| Az |
 Az World Chat Champion
| mudcow007 |
 mudcow007 World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
 Posted: 10:12 - 23 Sep 2014 Post subject: |
Az, like I said in Wales. Get a Haynes and have a sit for a weekend. You can manage it  ____________________ I'm Sam; Northern, Ginger, Lover
Did have: '95 ZZR600 '83 CG125 '97 ZZR1100 '15 Hypermotard 821 SP Do Have: '10 ZX10R |
| A100man |
 A100man World Chat Champion
| Az |
| Az |
| mudcow007 |
| Bezzer |
 Bezzer World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 17:49 - 23 Sep 2014 Post subject: |
It took me maybe 2-3 hours to get one of the cam cover bolts out on one 600 I owned. If the guy says he can do Bandit valve clearances in an hour at £30/hr, get him to do it for a fixed price and win win win. ____________________ a.k.a 'Geri'
| J.M. |
 J.M. World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 17:55 - 23 Sep 2014 Post subject: |
It is not a hard job, but more than an hours work. 4 hours sounds a bit long.
Disconnect and remove tank, remove rocker cover (swearing loudly if you find the previous owner has stripped the thread for one of the bolts), set the engine to the appropriate position and check the valves for 2 cylinders (ie, exhaust on one and inlet on another), turn crank half a turn and repeat, etc.
Problem comes with the oddities. Can't remember on the 600 but at least once I have had to remove the coils on a Bandit to get the rocket cover off (and the thread in the frame for the bolt holding the coil on is weak). And getting the cover off from under the throttle cables can be a pig. Rocker cover gasket is reusable but locating it can take a few attempts.
| Pete. |
 Pete. Super Spammer
 Posted: 18:20 - 23 Sep 2014 Post subject: |
Not much difference between check and adjust when you have screw & locknut valves JM.
Keith, yeah the coils have to come off to get the rocker cover off if you want to have any knuckles left. PAIR system too on the mk2 but you can block them off quite easily. ____________________ a.k.a 'Geri'
The last post was made 11 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
