Anyone able to 3d print a helicopter part?
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
mattd
PostPosted: 08:37 - 26 Sep 2014    Post subject: Reply with quote
What model helicopter?
Professional Hobo
nowhere.elysium
The Pork Lord
PostPosted: 08:57 - 26 Sep 2014    Post subject: Reply with quote
Sorry, I forgot to answer the PM. Does the part need to flex at all, or is it just something that slides on to two pins? I only ask because it may be faster/neater to just lasercut it from some other material.
The Artist
PostPosted: 13:04 - 26 Sep 2014    Post subject: Reply with quote
Are these not the socket parts of 2 ball and socket type joints? They usually pop onto the balls of the rotor and the swashplate.
https://cdn.instructables.com/FGL/2OCN/H3HCLCMC/FGL2OCNH3HCLCMC.LARGE.jpg
In which case, 3d printing might not be possible as they have to be exactly the right size or it will either break or fall off or if the plastic is flexible enough, may just become really stiff.
Common RC heli parts are cheap. Got a model no.?
Skudd
PostPosted: 13:37 - 26 Sep 2014    Post subject: Reply with quote
These parts are common to fail and usually sub £60 choppers come with spares as well as spare blades.
WD Forte
PostPosted: 18:50 - 26 Sep 2014    Post subject: Reply with quote
I have small CNC mill and as it looks a straightforward part
I could have a go at milling some out if you give me the dimensions
The smallest end mill I currently have is 3mm as I've mainly
been cutting PCBs with it
but I'm guessing from the pic a 3mm bit may be OK for that.
I have some 3mm plastic sheet here but don't ask me what variety
ABS/polywhatsit/whatever as I found it on the street but used it make a throttle lock so its fairly tough.
If you want fancy high grade stuff, you'll have to buy some
Edit
Assuming its not thicker than a pound coin which I measure at 3.2mm
the plastic I have is 3.7mm so thats sorted
I just need the hole diameter ( =>3mm would be sweet)
Pitch between centres
overall length and thickness and neck thickness and I'll have a go.
bikers smell of wee
c_dug
PostPosted: 00:52 - 27 Sep 2014    Post subject: Reply with quote
I may, big may, be able to get you some genuine ones, measurements would be useful.
It should fly fine with just one in place though, lots of companies used to sell them with two, then cut down to one. If it still has one dogbone in place and doesn't fly correctly I would suspect the pin that the blades pivot on has either broken or come loose. Worth checking that before anybody goes to the hassle of making you one.
(I base the above on having sold those sorts of helicopters for ~5 years prior to my current job)
c_dug
PostPosted: 00:58 - 27 Sep 2014    Post subject: Reply with quote
This is the sort I spent a long time flying:
https://www.menkind.co.uk/media/catalog/product/cache/1/image/800x/9df78eab33525d08d6e5fb8d27136e95/4/2/42070a_2.jpg
You can see it only comes with one.
WD Forte
quick pic of dimensions I need
Already done the vector drawing but need to get the dimensions right
before creating the tool paths.
the height looks similar to the pound coin but need some
verification on this too
https://oi57.tinypic.com/2reqrgp.jpg
bikers smell of wee
The Artist
PostPosted: 02:05 - 27 Sep 2014    Post subject: Reply with quote
Any technical drawer will be have a seizure right now. Can you at least post a ruler in shot or something!
c_dug
PostPosted: 09:18 - 27 Sep 2014    Post subject: Reply with quote
Iirc that hole isn't just a hole, as in the internal sides sides aren't flat, it's rounded to suit the ball it goes on to.
WD Forte
PostPosted: 12:42 - 27 Sep 2014    Post subject: Reply with quote
'Technical drawers' can go fuck themselves
I'm just trying to help a guy out here
It was late, quick pic ok?
Jeez, everyone's a critic
BTW Its fuckin Draughtsmen not technical fuckin drawers
I gotta fuckin flouncy fuckin feelin comin on here
is that what you want?
is it?
c_dug
if it is a ball and socket arrangement then I'm out
the pic I looked at showed a simpler easy to carve thing
with straight through holes
Now stand back.
further...
a bit more....
give me room to mince off in high dudgeon
bikers smell of wee
The Artist
PostPosted: 13:32 - 27 Sep 2014    Post subject: Reply with quote
is it?
Go on then.
lihp
PostPosted: 14:12 - 27 Sep 2014    Post subject: Reply with quote
You haven't even used a datum line. Tut Tut
nowhere.elysium
The Pork Lord
PostPosted: 21:08 - 27 Sep 2014    Post subject: Reply with quote
Rounded like a U, or does it contract again at the mouth, like a C?
c_dug
PostPosted: 21:50 - 27 Sep 2014    Post subject: Reply with quote
Open on both sides. Sort of like taking a tennis ball and cutting the top and bottom off.
WD Forte
PostPosted: 22:19 - 27 Sep 2014    Post subject: Reply with quote
Ahh shit
Did the drawins in pornographic protection and all
even isoseptic protection too, just in case.
I even coloured em in with crayons.
Thassit ! no more pretending to be nice.
Besides, I got something new in the basement needs to put the lotion on its skin
bikers smell of wee
Ichy
PostPosted: 00:55 - 28 Sep 2014    Post subject: Reply with quote
EDIT:
I posted a really pissy reply to this but changed my mind.
You can but 10 off ebay for about £2.50. I posted a link but why should I put the effort into it if the OP can't be arsed?
The last post was made 12 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 133.38 Kb
