Kawasaki Z750 Gear Slipping
rinckley
PostPosted: 11:59 - 22 Sep 2014    Post subject: Kawasaki Z750 Gear Slipping Reply with quote
I have a 2008 Z750.
Its started to feel a bit like its slipping in and out of gear rapidly then it will settle back into the gear after a second or so.
The problem happens on acceleration normally in the lower gears at about 7-8rpm. But it will happen in 6th gear on acceleration if even a slight bump is hit. Feels and sounds a bit like it does if you hit the end of the rev range.
Does anyone have any idea what this could be?
Mod 1 & Mod 2: Passed October 2012
Bike: Suzuki SV650
sickpup
Old Timer
PostPosted: 12:06 - 22 Sep 2014    Post subject: Reply with quote
Is the clutch slipping?
Conzar
PostPosted: 12:09 - 22 Sep 2014    Post subject: Reply with quote
Sounds like the clutch is slipping as above!
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
weasley
PostPosted: 12:48 - 22 Sep 2014    Post subject: Reply with quote
Or the chain jumping?
Taught2BCauti...
PostPosted: 15:34 - 22 Sep 2014    Post subject: Reply with quote
Something to do with the clutch I bet. Possibly worn or distorted plates, damaged cage, or friction plates contaminated by using the wrong oil!
A mate of mine used car engine oil in a motorbike and got similar results after a while. Car oil has friction modifiers and additives that bugger the clutch plates.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 15:53 - 22 Sep 2014    Post subject: Reply with quote
Oooooor, incorrectly adjusted clutch, hence the slip.
I use car oil in my bike, does it slip, no it does not.
rinckley
PostPosted: 17:16 - 22 Sep 2014    Post subject: Reply with quote
My mechanical knowledge extends to adjusting the chain and changing the oil and filter which i did about 6-8 weeks ago, could this be the problem then? Is this an easy thing to sort?
Bike: Suzuki SV650
RhynoCZ
PostPosted: 17:20 - 22 Sep 2014    Post subject: Reply with quote
Have you ever had a bicycle? It's the same thing. Adjust it with the cable adjuster on the lever, you'll know what to do. There should be a small free play in the lever, when it's correctly adjusted, meaning the pull mechanism in the clutch lid does not move when you move the lever a bit. Smile
The last post was made 12 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 56.39 Kb
