Author |
Rogerborg |
 Rogerborg nimbA
 Posted: 08:18 - 27 Sep 2014 Post subject: How would you stubby this can? |
Bought on a whim, a standard, dented end can with a welded on cap.
https://i57.tinypic.com/2cna8ts.jpg
Suggestions are welcome for re-attaching or replacing that end cap after stubbying it, or to be more precise, re-joining the cut exhaust at any point.
Hacksaw, angle grinder, riveter, silicone gloop, metal tape and patience is available and I don't give a stuff about how it looks, as long as it's more or less gas tight. The original will be going back on for MOTs and sale.
I don't plan to re-weld it to within fish finger of a sprocket as this is a DIY garage project for funsies. I mean, a stick welder is available but I can't weld thin sheet with it - I'm no BodyGuard.  ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
Fisty |
 Fisty Super Spammer
Back to top |
Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 08:49 - 27 Sep 2014 Post subject: |
I also wouldn't bother. I don't really like stubby cans. ____________________ My Flickr |
Back to top |
Rogerborg |
 Rogerborg nimbA
 Posted: 08:56 - 27 Sep 2014 Post subject: |
But if you were to bother...
To forestall the "Y U..." Zeitgeist, the whole thing including the bendy link pipe cost less than a separate new link pipe, so worst case I can just chop the can off, fit a slip on and still come out ahead of the game. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
Wafer_Thin_Ham |
Back to top |
nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 09:01 - 27 Sep 2014 Post subject: |
Back to top |
_Iain_ |
 _Iain_ Banned
 Posted: 09:57 - 27 Sep 2014 Post subject: |
I know how you lot like paint diagrams,
https://i.imgur.com/zSNUA9a.jpg
Dremel cut the edge of the weld.
Rip all the internals out, then there'll be nothing for the bolts to hit. Ought to be able to be done with nothing but a dremel, a big box of cutting discs and a drill w/8mm bit.
I'd probbabbly then bend the edge of the open can end inwards slightly to allow it to slot inside the weld line & grind the inside of the weld line out to allow the end cap to slot on. Would need dremel for this really, but it'd make for a much better seal.
If you took your time it might come out looking pretty decent.
Oh and before the screams of potato, moron etc, micron produced cans that were held together with a simmilar principle;
https://www.micronexhaust.com/store/images/01canistersend.jpg ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
kramdra |
 kramdra World Chat Champion
Back to top |
Fisty |
 Fisty Super Spammer
 Posted: 10:09 - 27 Sep 2014 Post subject: |
Potato.
The micron cans had end caps held on with cap heads, not stud bar going all the way through. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
Back to top |
_Iain_ |
 _Iain_ Banned
Back to top |
Rogerborg |
 Rogerborg nimbA
Back to top |
Fisty |
 Fisty Super Spammer
 Posted: 10:48 - 27 Sep 2014 Post subject: |
As the innards will look not too dissimilar to this
https://www.bikersoracle.com/jaws/myPictures/exhaust11.jpg
Without stripping the whole thing down you will need some mighty long drill bits to get through the internal baffles etc.
Potato. ____________________ Quietly and consistently taking the piss.
Back to top |
Vincent |
 Vincent Banned
Back to top |
_Iain_ |
 _Iain_ Banned
Back to top |
Fisty |
 Fisty Super Spammer
Back to top |
_Iain_ |
 _Iain_ Banned
 Posted: 14:19 - 27 Sep 2014 Post subject: |
Fisty wrote: | my crystal ball is a little cloudy lately. |
Seems to work well enough to tell what's on the inside of Mr Borgs can though doesn't it?
Fisty wrote: | The picture you have shown is a riveted, rebuildable can. |
Pic is the KTM can. Has a whacking great big plate in the middle much as you've shown in your picture, which was removed with a metal pole and a big hammer. I fully grasp the concept of a can that's got welded on end caps
I'll bet the internal bit is only welded in a few places & that said weld can be damaged either with dremel discs or a drill enough that you'd be able to smack em out. Either that or with both caps off cut one baffle plate out & stubby the end with the most stuff in it...i.e remove plate A1 and use the section of sleeve from the plate after that forwards.
Fisty wrote: | The only way to really do it is cut the caps off, gut it, cut it to length, fit a straight through tube and new wadding, and re weld it. |
Well yes, that's the ideal way. Also precisely what I did with said KTM cans. However part of the breif was no welding wasn't it? Bending it to a point whereby one could rivet it would be awkward..
Fisty wrote: | Dremel the cap off? That will take some time and A LOT of dremel cutting discs. |
Again, agree. Got fed up after about 15mins on Paddys stubby GSXR can before deciding bollocks to the finish & going at it with an angle grinder, but Borg may have patience
https://img4.wikia.nocookie.net/__cb20130914193752/trollpasta/images/8/87/Scary-potato.jpg
Edit, Potato ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
P. |
 P. Red Rocket
 Posted: 14:52 - 27 Sep 2014 Post subject: |
Wouldn't stubby, would just cut the end exit bit off and make the hole exceptionally wide at the end of the can.  |
Back to top |
G |
 G The Voice of Reason
Back to top |
Robby |
 Robby Dirty Old Man
Back to top |
G |
Back to top |
gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 16:11 - 27 Sep 2014 Post subject: |
Looking at fistys pic, I would cut the end off with a hacksaw or very carefully with a grinder ( whichever you can get the straightest cut with...)
Then I would start to cut the sleeve of the can down bit by bit until you hit the metal plates visible in the pic
Pick a plate ( or a can length ) and finish the sleeve flush with this plate.
You can use high temp silicone etc between the plate and the outer sleeve to gas tight it - just finger it smooth with the end plate before it sets.
Put the end cap in place temporarily and mark the inner exhaust diameter on the end plate with a marker, and proceed to drill a lot of holes around its circumference. If you cant be bothered to dremel or file to a decent finish then make it 10mm bigger so it cant be seen through the end cap.
To replace end cap I would drill 3-4 holes in the end of it and bolt it to the plate inside the exhaust as the micron ones do.
If the cuts are nice and square and the weld is still in place you probably wont be able to tell its been done as the inside is gas-tights you wont get the tell-tale carbon streaks where its leaking.
If you want to GUT it totally the easiest way is to cut it at the base nice and square BEHIND the weld.
Pull the outer sleeve off, pull the packing out of the way and then chop off the pipe that is welded to the base of the can.
This should leave you with an empty can, and the base...
If you carefully inspect the base you should be able to carefully grind away enough weld ( and a small part of the outer skin that was left ) and have the outer sleeve push back on ( after cutting to desired length ).
A good smear of exhaust paste will ease the skin back on and also help to gas-seal it. Then go round with a drill and a riveter to keep it in place. I find it easiest to do 1 rivet - then one 180 degrees to that, then 2 at 90 so that you can pull the sleeve onto the base and keep it square, if you set off putting a river every inch or two one after the other its easier to mis-align the can |
Back to top |
Rogerborg |
 Rogerborg nimbA
 Posted: 17:55 - 27 Sep 2014 Post subject: |
Interesting stuff, thanks all.
It'll come down to what's actually inside the can which I won't know until I start hacking.
£38 delivered, by the way, and it costs £55 just for a new link pipe, so I'm not too fussed if I keep cutting until there's nothing left.  ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
Clanger |
 Clanger Stirrer
 Posted: 19:04 - 27 Sep 2014 Post subject: |
Personally I'd give it to my mate Big Steve, and get him to sort it. Then when he's finished, I'd give it to my mate Grizz and get him to polish the fury out of it. Then I'd give it to my mate JD and get him to put it back on the bike...all this would cost me a bottle Southern Comfort - 'cos my mates love me...  ____________________ Be who you are and say what you feel, because those who mind don't matter, and those who matter won't mind - Dr. Seuss |
Back to top |
Sload |
 Sload World Chat Champion
 Posted: 19:32 - 27 Sep 2014 Post subject: |
Cut it, gut it and have it re welded by someone that can for best results. Ill say Ians idea would work fine too, plenty of things retained with tie bars but as with anything the more effort you put in then generally the better the results  ____________________ Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx |
Back to top |
Rogerborg |
 Rogerborg nimbA
 Posted: 19:55 - 27 Sep 2014 Post subject: |
I don't want to gut it completely as I'm not sure if the GS runs closed loop (using the O2 sensor) all the time, or if it goes to an open loop fixed mapping at high rpm / throttle, which is likely to run lean with a straight through pipe.
I'm only considering doing it at all since I'm mostly using it for a commute where it's barely off idle most of the time, and it's dangerously stealthy. It'd be the Hun in the sun, if we had sun up here. ____________________ Biking is 1/20th as dangerous as horse riding.
Back to top |
The last post was made 10 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
