FTP sorted Firewall/speed issues now.
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
PostPosted: 12:28 - 27 Sep 2014    Post subject: FTP sorted Firewall/speed issues now. Reply with quote
Edit ignore all this, down to the bottom please for firewall speed issues!
Right I bought one of those HP Proliant Servers posted in here and am trying to set it up.
I want it to access as an FTP server from outside my lan and access the 2 storage drives in the Server as network drives on my other devices.
FTP
I have set up the server with a static IP, I have also forwarded the ports on the router and allowed them through the firewall.
I tried setting up the built in FTP on windows server but it was above my head. If anyone can advise me on that I would be grateful. I installed the components but I couldn't work out how to set it up. I'm hoping to connect through my external IP and the port is routed to the local IP of the server.
I also tried filezilla I think I set it up correctly when I connect the log seems to think it is fine but the device times out and won't show the drive.
Log below.
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> Connected on port 21, sending welcome message...
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> 220-FileZilla Server version 0.9.47 beta
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> 220-written by Tim Kosse ([email protected])
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> 220 Please visit https://filezilla-project.org/
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> USER cbrown
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> 331 Password required for cbrown
(000022)28/09/2014 12:21:32 - (not logged in) (192.168.0.23)> PASS ********
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 230 Logged on
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> opts utf8 on
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 202 UTF8 mode is always enabled. No need to send this command.
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> PWD
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 257 "/" is current directory.
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> CWD /
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 250 CWD successful. "/" is current directory.
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> noop
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 200 OK
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> TYPE A
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 200 Type set to A
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> PASV
(000022)28/09/2014 12:21:32 - cbrown (192.168.0.23)> 227 Entering Passive Mode (192,168,0,10,195,96)
(000022)28/09/2014 12:21:53 - cbrown (192.168.0.23)> noop
(000022)28/09/2014 12:21:53 - cbrown (192.168.0.23)> 200 OK
(000022)28/09/2014 12:21:53 - cbrown (192.168.0.23)> CWD /
(000022)28/09/2014 12:21:53 - cbrown (192.168.0.23)> 250 CWD successful. "/" is current directory.
(000022)28/09/2014 12:22:10 - cbrown (192.168.0.23)> disconnected.
Benson_JV
PostPosted: 16:38 - 27 Sep 2014    Post subject: Reply with quote
First of all, presumably you are on a dynamic IP from your provider, not static?
If so I believe you'll have to set up dynamic DNS.
PostPosted: 17:17 - 27 Sep 2014    Post subject: Reply with quote
Have you tested from outside?
That is coming from your internal address, put your external IP into https://ping.eu/port-chk/ and port 21
Does it say its showing as open and listening?
PostPosted: 17:24 - 27 Sep 2014    Post subject: Reply with quote
I'm not on a static IP, but it doesn't change if that makes sense. Over the last few years it's changed only once or twice I think despite many modem reboots. So I'm quite happy with treating it as static. I used to have FileZilla set up on my desktop for months with no issues. I'd like to use the built in windows options if possible but it is above my head!
As an aside I've mapped 2 drives in the server as network drives on my desktop, the transfer seems slower than I'd though at about 3Mbps it also takes 'my computer' a long time to open (I assume from trying to resolve the drives) any tips on what I should be looking at?
PostPosted: 17:52 - 27 Sep 2014    Post subject: Reply with quote
Yep it's open. Thumbs Up
t121anf
PostPosted: 19:09 - 27 Sep 2014    Post subject: Reply with quote
FTP why not sFTP?
Can't say specifically for 2012 but for 2008 it's in server features/roles etc accessed via Server Manager.
PostPosted: 08:11 - 28 Sep 2014    Post subject: Reply with quote
t121anf wrote:
FTP why not sFTP?
Why sFTP not FTP?
I know where the options for it are, I just can't get it working it is over my head.
duhawkz
PostPosted: 10:00 - 28 Sep 2014    Post subject: Reply with quote
sFTP is secure, it uses ssh so traffic is encrypted.
Ftp is not everything is sent in plain text, password an all
PostPosted: 12:53 - 28 Sep 2014    Post subject: Reply with quote
I'm not overly bother tbh it isn't anything remote sensitive.
PostPosted: 14:46 - 28 Sep 2014    Post subject: Reply with quote
Does this look right to you?
I thought the speed should be about double that,
It fluctuates between 1MB/s and 6MB/s the throughput fluctuates between 60mbps and 100mbps and if I stop the transfer it drops to nothing - kbs.
Shouldn't the speed be faster with that kind of throughput? MB/mb is give or take 1/10 right so the speeds should be closer to 5-10MB/s?
https://www.bikechatforums.com/download.php?id=93774
PostPosted: 15:32 - 28 Sep 2014    Post subject: Reply with quote
Question 2 I have set up an ftp server and can telnet in but only with the firewall off when it's on a I can't despite there being a rule in the firewall.
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\Chris>telnet 192.168.0.10 21
Connecting To 192.168.0.10...Could not open connection to the host, on port 21: C
onnect failed
C:\Users\Chris>
https://www.bikechatforums.com/download.php?id=93775
Everything is cool with the firewall turned off but not on, Any ideas?
_Chris_
PostPosted: 15:39 - 28 Sep 2014    Post subject: Reply with quote
The last pic is of your 'outbound rules', you need to set the same rule in your 'inbound rules'
good luck
Just getting started
PostPosted: 15:40 - 28 Sep 2014    Post subject: Reply with quote
good luck
It is a pic of the inbound rules... Outbound is the same except it is port 20
CaNsA
PostPosted: 16:54 - 28 Sep 2014    Post subject: Reply with quote
Why'd you choose Windows server over a different o/s ?
_Chris_
PostPosted: 17:12 - 28 Sep 2014    Post subject: Reply with quote
chris-red wrote:
good luck
Yep, I'm a dick who didn't look properly.
Now I don't know why you have an issue, does the port ping from an external location when the firewall's on?
PostPosted: 19:52 - 28 Sep 2014    Post subject: Reply with quote
Same reason everyone does I'm familar with Windows and everything else is windows!
CaNsA
PostPosted: 20:15 - 28 Sep 2014    Post subject: Reply with quote
Everything in my house is windows, but my server runs OMV
PostPosted: 21:23 - 28 Sep 2014    Post subject: Reply with quote
Embarrassed to say...
I turned it off and on again and it worked Laughing
I still have my question about the speed though!
_Chris_
PostPosted: 22:20 - 28 Sep 2014    Post subject: Reply with quote
is all your hardware gigabit? every switch/router/hub and cat6 cable?
personally, i have my pc/server/media centre all into a gigabit switch, which is then connected to the shitty adsl router I got for free from ISP (which is good enough for me not to spend any money replacing)
PostPosted: 10:34 - 29 Sep 2014    Post subject: Reply with quote
Nope it's a powerline connection. I'd like gigabit but cable routing is too much agro.
My question is about the speed I have, 100mbps. If the Throughput 100mbps and if I end the transfer and the throughput drops to, to all intents and purposes 0. Shouldn't my speed be more than 6MB/s
A quick google says 100mbps = 12.2 MB/s it seems odd I get half of that.
_Chris_
PostPosted: 11:05 - 29 Sep 2014    Post subject: Reply with quote
Sounds about right, it 'thinks' it has a 100Mb connection until it tries to use it Laughing
I've got a powerline thing too, I love it, but it's certainly not as good when transferring large files compared to a traditional cable.
Actually, to see where the problem really is, remove the powerline and connect directly (even if it means moving your pc for an hour or so), if you still only get 6mb at least you can start looking elsewhere (disk speed/processor maxing out?)
CaNsA
PostPosted: 12:16 - 29 Sep 2014    Post subject: Reply with quote
lose the powershit connection.
get 1 long ethernet cable and run it round the edge of the rooms/stairs etc etc
once it's done, it's done.
PostPosted: 13:44 - 29 Sep 2014    Post subject: Reply with quote
Embarassed
I bought 1gpbs Powerline connectors 3 years ago, however I only used cat5 cable. I have grabbed a load of cat6 from work and will try again. Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed
_Chris_
PostPosted: 15:59 - 29 Sep 2014    Post subject: Reply with quote
ahh the joys of working in IT all the free cables you can eat Mr. Green
CaNsA
PostPosted: 17:31 - 29 Sep 2014    Post subject: Reply with quote
chris-red wrote:
Embarassed
Cat5 with give you gbit speeds.
The last post was made 12 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 133.61 Kb
