Valve Clearance Bandit 600
Az
PostPosted: 08:36 - 23 Sep 2014    Post subject: Valve Clearance Bandit 600 Reply with quote
How long does take it take to do the valve clearance on a Bandit 600?
The reason for asking is, that I've been given two quotes by two different mechanics. One saying it'll take 4hours (at £40/hour) and the other say it will only take 1 hour (£30/hour).
That's quite a difference in time, so is one taking me for a ride by claiming it'll take 4hours? Or is the mechanic who said it'll only take him an hour underestimated the work needed doing?
mudcow007
PostPosted: 08:52 - 23 Sep 2014    Post subject: Reply with quote
have a go your self, it really is piece of piss
the rocker gasket is rubber so you just reuse it, set of feeler guages 10mm ring spanner, long nose pliers (to adjust valve) an some sockets
done - an i rate my self just slightly higher in mechanical competence than jizzbunny
a few hours to do your self
whip tank off
plugs out, rocker off thats it
nowhere.elysium
The Pork Lord
PostPosted: 10:03 - 23 Sep 2014    Post subject: Reply with quote
Valve clearances on a Bandit 6 are insanely easy to do. No shims required, just patience, feeler gauges, spanners and a thin bladed screwdriver.
DrSnoosnoo
PostPosted: 10:12 - 23 Sep 2014    Post subject: Reply with quote
Az, like I said in Wales. Get a Haynes and have a sit for a weekend. You can manage it Smile
A100man
PostPosted: 11:11 - 23 Sep 2014    Post subject: Re: Valve Clearance Bandit 600 Reply with quote
An honest mechanic charging 30 an hour. Where are you living - The Punjab ?
Az
PostPosted: 15:50 - 23 Sep 2014    Post subject: Reply with quote
But for £30 I will only be without a bike for an hour rather than a whole day/possibly weekend Smile
+ I'm no longer at my mums, so I don't have a garage to work in.
Az
PostPosted: 15:57 - 23 Sep 2014    Post subject: Re: Valve Clearance Bandit 600 Reply with quote
Vale Onslow, the mechanics a sound guy (Mick) and it's looking like that they don't try and overcharge you either.
mudcow007
PostPosted: 16:01 - 23 Sep 2014    Post subject: Reply with quote
will deffo take longer than an hour
maybe 1 1/2 at very least!?
seat, tank an rocker removal an refit will take 40 odd mins being careful etc....
Bezzer
PostPosted: 17:41 - 23 Sep 2014    Post subject: Reply with quote
and a bit longer if it's still got the PAIR system fitted as it's a Mk2. It's an 8mm ring spanner you need for the locknut not a 10mm btw.
PostPosted: 17:49 - 23 Sep 2014    Post subject: Reply with quote
It took me maybe 2-3 hours to get one of the cam cover bolts out on one 600 I owned. If the guy says he can do Bandit valve clearances in an hour at £30/hr, get him to do it for a fixed price and win win win.
J.M.
PostPosted: 17:55 - 23 Sep 2014    Post subject: Reply with quote
Just make sure to be clear on whether their prices are to check the clearances or check&adjust.
2004 R1 & 2018 XSR900
It is not a hard job, but more than an hours work. 4 hours sounds a bit long.
Disconnect and remove tank, remove rocker cover (swearing loudly if you find the previous owner has stripped the thread for one of the bolts), set the engine to the appropriate position and check the valves for 2 cylinders (ie, exhaust on one and inlet on another), turn crank half a turn and repeat, etc.
Problem comes with the oddities. Can't remember on the 600 but at least once I have had to remove the coils on a Bandit to get the rocket cover off (and the thread in the frame for the bolt holding the coil on is weak). And getting the cover off from under the throttle cables can be a pig. Rocker cover gasket is reusable but locating it can take a few attempts.
PostPosted: 18:20 - 23 Sep 2014    Post subject: Reply with quote
Not much difference between check and adjust when you have screw & locknut valves JM.
Keith, yeah the coils have to come off to get the rocker cover off if you want to have any knuckles left. PAIR system too on the mk2 but you can block them off quite easily.
The last post was made 11 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 79.51 Kb
