Oven repair
LustyLew
PostPosted: 11:22 - 03 Oct 2014    Post subject: Oven repair Reply with quote
Hey all,
after a bit of advice.
My oven has been acting up lately. I've got a conventional electric oven, with top and bottom heating elements. Just recently it's been getting very hot. Dial on the front set to 175c, but the oven thermometer I bought showing 210c!
I've been hunting around online and most opinions suggest that the thermostat is bust, but on further testing I'm not so sure. I tested just using the bottom element, set to 250c and it was still cold to touch after 10 minutes. Switching to both elements and it started to heat.
The thermostat sensor sits in the oven in a vertical position, so I'm now beginning to think that it's due to the faulty element. I dug out my multi-meter and checked all the switches and connections, 240v everywhere (where it should be!). I didn't get a chance to check the bottom elements as it's only accessible from the underneath and this was 11pm!
So, I guess, what I'm asking is due to heat riding etc, and the oven not being fan assisted. Would you expect the thermostat to register incorrectly resulting in the upper half of the oven getting too hot and the bottom staying too cold?
I'm a bit annoyed as if this happened a few months later I'd be able to buy a decent fan assisted oven. This B&Q POS is crap!
Thanks! Smile
fatjames
PostPosted: 12:11 - 03 Oct 2014    Post subject: Reply with quote
It does sounds like the thermostat has a part to play in whatever is wrong. Are you under warrenty?
LustyLew
PostPosted: 12:21 - 03 Oct 2014    Post subject: Reply with quote
I don't. It was replaced just before I moved in about 18 months ago. The handbook says 2 year, but proof of purchase required. Might just bite the bullet and replace.
LustyLew
PostPosted: 13:39 - 06 Oct 2014    Post subject: Reply with quote
240v getting right to the element.
New one on order. Will test fo continuity when I get a chance to cut power and remove the oven properly...
Richy CB1000
PostPosted: 13:07 - 07 Oct 2014    Post subject: Reply with quote
If it dries out your cylinder head after coming out of a rinse hold in the dishwasher it's fine......
CB1000 Big One, Triumph T3 Trophy 900
The last post was made 11 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 43.61 Kb
