| trisktm |
 trisktm L Plate Warrior
 Posted: 00:22 - 20 Jan 2005 Post subject: seat off on CBR 600F 1998 |
bloke i bought it from never removed it and didnt know how, and its my 1st bike so i dont know, help!!  ____________________ 1998 CBR 600F
2001 KTM 400EXC FOR SALE ?2800 |
| Demonic69 |
 Demonic69 The Pink Rhino
| Bendy |
 Bendy Mrs Sensible
 Posted: 11:39 - 20 Jan 2005 Post subject: |
Is that a 1998 steel frame or a 1998 ally frame CBR?
1998 *should* be a steely, but I've seen some FXs advertised as 1998 on a 'T' plate so you never know.
If it's the ally one, the seat lock is just above the numberplate.
If it's the steel one I have no idea.  |
| swaffs |
 swaffs World Chat Champion
| matlow |
 matlow Scooby Slapper
 Posted: 14:16 - 20 Jan 2005 Post subject: |
after unlocking the seat, grab the rear of the seat and pull up and towards the back of the bike, should come right off  ____________________ Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s |
| fuel |
 fuel Nitrous Nuisance
 Posted: 22:47 - 20 Jan 2005 Post subject: |
hi, i have a cbr 600 1998 fw,
you cannot lift the seat on this model
there is very little storage on the bike, and you access this by removing the under seat side fairing on the left side of the bike.
under this panel there is 2 little cubbys, one near the fuel tap and one right at the back under where the pass seat is, but like i said the seat does not flip up.
the only reason to remove a seat on a 1998 cbr 600 is to get to the battery, or to take the tank off to change the air filter ect, and the seat is held on by a couple of 10mm bolts, one on each side, then you gently lift the seat from the rear and pull it of towards the rear of the bike
to remove the under seat fairing start on the left, look just above the left foot peg and you will see a plastic screw with a a flat head drive, ( same on the right) undo this and then you can carefully pull the fairing from the bike which after undoing this plastic screw, is only help on by pull in and out fixings, but be carefull as by the grab rail, the fairing can be tricky and there is a couple of fragile fixings
if you need to know any more bout the 98 600 fw, drop me a line.
hope this helps
Fuel |
| Barker-CBR 600 |
 Barker-CBR 600 Could Be A Chat Bot
The last post was made 21 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
