| Mirey |
 Mirey Two Stroke Sniffer
 Posted: 10:26 - 04 Oct 2014 Post subject: Bolt stuck trying to remove front brake |
I'm trying to replace the front tyre on my YBR but I can't get the front brake off.
No matter how hard I try, it just won't budge. It looks like the bolt is starting to deform as well...
any ideas?
https://s10.postimg.org/iw58ojkft/bolt.jpg |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 10:34 - 04 Oct 2014 Post subject: |
WD40, hammer it a bit, then when using the wrench don't just turn it, give it the initial impact to break the tension. Also push on the bolt when using the wrench to prevent it from ruining the head.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:37 - 04 Oct 2014 Post subject: |
Freeze and release?
Also use a proper hex socket, not one of the star type ones, it'll have far less chance of buggering the head.
It wouldn't surprise me if some nobber's used loads of locking compound on it to be fair. ____________________ My Flickr |
| c_dug |
 c_dug Super Spammer
 Posted: 10:42 - 04 Oct 2014 Post subject: |
A six sided socket should see that off without too much hassle and you can probably pick up an individual socket from any local tool place, or maybe halfords, for a couple of quid.
If I was really worried about it rounding I would combine the six sided socket with my Impact Driver There isn't much that that combination wont see undone. Certainly it should see a calliper bolt undone.
Don't even half consider putting it back in, buy yourself a replacement for about a fiver. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Ed Case |
 Ed Case World Chat Champion
| jeddy11 |
 jeddy11 Traffic Copper
| kramdra |
 kramdra World Chat Champion
| Taught2BCauti... |
 Posted: 15:51 - 04 Oct 2014 Post subject: |
Those Irwin Bolt Grips are awesome - I have lost most of mine now - but don't count on using the bolt again after using them!
Bolts with a large flange like that are always trouble - especially if someone has used too much Loctite on the threads, and some has got between the flange and the body.
I would try tapping the head of the bolt gently - left to right, up and down - to break the bond.
Try attaching some mole grips to the bolt head whilst heating the threaded part up with a hairdryer (a bit gay, but it works) then remove the mole grips and use the Irwins.
The mole grips act as a heat-sink, to stop the bolt getting too hot and expanding as well. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| lihp |
 lihp World Chat Champion
| kramdra |
 Posted: 16:01 - 04 Oct 2014 Post subject: |
| c_dug |
 c_dug Super Spammer
| Mirey |
| Taught2BCauti... |
| c_dug |
 c_dug Super Spammer
| Islander |
 Islander World Chat Champion
| kramdra |
 Posted: 17:15 - 04 Oct 2014 Post subject: |
Irwins are destructive, and as previously noted, the bolt has already been destructed. A chisel and hammer to tap it round is equally effective, less destructive and cheaper.
www.ebay.co.uk/sch/i.html?_nkw=m8+35+bzp+12.9&_sacat=0
35-40mm is the correct length for my bike, measure the old to be sure
c_dug... of the 9 bikes in your sig how may deadeded?  |
| thomp1983 |
 thomp1983 Crazy Courier
| J4mes |
 J4mes World Chat Champion
 Posted: 19:22 - 04 Oct 2014 Post subject: |
I normally try to tighten it first in order to break the seal, that way if it is bollocks tight and the tool slips you don't further damage the head on the edges you need to stay intact to undo it.
Shocking it can also help, so perhaps try a short ratchet handle and smack it with a mallet
| Raffles |
 Raffles World Chat Champion
| J4mes |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| CBRMAN94 |
 CBRMAN94 Nitrous Nuisance
 Posted: 21:07 - 04 Oct 2014 Post subject: |
Am i the only one who is wondering why you need to take the front brake off for a tyre change? Spindle out, Wheel out, Tyre change and stick it back in  ____________________ Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR |
| drbaig |
 drbaig Crazy Courier
 Posted: 22:03 - 04 Oct 2014 Post subject: |
A lot of these issues happen because there is not enough leverage and a lot of force.
If I have trouble getting any bolts of these days I just go grab the breaker bar or a pipe to put over the ratchet. Every bolt comes off with ease. If only I had done this with the countless bolts I've rounded previously. ____________________ yzf 600r  |
| Suntan Sid |
 Posted: 23:09 - 04 Oct 2014 Post subject: |
As DrBaig says get a decent breaker bar and 6 sided socket!
Bagged myself a second hand 2.5ft breaker bar, at the market, years ago, it laughs at bolts like that!
If you still have trouble with the breaker bar get a friend to wallop the bar/socket while you've got pressure on the bolt, should shock it enough to get it moving. ____________________ "Everybody needs money, that's why they call it money!"  |
The last post was made 12 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
