue, if it is cutting out when you turn your bars I'd have a look at the routing of the choke cable see if it is being pulled.
dandelion
PostPosted: 16:00 - 24 Sep 2014    Post subject: Reply with quote
Google for vanvan forums and join the crew.
There's so much info there to help out and some members know their vvs inside out. I know nothing but have always found the support great.
The last post was made 11 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 65.39 Kb
